HTTP
All HTTP based communication should be protected using TLS.spring-doc.cn
Below you can find details around Servlet specific features that assist with HTTPS usage.spring-doc.cn
Redirect to HTTPS
If a client makes a request using HTTP rather than HTTPS, Spring Security can be configured to redirect to HTTPS.spring-doc.cn
For example, the following Java configuration will redirect any HTTP requests to HTTPS:spring-doc.cn
Redirect to HTTPS
@EnableWebSecurity
public class WebSecurityConfig {
		http
			.requiresChannel(channel -> channel
				.anyRequest().requiresSecure()
		return http.build();
@EnableWebSecurity
class SecurityConfig {
        http {
            requiresChannel {
                secure(AnyRequestMatcher.INSTANCE, "REQUIRES_SECURE_CHANNEL")
        return http.build()
The following XML configuration will redirect all HTTP requests to HTTPSspring-doc.cn
Redirect to HTTPS with XML Configuration
<http>
	<intercept-url pattern="/**" access="ROLE_USER" requires-channel="https"/>
</http>
Strict Transport Security
Spring Security provides support for Strict Transport Security and enables it by default.spring-doc.cn
Proxy Server Configuration
