HTTP
All HTTP based communication, including static resources, should be protected using TLS.spring-doc.cn
As a framework, Spring Security does not handle HTTP connections and thus does not provide support for HTTPS directly. However, it does provide a number of features that help with HTTPS usage.spring-doc.cn
Redirect to HTTPS
When a client uses HTTP, Spring Security can be configured to redirect to HTTPS both Servlet and WebFlux environments.spring-doc.cn
Strict Transport Security
Spring Security provides support for Strict Transport Security and enables it by default.spring-doc.cn
Proxy Server Configuration
When using a proxy server it is important to ensure that you have configured your application properly. For example, many applications will have a load balancer that responds to request for example.com/ by forwarding the request to an application server at 192.168.1:8080. Without proper configuration, the application server will not know that the load balancer exists and treat the request as though 192.168.1:8080 was requested by the client.spring-doc.cn
To fix this you can use RFC 7239 to specify that a load balancer is being used. To make the application aware of this, you need to either configure your application server aware of the X-Forwarded headers. For example Tomcat uses the RemoteIpValve and Jetty uses ForwardedRequestCustomizer. Alternatively, Spring users can leverage ForwardedHeaderFilter.spring-doc.cn
Spring Boot users may use the server.use-forward-headers property to configure the application. See the Spring Boot documentation for further details.spring-doc.cn
