For the latest stable version, please use Spring Security 6.4.1!spring-doc.cn
Testing with CSRF Protection
When testing any non-safe HTTP methods and using Spring Security’s CSRF protection, you must be sure to include a valid CSRF Token in the request. To specify a valid CSRF token as a request parameter use the CSRF RequestPostProcessor like so:spring-doc.cn
mvc
	.perform(post("/").with(csrf()))
mvc.post("/") {
    with(csrf())
If you like you can include CSRF token in the header instead:spring-doc.cn
mvc
	.perform(post("/").with(csrf().asHeader()))
mvc.post("/") {
You can also test providing an invalid CSRF token using the following:spring-doc.cn
mvc
	.perform(post("/").with(csrf().useInvalidToken()))
mvc.post("/") {
