HTTP
All HTTP based communication should be protected using TLS.spring-doc.cn
Below you can find details around WebFlux specific features that assist with HTTPS usage.spring-doc.cn
Redirect to HTTPS
If a client makes a request using HTTP rather than HTTPS, Spring Security can be configured to redirect to HTTPS.spring-doc.cn
For example, the following Java configuration will redirect any HTTP requests to HTTPS:spring-doc.cn
Redirect to HTTPS
SecurityWebFilterChain springSecurityFilterChain(ServerHttpSecurity http) {
	http
		.redirectToHttps(withDefaults());
	return http.build();
fun springSecurityFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
    return http {
        redirectToHttps { }
The configuration can easily be wrapped around an if statement to only be turned on in production. Alternatively, it can be enabled by looking for a property about the request that only happens in production. For example, if the production environment adds a header named X-Forwarded-Proto the following Java Configuration could be used:spring-doc.cn
Redirect to HTTPS when X-Forwarded
	http
		.redirectToHttps(redirect -> redirect
			.httpsRedirectWhen(e -> e.getRequest().getHeaders().containsKey("X-Forwarded-Proto"))
    return http {
        redirectToHttps {
            httpsRedirectWhen {
                it.request.headers.containsKey("X-Forwarded-Proto")
Strict Transport Security
Spring Security provides support for Strict Transport Security and enables it by default.spring-doc.cn
Proxy Server Configuration
