For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
Setting Up MockMvc and Spring Security
In order to use Spring Security with Spring MVC Test it is necessary to add the Spring Security FilterChainProxy as a Filter. It is also necessary to add Spring Security’s TestSecurityContextHolderPostProcessor to support Running as a User in Spring MVC Test with Annotations. This can be done using Spring Security’s SecurityMockMvcConfigurers.springSecurity(). For example:spring-doc.cn
Spring Security’s testing support requires spring-test-4.1.3.RELEASE or greater.
import static org.springframework.security.test.web.servlet.setup.SecurityMockMvcConfigurers.*;
@ExtendWith(SpringExtension.class)
@ContextConfiguration(classes = SecurityConfig.class)
@WebAppConfiguration
public class CsrfShowcaseTests {
	@Autowired
	private WebApplicationContext context;
	private MockMvc mvc;
	@BeforeEach
	public void setup() {
		mvc = MockMvcBuilders
				.webAppContextSetup(context)
				.apply(springSecurity()) (1)
@ContextConfiguration(classes = [SecurityConfig::class])
    @Autowired
    private lateinit var context: WebApplicationContext
    private var mvc: MockMvc? = null
    @BeforeEach
    fun setup() {
            .apply<DefaultMockMvcBuilder>(springSecurity()) (1)
            .build()
1 SecurityMockMvcConfigurers.springSecurity() will perform all of the initial setup we need to integrate Spring Security with Spring MVC Test
