对于最新的稳定版本,请使用 Spring Security 6.4.3! |
Java 配置
在 Spring 3.1 中,Spring Framework 中添加了对 Java 配置的一般支持。 从 Spring Security 3.2 开始,就有了 Spring Security Java 配置支持,这使用户无需使用任何 XML 即可轻松配置 Spring Security。
如果您熟悉 Security Namespace Configuration,那么您应该会发现它与 Security Java Configuration 支持之间有很多相似之处。
Spring Security 提供了许多示例应用程序,这些应用程序演示了 Spring Security Java Configuration 的使用。 |
Hello Web Security Java 配置
第一步是创建我们的 Spring Security Java 配置。
该配置将创建一个称为springSecurityFilterChain
它负责应用程序中的所有安全性(保护应用程序 URL、验证提交的用户名和密码、重定向到登录表单等)。
您可以在下面找到 Spring Security Java 配置的最基本示例:
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.context.annotation.*;
import org.springframework.security.config.annotation.authentication.builders.*;
import org.springframework.security.config.annotation.web.configuration.*;
@EnableWebSecurity
public class WebSecurityConfig {
public UserDetailsService userDetailsService() {
InMemoryUserDetailsManager manager = new InMemoryUserDetailsManager();
manager.createUser(User.withDefaultPasswordEncoder().username("user").password("password").roles("USER").build());
return manager;
There really isn’t much to this configuration, but it does a lot.
You can find a summary of the features below:
Require authentication to every URL in your application
Generate a login form for you
Allow the user with the Username user and the Password password to authenticate with form based authentication
Allow the user to logout
CSRF attack prevention
Session Fixation protection
Security Header integration
HTTP Strict Transport Security for secure requests
X-Content-Type-Options integration
Cache Control (can be overridden later by your application to allow caching of your static resources)
X-XSS-Protection integration
X-Frame-Options integration to help prevent Clickjacking
Integrate with the following Servlet API methods
AbstractSecurityWebApplicationInitializer
The next step is to register the springSecurityFilterChain
with the war.
This can be done in Java Configuration with Spring’s WebApplicationInitializer support in a Servlet 3.0+ environment.
Not suprisingly, Spring Security provides a base class AbstractSecurityWebApplicationInitializer
that will ensure the springSecurityFilterChain
gets registered for you.
The way in which we use AbstractSecurityWebApplicationInitializer
differs depending on if we are already using Spring or if Spring Security is the only Spring component in our application.
AbstractSecurityWebApplicationInitializer without Existing Spring - Use these instructions if you are not using Spring already
AbstractSecurityWebApplicationInitializer with Spring MVC - Use these instructions if you are already using Spring
If you are not using Spring or Spring MVC, you will need to pass in the WebSecurityConfig
into the superclass to ensure the configuration is picked up.
You can find an example below:
import org.springframework.security.web.context.*;
public class SecurityWebApplicationInitializer
extends AbstractSecurityWebApplicationInitializer {
public SecurityWebApplicationInitializer() {
super(WebSecurityConfig.class);
The SecurityWebApplicationInitializer
will do the following things:
Automatically register the springSecurityFilterChain Filter for every URL in your application
Add a ContextLoaderListener that loads the WebSecurityConfig.
If we were using Spring elsewhere in our application we probably already had a WebApplicationInitializer
that is loading our Spring Configuration.
If we use the previous configuration we would get an error.
Instead, we should register Spring Security with the existing ApplicationContext
For example, if we were using Spring MVC our SecurityWebApplicationInitializer
would look something like the following:
This would simply only register the springSecurityFilterChain Filter for every URL in your application.
After that we would ensure that WebSecurityConfig
was loaded in our existing ApplicationInitializer.
For example, if we were using Spring MVC it would be added in the getRootConfigClasses()
public class MvcWebApplicationInitializer extends
AbstractAnnotationConfigDispatcherServletInitializer {
protected Class<?>[] getRootConfigClasses() {
return new Class[] { WebSecurityConfig.class };
// ... other overrides ...
HttpSecurity
Thus far our WebSecurityConfig only contains information about how to authenticate our users.
How does Spring Security know that we want to require all users to be authenticated?
How does Spring Security know we want to support form based authentication?
Actually, there is a bean that is being invoked behind the scenes called SecurityFilterChain
It is configured with the following default implementation:
http
.authorizeRequests(authorize -> authorize
.anyRequest().authenticated()
.formLogin(withDefaults())
.httpBasic(withDefaults());
return http.build();
The default configuration above:
Ensures that any request to our application requires the user to be authenticated
Allows users to authenticate with form based login
Allows users to authenticate with HTTP Basic authentication
You will notice that this configuration is quite similar the XML Namespace configuration:
<http>
<intercept-url pattern="/**" access="authenticated"/>
<form-login />
<http-basic />
</http>
Multiple HttpSecurity
We can configure multiple HttpSecurity
instances just as we can have multiple <http>
blocks.
The key is to register multiple SecurityFilterChain
s.
For example, the following is an example of having a different configuration for URL’s that start with /api/
@EnableWebSecurity
public class MultiHttpSecurityConfig {
@Bean (1)
public UserDetailsService userDetailsService() throws Exception {
// ensure the passwords are encoded properly
UserBuilder users = User.withDefaultPasswordEncoder();
manager.createUser(users.username("user").password("password").roles("USER").build());
manager.createUser(users.username("admin").password("password").roles("USER","ADMIN").build());
return manager;
@Order(1) (2)
public SecurityFilterChain apiFilterChain(HttpSecurity http) throws Exception {
http
.antMatcher("/api/**") (3)
.anyRequest().hasRole("ADMIN")
@Bean (4)
public SecurityFilterChain formLoginFilterChain(HttpSecurity http) throws Exception {
http
.formLogin(withDefaults());
1
Configure Authentication as normal
2
Register an instance of SecurityFilterChain
that contains @Order
to specify which SecurityFilterChain
should be considered first.
3
The http.antMatcher
states that this HttpSecurity
will only be applicable to URLs that start with /api/
4
Register another instance of SecurityFilterChain
If the URL does not start with /api/
this configuration will be used.
This configuration is considered after apiFilterChain
since it has an @Order
value after 1
(no @Order
defaults to last).
Custom DSLs
You can provide your own custom DSLs in Spring Security.
For example, you might have something that looks like this:
public class MyCustomDsl extends AbstractHttpConfigurer<MyCustomDsl, HttpSecurity> {
private boolean flag;
public void init(HttpSecurity http) throws Exception {
// any method that adds another configurer
// must be done in the init method
http.csrf().disable();
public void configure(HttpSecurity http) throws Exception {
ApplicationContext context = http.getSharedObject(ApplicationContext.class);
// here we lookup from the ApplicationContext. You can also just create a new instance.
MyFilter myFilter = context.getBean(MyFilter.class);
myFilter.setFlag(flag);
http.addFilterBefore(myFilter, UsernamePasswordAuthenticationFilter.class);
public MyCustomDsl flag(boolean value) {
this.flag = value;
return this;
public static MyCustomDsl customDsl() {
return new MyCustomDsl();
This is actually how methods like HttpSecurity.authorizeRequests()
are implemented.
The custom DSL can then be used like this:
@EnableWebSecurity
public class Config {
http
.apply(customDsl())
.flag(true)
.and()
The code is invoked in the following order:
Code in `Config`s configure method is invoked
Code in `MyCustomDsl`s init method is invoked
Code in `MyCustomDsl`s configure method is invoked
If you want, you can add MyCustomDsl
to HttpSecurity
by default by using SpringFactories
For example, you would create a resource on the classpath named META-INF/spring.factories
with the following contents:
org.springframework.security.config.annotation.web.configurers.AbstractHttpConfigurer = sample.MyCustomDsl
Users wishing to disable the default can do so explicitly.
@EnableWebSecurity
http
.apply(customDsl()).disable()
Post Processing Configured Objects
Spring Security’s Java Configuration does not expose every property of every object that it configures.
This simplifies the configuration for a majority of users.
Afterall, if every property was exposed, users could use standard bean configuration.
While there are good reasons to not directly expose every property, users may still need more advanced configuration options.
To address this Spring Security introduces the concept of an ObjectPostProcessor
which can be used to modify or replace many of the Object instances created by the Java Configuration.
For example, if you wanted to configure the filterSecurityPublishAuthorizationSuccess
property on FilterSecurityInterceptor
you could use the following:
http
.withObjectPostProcessor(new ObjectPostProcessor<FilterSecurityInterceptor>() {
public <O extends FilterSecurityInterceptor> O postProcess(
O fsi) {
fsi.setPublishAuthorizationSuccess(true);
return fsi;
