对于最新的稳定版本,请使用 Spring Security 6.4.3! |
设置 MockMvc 和 Spring Security性
为了将 Spring Security 与 Spring MVC Test 一起使用,有必要添加 Spring SecurityFilterChainProxy
作为Filter
还需要添加 Spring Security 的TestSecurityContextHolderPostProcessor
以支持在 Spring MVC Test with Comments 中以用户身份运行。
这可以使用 Spring Security 的SecurityMockMvcConfigurers.springSecurity()
例如:
Spring Security 的测试支持需要spring-test-4.1.3.RELEASE或更高版本。 |
Java
Kotlin
import static org.springframework.security.test.web.servlet.setup.SecurityMockMvcConfigurers.*;
@ExtendWith(SpringExtension.class)
@ContextConfiguration(classes = SecurityConfig.class)
@WebAppConfiguration
public class CsrfShowcaseTests {
@Autowired
private WebApplicationContext context;
private MockMvc mvc;
@BeforeEach
public void setup() {
mvc = MockMvcBuilders
.webAppContextSetup(context)
.apply(springSecurity()) (1)
@ContextConfiguration(classes = [SecurityConfig::class])
@Autowired
private lateinit var context: WebApplicationContext
private var mvc: MockMvc? = null
@BeforeEach
fun setup() {
.apply<DefaultMockMvcBuilder>(springSecurity()) (1)
.build()
1
will perform all of the initial setup we need to integrate Spring Security with Spring MVC Test
