For the latest stable version, please use Spring Security 6.4.1!spring-doc.cn
Authorized Client Features
Resolving an Authorized Client
The @RegisteredOAuth2AuthorizedClient annotation provides the capability of resolving a method parameter to an argument value of type OAuth2AuthorizedClient. This is a convenient alternative compared to accessing the OAuth2AuthorizedClient using the OAuth2AuthorizedClientManager or OAuth2AuthorizedClientService.spring-doc.cn
@Controller
	@GetMapping("/")
	public String index(@RegisteredOAuth2AuthorizedClient("okta") OAuth2AuthorizedClient authorizedClient) {
		OAuth2AccessToken accessToken = authorizedClient.getAccessToken();
		return "index";
@Controller
    @GetMapping("/")
    fun index(@RegisteredOAuth2AuthorizedClient("okta") authorizedClient: OAuth2AuthorizedClient): String {
        val accessToken = authorizedClient.accessToken
        return "index"
The @RegisteredOAuth2AuthorizedClient annotation is handled by OAuth2AuthorizedClientArgumentResolver, which directly uses an OAuth2AuthorizedClientManager and therefore inherits it’s capabilities.spring-doc.cn
WebClient integration for Servlet Environments
The OAuth 2.0 Client support integrates with WebClient using an ExchangeFilterFunction.spring-doc.cn
The ServletOAuth2AuthorizedClientExchangeFilterFunction provides a simple mechanism for requesting protected resources by using an OAuth2AuthorizedClient and including the associated OAuth2AccessToken as a Bearer Token. It directly uses an OAuth2AuthorizedClientManager and therefore inherits the following capabilities:spring-doc.cn
  • An OAuth2AccessToken will be requested if the client has not yet been authorized.spring-doc.cn
    • authorization_code - triggers the Authorization Request redirect to initiate the flowspring-doc.cn
    • client_credentials - the access token is obtained directly from the Token Endpointspring-doc.cn
    • password - the access token is obtained directly from the Token Endpointspring-doc.cn
  • If the OAuth2AccessToken is expired, it will be refreshed (or renewed) if an OAuth2AuthorizedClientProvider is available to perform the authorizationspring-doc.cn
The following code shows an example of how to configure WebClient with OAuth 2.0 Client support:spring-doc.cn
WebClient webClient(OAuth2AuthorizedClientManager authorizedClientManager) {
	ServletOAuth2AuthorizedClientExchangeFilterFunction oauth2Client =
			new ServletOAuth2AuthorizedClientExchangeFilterFunction(authorizedClientManager);
	return WebClient.builder()
			.apply(oauth2Client.oauth2Configuration())
fun webClient(authorizedClientManager: OAuth2AuthorizedClientManager?): WebClient {
    val oauth2Client = ServletOAuth2AuthorizedClientExchangeFilterFunction(authorizedClientManager)
            .build()
Providing the Authorized Client
The ServletOAuth2AuthorizedClientExchangeFilterFunction determines the client to use (for a request) by resolving the OAuth2AuthorizedClient from the ClientRequest.attributes() (request attributes).spring-doc.cn
The following code shows how to set an OAuth2AuthorizedClient as a request attribute:spring-doc.cn
@GetMapping("/")
	String resourceUri = ...
	String body = webClient
			.get()
			.uri(resourceUri)
			.attributes(oauth2AuthorizedClient(authorizedClient))   (1)
			.retrieve()
			.bodyToMono(String.class)
			.block();
	return "index";
@GetMapping("/")
    val resourceUri: String = ...
    val body: String = webClient
            .get()
            .uri(resourceUri)
            .retrieve()
            .bodyToMono()
            .block()
    return "index"
1 oauth2AuthorizedClient() is a static method in ServletOAuth2AuthorizedClientExchangeFilterFunction.
The following code shows how to set the ClientRegistration.getRegistrationId() as a request attribute:spring-doc.cn
@GetMapping("/")
public String index() {
			.get()
			.uri(resourceUri)
			.attributes(clientRegistrationId("okta"))   (1)
			.retrieve()
			.block();
	return "index";
@GetMapping("/")
fun index(): String {
            .get()
            .uri(resourceUri)
            .retrieve()
            .bodyToMono()
            .block()
    return "index"
1 clientRegistrationId() is a static method in ServletOAuth2AuthorizedClientExchangeFilterFunction.
Defaulting the Authorized Client
If neither OAuth2AuthorizedClient or ClientRegistration.getRegistrationId() is provided as a request attribute, the ServletOAuth2AuthorizedClientExchangeFilterFunction can determine the default client to use depending on it’s configuration.spring-doc.cn
If setDefaultOAuth2AuthorizedClient(true) is configured and the user has authenticated using HttpSecurity.oauth2Login(), the OAuth2AccessToken associated with the current OAuth2AuthenticationToken is used.spring-doc.cn
The following code shows the specific configuration:spring-doc.cn
	oauth2Client.setDefaultOAuth2AuthorizedClient(true);
            .build()
It is recommended to be cautious with this feature since all HTTP requests will receive the access token.
Alternatively, if setDefaultClientRegistrationId("okta") is configured with a valid ClientRegistration, the OAuth2AccessToken associated with the OAuth2AuthorizedClient is used.spring-doc.cn
	oauth2Client.setDefaultClientRegistrationId("okta");
            .build()
