Handling Logouts
Logout Java/Kotlin Configuration
When injecting the HttpSecurity bean, logout capabilities are automatically applied. The default is that accessing the URL /logout will log the user out by:spring-doc.cn
Similar to configuring login capabilities, however, you also have various options to further customize your logout requirements:spring-doc.cn
Logout Configuration
public SecurityFilterChain filterChain(HttpSecurity http) {
    http
        .logout(logout -> logout                                                (1)
            .logoutUrl("/my/logout")                                            (2)
            .logoutSuccessUrl("/my/index")                                      (3)
            .logoutSuccessHandler(logoutSuccessHandler)                         (4)
            .invalidateHttpSession(true)                                        (5)
            .addLogoutHandler(logoutHandler)                                    (6)
            .deleteCookies(cookieNamesToClear)                                  (7)
    http {
        logout {
            logoutUrl = "/my/logout"                              (1)
            logoutSuccessUrl = "/my/index"                        (2)
            logoutSuccessHandler = customLogoutSuccessHandler     (3)
            invalidateHttpSession = true                          (4)
            addLogoutHandler(logoutHandler)                       (5)
            deleteCookies(cookieNamesToClear)                     (6)
1 Provides logout support.
2 The URL that triggers log out to occur (default is /logout). If CSRF protection is enabled (default), then the request must also be a POST. For more information, please consult the Javadoc.
3 The URL to redirect to after logout has occurred. The default is /login?logout. For more information, please consult the Javadoc.
4 Let’s you specify a custom LogoutSuccessHandler. If this is specified, logoutSuccessUrl() is ignored. For more information, please consult the Javadoc.
5 Specify whether to invalidate the HttpSession at the time of logout. This is true by default. Configures the SecurityContextLogoutHandler under the covers. For more information, please consult the Javadoc.
6 Adds a LogoutHandler. SecurityContextLogoutHandler is added as the last LogoutHandler by default.
7 Allows specifying the names of cookies to be removed on logout success. This is a shortcut for adding a CookieClearingLogoutHandler explicitly.
Logouts can of course also be configured using the XML Namespace notation. Please see the documentation for the logout element in the Spring Security XML Namespace section for further details.spring-doc.cn
Generally, in order to customize logout functionality, you can add LogoutHandler and/or LogoutSuccessHandler implementations. For many common scenarios, these handlers are applied under the covers when using the fluent API.spring-doc.cn
Logout XML Configuration
The logout element adds support for logging out by navigating to a particular URL. The default logout URL is /logout, but you can set it to something else using the logout-url attribute. More information on other available attributes may be found in the namespace appendix.spring-doc.cn
LogoutHandler
Generally, LogoutHandler implementations indicate classes that are able to participate in logout handling. They are expected to be invoked to perform necessary clean-up. As such they should not throw exceptions. Various implementations are provided:spring-doc.cn
Instead of providing LogoutHandler implementations directly, the fluent API also provides shortcuts that provide the respective LogoutHandler implementations under the covers. E.g. deleteCookies() allows specifying the names of one or more cookies to be removed on logout success. This is a shortcut compared to adding a CookieClearingLogoutHandler.spring-doc.cn
The LogoutSuccessHandler is called after a successful logout by the LogoutFilter, to handle e.g. redirection or forwarding to the appropriate destination. Note that the interface is almost the same as the LogoutHandler but may raise an exception.spring-doc.cn
The following implementations are provided:spring-doc.cn
As mentioned above, you don’t need to specify the SimpleUrlLogoutSuccessHandler directly. Instead, the fluent API provides a shortcut by setting the logoutSuccessUrl(). This will setup the SimpleUrlLogoutSuccessHandler under the covers. The provided URL will be redirected to after a logout has occurred. The default is /login?logout.spring-doc.cn
The HttpStatusReturningLogoutSuccessHandler can be interesting in REST API type scenarios. Instead of redirecting to a URL upon the successful logout, this LogoutSuccessHandler allows you to provide a plain HTTP status code to be returned. If not configured a status code 200 will be returned by default.spring-doc.cn
