对于最新的稳定版本,请使用 Spring Security 6.4.3spring-doc.cadn.net.cn
授权事件
对于每个被拒绝的授权,都会显示AuthorizationDeniedEvent被解雇。 此外,还可以触发AuthorizationGrantedEvent对于已授予的授权。spring-doc.cadn.net.cn
要侦听这些事件,您必须首先发布AuthorizationEventPublisher.spring-doc.cadn.net.cn
Spring Security 的SpringAuthorizationEventPublisher可能会做得很好。 它使用 Spring 的ApplicationEventPublisher:spring-doc.cadn.net.cn
public AuthorizationEventPublisher authorizationEventPublisher
        (ApplicationEventPublisher applicationEventPublisher) {
    return new SpringAuthorizationEventPublisher(applicationEventPublisher);
fun authorizationEventPublisher
        (applicationEventPublisher: ApplicationEventPublisher?): AuthorizationEventPublisher {
    return SpringAuthorizationEventPublisher(applicationEventPublisher)
然后,您可以使用 Spring 的@EventListener支持:spring-doc.cadn.net.cn
@Component
public class AuthenticationEvents {
    @EventListener
    public void onFailure(AuthorizationDeniedEvent failure) {
@Component
    @EventListener
    fun onFailure(failure: AuthorizationDeniedEvent?) {
授权授予事件
因为AuthorizationGrantedEvent可能会非常嘈杂,默认情况下不会发布它们。spring-doc.cadn.net.cn
事实上,发布这些事件可能需要您具备一些业务逻辑,以确保您的应用程序不会被嘈杂的授权事件所淹没。spring-doc.cadn.net.cn
您可以创建自己的事件发布者来筛选成功事件。 例如,以下发布者仅发布授权,其中ROLE_ADMIN是必需的:spring-doc.cadn.net.cn
@Component
public class MyAuthorizationEventPublisher implements AuthorizationEventPublisher {
    private final ApplicationEventPublisher publisher;
    private final AuthorizationEventPublisher delegate;
    public MyAuthorizationEventPublisher(ApplicationEventPublisher publisher) {
        this.publisher = publisher;
        this.delegate = new SpringAuthorizationEventPublisher(publisher);
    public <T> void publishAuthorizationEvent(Supplier<Authentication> authentication,
            T object, AuthorizationDecision decision) {
        if (decision == null) {
            return;
        if (!decision.isGranted()) {
            this.delegate.publishAuthorizationEvent(authentication, object, decision);
            return;
        if (shouldThisEventBePublished(decision)) {
            AuthorizationGrantedEvent granted = new AuthorizationGrantedEvent(
            this.publisher.publishEvent(granted);
    private boolean shouldThisEventBePublished(AuthorizationDecision decision) {
        if (!(decision instanceof AuthorityAuthorizationDecision)) {
            return false;
        Collection<GrantedAuthority> authorities = ((AuthorityAuthorizationDecision) decision).getAuthorities();
        for (GrantedAuthority authority : authorities) {
            if ("ROLE_ADMIN".equals(authority.getAuthority())) {
                return true;
        return false;
@Component
class MyAuthorizationEventPublisher(val publisher: ApplicationEventPublisher,
    val delegate: SpringAuthorizationEventPublisher = SpringAuthorizationEventPublisher(publisher)):
    override fun <T : Any?> publishAuthorizationEvent(
        authentication: Supplier<Authentication>?,
        `object`: T,
        decision: AuthorizationDecision?
            return
        if (!decision.isGranted) {
            this.delegate.publishAuthorizationEvent(authentication, `object`, decision)
            return
            val granted = AuthorizationGrantedEvent(authentication, `object`, decision)
    private fun shouldThisEventBePublished(decision: AuthorizationDecision): Boolean {
        if (decision !is AuthorityAuthorizationDecision) {
            return false
        val authorities = decision.authorities
        for (authority in authorities) {
            if ("ROLE_ADMIN" == authority.authority) {
                return true
        return false
