Testing Logout
While fairly trivial using standard Spring MVC Test, you can use Spring Security’s testing support to make testing log out easier. For example, the following logout RequestPostProcessor will submit a POST to "/logout" with a valid CSRF token:spring-doc.cn
mvc
	.perform(logout())
mvc
    .perform(logout())
You can also customize the URL to post to. For example, the snippet below will submit a POST to "/signout" with a valid CSRF token:spring-doc.cn
mvc
	.perform(logout("/signout"))
mvc
