For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
OAuth 2.0 Bearer Tokens
Bearer Token Resolution
By default, Resource Server looks for a bearer token in the Authorization header. This, however, can be customized in a handful of ways.spring-doc.cn
Reading the Bearer Token from a Custom Header
For example, you may have a need to read the bearer token from a custom header. To achieve this, you can expose a DefaultBearerTokenResolver as a bean, or wire an instance into the DSL, as you can see in the following example:spring-doc.cn
Custom Bearer Token Header
BearerTokenResolver bearerTokenResolver() {
    DefaultBearerTokenResolver bearerTokenResolver = new DefaultBearerTokenResolver();
    bearerTokenResolver.setBearerTokenHeaderName(HttpHeaders.PROXY_AUTHORIZATION);
    return bearerTokenResolver;
fun bearerTokenResolver(): BearerTokenResolver {
    val bearerTokenResolver = DefaultBearerTokenResolver()
<http>
    <oauth2-resource-server bearer-token-resolver-ref="bearerTokenResolver"/>
</http>
<bean id="bearerTokenResolver"
        class="org.springframework.security.oauth2.server.resource.web.DefaultBearerTokenResolver">
    <property name="bearerTokenHeaderName" value="Proxy-Authorization"/>
</bean>
Or, in circumstances where a provider is using both a custom header and value, you can use HeaderBearerTokenResolver instead.spring-doc.cn
Reading the Bearer Token from a Form Parameter
Or, you may wish to read the token from a form parameter, which you can do by configuring the DefaultBearerTokenResolver, as you can see below:spring-doc.cn
Form Parameter Bearer Token
DefaultBearerTokenResolver resolver = new DefaultBearerTokenResolver();
resolver.setAllowFormEncodedBodyParameter(true);
http
    .oauth2ResourceServer(oauth2 -> oauth2
        .bearerTokenResolver(resolver)
val resolver = DefaultBearerTokenResolver()
http {
    oauth2ResourceServer {
        bearerTokenResolver = resolver
<http>
</http>
        class="org.springframework.security.oauth2.server.resource.web.HeaderBearerTokenResolver">
    <property name="allowFormEncodedBodyParameter" value="true"/>
</bean>
Bearer Token Propagation
Now that your resource server has validated the token, it might be handy to pass it to downstream services. This is quite simple with ServletBearerExchangeFilterFunction, which you can see in the following example:spring-doc.cn
public WebClient rest() {
    return WebClient.builder()
            .filter(new ServletBearerExchangeFilterFunction())
fun rest(): WebClient {
            .filter(ServletBearerExchangeFilterFunction())
            .build()
When the above WebClient is used to perform requests, Spring Security will look up the current Authentication and extract any AbstractOAuth2Token credential. Then, it will propagate that token in the Authorization header.spring-doc.cn
For example:spring-doc.cn
this.rest.get()
        .uri("https://other-service.example.com/endpoint")
        .retrieve()
        .bodyToMono(String.class)
        .block()
this.rest.get()
        .retrieve()
        .bodyToMono<String>()
        .block()
Will invoke the other-service.example.com/endpoint, adding the bearer token Authorization header for you.spring-doc.cn
In places where you need to override this behavior, it’s a simple matter of supplying the header yourself, like so:spring-doc.cn
this.rest.get()
        .headers(headers -> headers.setBearerAuth(overridingToken))
        .retrieve()
        .block()
this.rest.get()
        .headers{  headers -> headers.setBearerAuth(overridingToken)}
        .retrieve()
        .block()
In this case, the filter will fall back and simply forward the request onto the rest of the web filter chain.spring-doc.cn
Unlike the OAuth 2.0 Client filter function, this filter function makes no attempt to renew the token, should it be expired. To obtain this level of support, please use the OAuth 2.0 Client filter.
RestTemplate support
There is no RestTemplate equivalent for ServletBearerExchangeFilterFunction at the moment, but you can propagate the request’s bearer token quite simply with your own interceptor:spring-doc.cn
RestTemplate rest() {
	RestTemplate rest = new RestTemplate();
	rest.getInterceptors().add((request, body, execution) -> {
		Authentication authentication = SecurityContextHolder.getContext().getAuthentication();
		if (authentication == null) {
			return execution.execute(request, body);
		if (!(authentication.getCredentials() instanceof AbstractOAuth2Token)) {
		AbstractOAuth2Token token = (AbstractOAuth2Token) authentication.getCredentials();
	    request.getHeaders().setBearerAuth(token.getTokenValue());
	return rest;
fun rest(): RestTemplate {
    val rest = RestTemplate()
    rest.interceptors.add(ClientHttpRequestInterceptor { request, body, execution ->
        val authentication: Authentication? = SecurityContextHolder.getContext().authentication
        if (authentication != null) {
        if (authentication!!.credentials !is AbstractOAuth2Token) {
        val token: AbstractOAuth2Token = authentication.credentials as AbstractOAuth2Token
        request.headers.setBearerAuth(token.tokenValue)
    return rest
Unlike the OAuth 2.0 Authorized Client Manager, this filter interceptor makes no attempt to renew the token, should it be expired. To obtain this level of support, please create an interceptor using the OAuth 2.0 Authorized Client Manager.
Bearer Token Failure
A bearer token may be invalid for a number of reasons. For example, the token may no longer be active.spring-doc.cn
In these circumstances, Resource Server throws an InvalidBearerTokenException. Like other exceptions, this results in an OAuth 2.0 Bearer Token error response:spring-doc.cn
HTTP/1.1 401 Unauthorized
WWW-Authenticate: Bearer error_code="invalid_token", error_description="Unsupported algorithm of none", error_uri="https://tools.ietf.org/html/rfc6750#section-3.1"
Additionally, it is published as an AuthenticationFailureBadCredentialsEvent, which you can listen for in your application like so:spring-doc.cn
@Component
public class FailureEvents {
	@EventListener
    public void onFailure(AuthenticationFailureBadCredentialsEvent badCredentials) {
		if (badCredentials.getAuthentication() instanceof BearerTokenAuthenticationToken) {
		    // ... handle
@Component
    @EventListener
    fun onFailure(badCredentials: AuthenticationFailureBadCredentialsEvent) {
        if (badCredentials.authentication is BearerTokenAuthenticationToken) {
            // ... handle
