For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
Security HTTP Response Headers
Security HTTP Response Headers can be used to increase the security of web applications. This section is dedicated to WebFlux based support for Security HTTP Response Headers.spring-doc.cn
Default Security Headers
Spring Security provides a default set of Security HTTP Response Headers to provide secure defaults. While each of these headers are considered best practice, it should be noted that not all clients utilize the headers, so additional testing is encouraged.spring-doc.cn
You can customize specific headers. For example, assume that you want the defaults except you wish to specify SAMEORIGIN for X-Frame-Options.spring-doc.cn
You can easily do this with the following Configuration:spring-doc.cn
Customize Default Security Headers
SecurityWebFilterChain springSecurityFilterChain(ServerHttpSecurity http) {
	http
		.headers(headers -> headers
			.frameOptions(frameOptions -> frameOptions
				.mode(Mode.SAMEORIGIN)
	return http.build();
fun webFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
    return http {
        headers {
            frameOptions {
                mode = Mode.SAMEORIGIN
If you do not want the defaults to be added and want explicit control over what should be used, you can disable the defaults. An example is provided below:spring-doc.cn
Disable HTTP Security Response Headers
	http
		.headers(headers -> headers.disable());
    return http {
        headers {
            disable()
Cache Control
Spring Security includes Cache Control headers by default.spring-doc.cn
However, if you actually want to cache specific responses, your application can selectively add them to the ServerHttpResponse to override the header set by Spring Security. This is useful to ensure things like CSS, JavaScript, and images are properly cached.spring-doc.cn
When using Spring WebFlux, this is typically done within your configuration. Details on how to do this can be found in the Static Resources portion of the Spring Reference documentationspring-doc.cn
If necessary, you can also disable Spring Security’s cache control HTTP response headers.spring-doc.cn
Cache Control Disabled
	http
			.cache(cache -> cache.disable())
    return http {
        headers {
            cache {
                disable()
Content Type Options
Spring Security includes Content-Type headers by default. However, you can disable it with:spring-doc.cn
Content Type Options Disabled
	http
			.contentTypeOptions(contentTypeOptions -> contentTypeOptions.disable())
    return http {
        headers {
            contentTypeOptions {
                disable()
HTTP Strict Transport Security (HSTS)
Spring Security provides the Strict Transport Security header by default. However, you can customize the results explicitly. For example, the following is an example of explicitly providing HSTS:spring-doc.cn
	http
			.hsts(hsts -> hsts
				.includeSubdomains(true)
				.preload(true)
				.maxAge(Duration.ofDays(365))
    return http {
        headers {
            hsts {
                includeSubdomains = true
                preload = true
                maxAge = Duration.ofDays(365)
X-Frame-Options
By default, Spring Security disables rendering within an iframe using X-Frame-Options.spring-doc.cn
You can customize frame options to use the same origin using the following:spring-doc.cn
X-Frame-Options: SAMEORIGIN
	http
				.mode(SAMEORIGIN)
    return http {
        headers {
            frameOptions {
                mode = SAMEORIGIN
X-XSS-Protection
By default, Spring Security instructs browsers to block reflected XSS attacks using the <<headers-xss-protection,X-XSS-Protection header>. You can disable X-XSS-Protection with the following Configuration:spring-doc.cn
X-XSS-Protection Customization
	http
			.xssProtection(xssProtection -> xssProtection.disable())
    return http {
        headers {
            xssProtection {
                disable()
Content Security Policy (CSP)
Spring Security does not add Content Security Policy by default, because a reasonable default is impossible to know without context of the application. The web application author must declare the security policy(s) to enforce and/or monitor for the protected resources.spring-doc.cn
For example, given the following security policy:spring-doc.cn
Content Security Policy Example
Content-Security-Policy: script-src 'self' https://trustedscripts.example.com; object-src https://trustedplugins.example.com; report-uri /csp-report-endpoint/
You can enable the CSP header as shown below:spring-doc.cn
	http
			.contentSecurityPolicy(policy -> policy
				.policyDirectives("script-src 'self' https://trustedscripts.example.com; object-src https://trustedplugins.example.com; report-uri /csp-report-endpoint/")
    return http {
        headers {
            contentSecurityPolicy {
                policyDirectives = "script-src 'self' https://trustedscripts.example.com; object-src https://trustedplugins.example.com; report-uri /csp-report-endpoint/"
To enable the CSP report-only header, provide the following configuration:spring-doc.cn
Content Security Policy Report Only
	http
				.reportOnly()
    return http {
        headers {
                reportOnly = true
Referrer Policy
Spring Security does not add Referrer Policy headers by default. You can enable the Referrer Policy header using configuration as shown below:spring-doc.cn
Referrer Policy Configuration
	http
			.referrerPolicy(referrer -> referrer
				.policy(ReferrerPolicy.SAME_ORIGIN)
    return http {
        headers {
            referrerPolicy {
                policy = ReferrerPolicy.SAME_ORIGIN
Feature Policy
Spring Security does not add Feature Policy headers by default. The following Feature-Policy header:spring-doc.cn
Feature-Policy Example
Feature-Policy: geolocation 'self'
You can enable the Feature Policy header as shown below:spring-doc.cn
Feature-Policy Configuration
	http
			.featurePolicy("geolocation 'self'")
    return http {
        headers {
Permissions Policy
Spring Security does not add Permissions Policy headers by default. The following Permissions-Policy header:spring-doc.cn
Permissions-Policy Example
Permissions-Policy: geolocation=(self)
You can enable the Permissions Policy header as shown below:spring-doc.cn
Permissions-Policy Configuration
	http
			.permissionsPolicy(permissions -> permissions
				.policy("geolocation=(self)")
    return http {
        headers {
            permissionsPolicy {
                policy = "geolocation=(self)"
Clear Site Data
Spring Security does not add Clear-Site-Data headers by default. The following Clear-Site-Data header:spring-doc.cn
Clear-Site-Data Example
Clear-Site-Data: "cache", "cookies"
can be sent on log out with the following configuration:spring-doc.cn
Clear-Site-Data Configuration
	ServerLogoutHandler securityContext = new SecurityContextServerLogoutHandler();
	ClearSiteDataServerHttpHeadersWriter writer = new ClearSiteDataServerHttpHeadersWriter(CACHE, COOKIES);
	ServerLogoutHandler clearSiteData = new HeaderWriterServerLogoutHandler(writer);
	DelegatingServerLogoutHandler logoutHandler = new DelegatingServerLogoutHandler(securityContext, clearSiteData);
	http
		.logout()
			.logoutHandler(logoutHandler);
    val securityContext: ServerLogoutHandler = SecurityContextServerLogoutHandler()
    val writer = ClearSiteDataServerHttpHeadersWriter(CACHE, COOKIES)
    val clearSiteData: ServerLogoutHandler = HeaderWriterServerLogoutHandler(writer)
    val customLogoutHandler = DelegatingServerLogoutHandler(securityContext, clearSiteData)
    return http {
        logout {
            logoutHandler = customLogoutHandler
Cross-Origin Policies
Spring Security provides built-in support for adding some Cross-Origin policies headers, those headers are:spring-doc.cn
Cross-Origin-Opener-Policy
Cross-Origin-Embedder-Policy
Cross-Origin-Resource-Policy
Spring Security does not add Cross-Origin Policies headers by default. The headers can be added with the following configuration:spring-doc.cn
@EnableWebFluxSecurity
@EnableWebFlux
public class WebSecurityConfig {
    SecurityWebFilterChain securityFilterChain(ServerHttpSecurity http) {
        http.headers((headers) -> headers
                .crossOriginOpenerPolicy(CrossOriginOpenerPolicy.SAME_ORIGIN)
                .crossOriginEmbedderPolicy(CrossOriginEmbedderPolicy.REQUIRE_CORP)
                .crossOriginResourcePolicy(CrossOriginResourcePolicy.SAME_ORIGIN));
@EnableWebFlux
open class CrossOriginPoliciesCustomConfig {
    open fun springWebFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
        return http {
            headers {
This configuration will write the headers with the values provided:spring-doc.cn
Cross-Origin-Opener-Policy: same-origin
Cross-Origin-Embedder-Policy: require-corp
Cross-Origin-Resource-Policy: same-origin
