For the latest stable version, please use Spring Security 6.4.1!spring-doc.cn
OAuth 2.0 Resource Server Opaque Token
Minimal Dependencies for Introspection
As described in Minimal Dependencies for JWT most of Resource Server support is collected in spring-security-oauth2-resource-server. However unless a custom ReactiveOpaqueTokenIntrospector is provided, the Resource Server will fallback to ReactiveOpaqueTokenIntrospector. Meaning that both spring-security-oauth2-resource-server and oauth2-oidc-sdk are necessary in order to have a working minimal Resource Server that supports opaque Bearer Tokens. Please refer to spring-security-oauth2-resource-server in order to determin the correct version for oauth2-oidc-sdk.spring-doc.cn
Minimal Configuration for Introspection
Typically, an opaque token can be verified via an OAuth 2.0 Introspection Endpoint, hosted by the authorization server. This can be handy when revocation is a requirement.spring-doc.cn
When using Spring Boot, configuring an application as a resource server that uses introspection consists of two basic steps. First, include the needed dependencies and second, indicate the introspection endpoint details.spring-doc.cn
Specifying the Authorization Server
To specify where the introspection endpoint is, simply do:spring-doc.cn
spring:
  security:
    oauth2:
      resourceserver:
        opaque-token:
          introspection-uri: https://idp.example.com/introspect
          client-id: client
          client-secret: secret
Where idp.example.com/introspect is the introspection endpoint hosted by your authorization server and client-id and client-secret are the credentials needed to hit that endpoint.spring-doc.cn
Resource Server will use these properties to further self-configure and subsequently validate incoming JWTs.spring-doc.cn
When using introspection, the authorization server’s word is the law. If the authorization server responses that the token is valid, then it is.
And that’s it!spring-doc.cn
Startup Expectations
When this property and these dependencies are used, Resource Server will automatically configure itself to validate Opaque Bearer Tokens.spring-doc.cn
This startup process is quite a bit simpler than for JWTs since no endpoints need to be discovered and no additional validation rules get added.spring-doc.cn
Runtime Expectations
Once the application is started up, Resource Server will attempt to process any request containing an Authorization: Bearer header:spring-doc.cn
GET / HTTP/1.1
Authorization: Bearer some-token-value # Resource Server will process this
So long as this scheme is indicated, Resource Server will attempt to process the request according to the Bearer Token specification.spring-doc.cn
Given an Opaque Token, Resource Server willspring-doc.cn
  1. Query the provided introspection endpoint using the provided credentials and the tokenspring-doc.cn
  2. Inspect the response for an { 'active' : true } attributespring-doc.cn
  3. Map each scope to an authority with the prefix SCOPE_spring-doc.cn
The resulting Authentication#getPrincipal, by default, is a Spring Security OAuth2AuthenticatedPrincipal object, and Authentication#getName maps to the token’s sub property, if one is present.spring-doc.cn
From here, you may want to jump to:spring-doc.cn
Looking Up Attributes Post-Authentication
Once a token is authenticated, an instance of BearerTokenAuthentication is set in the SecurityContext.spring-doc.cn
This means that it’s available in @Controller methods when using @EnableWebFlux in your configuration:spring-doc.cn
@GetMapping("/foo")
public Mono<String> foo(BearerTokenAuthentication authentication) {
    return Mono.just(authentication.getTokenAttributes().get("sub") + " is the subject");
@GetMapping("/foo")
fun foo(authentication: BearerTokenAuthentication): Mono<String> {
    return Mono.just(authentication.tokenAttributes["sub"].toString() + " is the subject")
Since BearerTokenAuthentication holds an OAuth2AuthenticatedPrincipal, that also means that it’s available to controller methods, too:spring-doc.cn
@GetMapping("/foo")
public Mono<String> foo(@AuthenticationPrincipal OAuth2AuthenticatedPrincipal principal) {
    return Mono.just(principal.getAttribute("sub") + " is the subject");
@GetMapping("/foo")
fun foo(@AuthenticationPrincipal principal: OAuth2AuthenticatedPrincipal): Mono<String> {
    return Mono.just(principal.getAttribute<Any>("sub").toString() + " is the subject")
Looking Up Attributes Via SpEL
Of course, this also means that attributes can be accessed via SpEL.spring-doc.cn
For example, if using @EnableReactiveMethodSecurity so that you can use @PreAuthorize annotations, you can do:spring-doc.cn
@PreAuthorize("principal?.attributes['sub'] = 'foo'")
public Mono<String> forFoosEyesOnly() {
    return Mono.just("foo");
@PreAuthorize("principal.attributes['sub'] = 'foo'")
fun forFoosEyesOnly(): Mono<String> {
Overriding or Replacing Boot Auto Configuration
There are two @Beans that Spring Boot generates on Resource Server’s behalf.spring-doc.cn
The first is a SecurityWebFilterChain that configures the app as a resource server. When use Opaque Token, this SecurityWebFilterChain looks like:spring-doc.cn
SecurityWebFilterChain springSecurityFilterChain(ServerHttpSecurity http) {
	http
		.authorizeExchange(exchanges -> exchanges
		.oauth2ResourceServer(ServerHttpSecurity.OAuth2ResourceServerSpec::opaqueToken)
	return http.build();
fun springSecurityFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
    return http {
        authorizeExchange {
        oauth2ResourceServer {
            opaqueToken { }
If the application doesn’t expose a SecurityWebFilterChain bean, then Spring Boot will expose the above default one.spring-doc.cn
Replacing this is as simple as exposing the bean within the application:spring-doc.cn
Replacing SecurityWebFilterChain
@EnableWebFluxSecurity
public class MyCustomSecurityConfiguration {
        http
                .pathMatchers("/messages/**").hasAuthority("SCOPE_message:read")
            .oauth2ResourceServer(oauth2 -> oauth2
                .opaqueToken(opaqueToken -> opaqueToken
                    .introspector(myIntrospector())
    return http {
        authorizeExchange {
            authorize("/messages/**", hasAuthority("SCOPE_message:read"))
            opaqueToken {
                introspector = myIntrospector()
The above requires the scope of message:read for any URL that starts with /messages/.spring-doc.cn
Methods on the oauth2ResourceServer DSL will also override or replace auto configuration.spring-doc.cn
For example, the second @Bean Spring Boot creates is a ReactiveOpaqueTokenIntrospector, which decodes String tokens into validated instances of OAuth2AuthenticatedPrincipal:spring-doc.cn
public ReactiveOpaqueTokenIntrospector introspector() {
    return new NimbusReactiveOpaqueTokenIntrospector(introspectionUri, clientId, clientSecret);
fun introspector(): ReactiveOpaqueTokenIntrospector {
    return NimbusReactiveOpaqueTokenIntrospector(introspectionUri, clientId, clientSecret)
If the application doesn’t expose a ReactiveOpaqueTokenIntrospector bean, then Spring Boot will expose the above default one.spring-doc.cn
And its configuration can be overridden using introspectionUri() and introspectionClientCredentials() or replaced using introspector().spring-doc.cn
Using introspectionUri()
An authorization server’s Introspection Uri can be configured as a configuration property or it can be supplied in the DSL:spring-doc.cn
public class DirectlyConfiguredIntrospectionUri {
        http
                    .introspectionUri("https://idp.example.com/introspect")
                    .introspectionClientCredentials("client", "secret")
    return http {
        authorizeExchange {
            opaqueToken {
                introspectionUri = "https://idp.example.com/introspect"
Using introspectionUri() takes precedence over any configuration property.spring-doc.cn
Using introspector()
More powerful than introspectionUri() is introspector(), which will completely replace any Boot auto configuration of ReactiveOpaqueTokenIntrospector:spring-doc.cn
public class DirectlyConfiguredIntrospector {
        http
                    .introspector(myCustomIntrospector())
    return http {
        authorizeExchange {
            opaqueToken {
                introspector = myCustomIntrospector()
This is handy when deeper configuration, like authority mappingor JWT revocation is necessary.spring-doc.cn
Exposing a ReactiveOpaqueTokenIntrospector @Bean
Or, exposing a ReactiveOpaqueTokenIntrospector @Bean has the same effect as introspector():spring-doc.cn
Configuring Authorization
An OAuth 2.0 Introspection endpoint will typically return a scope attribute, indicating the scopes (or authorities) it’s been granted, for example:spring-doc.cn
{ …​, "scope" : "messages contacts"}spring-doc.cn
When this is the case, Resource Server will attempt to coerce these scopes into a list of granted authorities, prefixing each scope with the string "SCOPE_".spring-doc.cn
This means that to protect an endpoint or method with a scope derived from an Opaque Token, the corresponding expressions should include this prefix:spring-doc.cn
public class MappedAuthorities {
        http
            .authorizeExchange(exchange -> exchange
                .pathMatchers("/contacts/**").hasAuthority("SCOPE_contacts")
                .pathMatchers("/messages/**").hasAuthority("SCOPE_messages")
            .oauth2ResourceServer(ServerHttpSecurity.OAuth2ResourceServerSpec::opaqueToken);
    return http {
        authorizeExchange {
            authorize("/contacts/**", hasAuthority("SCOPE_contacts"))
            authorize("/messages/**", hasAuthority("SCOPE_messages"))
            opaqueToken { }
Or similarly with method security:spring-doc.cn
@PreAuthorize("hasAuthority('SCOPE_messages')")
public Flux<Message> getMessages(...) {}
fun getMessages(): Flux<Message> { }
Extracting Authorities Manually
By default, Opaque Token support will extract the scope claim from an introspection response and parse it into individual GrantedAuthority instances.spring-doc.cn
For example, if the introspection response were:spring-doc.cn
    "active" : true,
    "scope" : "message:read message:write"
Then Resource Server would generate an Authentication with two authorities, one for message:read and the other for message:write.spring-doc.cn
This can, of course, be customized using a custom ReactiveOpaqueTokenIntrospector that takes a look at the attribute set and converts in its own way:spring-doc.cn
public class CustomAuthoritiesOpaqueTokenIntrospector implements ReactiveOpaqueTokenIntrospector {
    private ReactiveOpaqueTokenIntrospector delegate =
            new NimbusReactiveOpaqueTokenIntrospector("https://idp.example.org/introspect", "client", "secret");
    public Mono<OAuth2AuthenticatedPrincipal> introspect(String token) {
        return this.delegate.introspect(token)
                .map(principal -> new DefaultOAuth2AuthenticatedPrincipal(
                        principal.getName(), principal.getAttributes(), extractAuthorities(principal)));
    private Collection<GrantedAuthority> extractAuthorities(OAuth2AuthenticatedPrincipal principal) {
        List<String> scopes = principal.getAttribute(OAuth2IntrospectionClaimNames.SCOPE);
        return scopes.stream()
                .map(SimpleGrantedAuthority::new)
                .collect(Collectors.toList());
class CustomAuthoritiesOpaqueTokenIntrospector : ReactiveOpaqueTokenIntrospector {
    private val delegate: ReactiveOpaqueTokenIntrospector = NimbusReactiveOpaqueTokenIntrospector("https://idp.example.org/introspect", "client", "secret")
    override fun introspect(token: String): Mono<OAuth2AuthenticatedPrincipal> {
        return delegate.introspect(token)
                .map { principal: OAuth2AuthenticatedPrincipal ->
                            principal.name, principal.attributes, extractAuthorities(principal))
    private fun extractAuthorities(principal: OAuth2AuthenticatedPrincipal): Collection<GrantedAuthority> {
        val scopes = principal.getAttribute<List<String>>(OAuth2IntrospectionClaimNames.SCOPE)
        return scopes
                .map { SimpleGrantedAuthority(it) }
Thereafter, this custom introspector can be configured simply by exposing it as a @Bean:spring-doc.cn
    return new CustomAuthoritiesOpaqueTokenIntrospector();
    return CustomAuthoritiesOpaqueTokenIntrospector()
Using Introspection with JWTs
A common question is whether or not introspection is compatible with JWTs. Spring Security’s Opaque Token support has been designed to not care about the format of the token — it will gladly pass any token to the introspection endpoint provided.spring-doc.cn
So, let’s say that you’ve got a requirement that requires you to check with the authorization server on each request, in case the JWT has been revoked.spring-doc.cn
Even though you are using the JWT format for the token, your validation method is introspection, meaning you’d want to do:spring-doc.cn
spring:
  security:
    oauth2:
      resourceserver:
        opaque-token:
          introspection-uri: https://idp.example.org/introspection
          client-id: client
In this case, the resulting Authentication would be BearerTokenAuthentication. Any attributes in the corresponding OAuth2AuthenticatedPrincipal would be whatever was returned by the introspection endpoint.spring-doc.cn
But, let’s say that, oddly enough, the introspection endpoint only returns whether or not the token is active. Now what?spring-doc.cn
In this case, you can create a custom ReactiveOpaqueTokenIntrospector that still hits the endpoint, but then updates the returned principal to have the JWTs claims as the attributes:spring-doc.cn
public class JwtOpaqueTokenIntrospector implements ReactiveOpaqueTokenIntrospector {
	private ReactiveJwtDecoder jwtDecoder = new NimbusReactiveJwtDecoder(new ParseOnlyJWTProcessor());
				.flatMap(principal -> this.jwtDecoder.decode(token))
				.map(jwt -> new DefaultOAuth2AuthenticatedPrincipal(jwt.getClaims(), NO_AUTHORITIES));
	private static class ParseOnlyJWTProcessor implements Converter<JWT, Mono<JWTClaimsSet>> {
		public Mono<JWTClaimsSet> convert(JWT jwt) {
			try {
				return Mono.just(jwt.getJWTClaimsSet());
			} catch (Exception ex) {
				return Mono.error(ex);
class JwtOpaqueTokenIntrospector : ReactiveOpaqueTokenIntrospector {
    private val jwtDecoder: ReactiveJwtDecoder = NimbusReactiveJwtDecoder(ParseOnlyJWTProcessor())
                .flatMap { jwtDecoder.decode(token) }
                .map { jwt: Jwt -> DefaultOAuth2AuthenticatedPrincipal(jwt.claims, NO_AUTHORITIES) }
    private class ParseOnlyJWTProcessor : Converter<JWT, Mono<JWTClaimsSet>> {
        override fun convert(jwt: JWT): Mono<JWTClaimsSet> {
            return try {
                Mono.just(jwt.jwtClaimsSet)
            } catch (e: Exception) {
                Mono.error(e)
    return new JwtOpaqueTokenIntropsector();
    return JwtOpaqueTokenIntrospector()
Calling a /userinfo Endpoint
Generally speaking, a Resource Server doesn’t care about the underlying user, but instead about the authorities that have been granted.spring-doc.cn
That said, at times it can be valuable to tie the authorization statement back to a user.spring-doc.cn
If an application is also using spring-security-oauth2-client, having set up the appropriate ClientRegistrationRepository, then this is quite simple with a custom OpaqueTokenIntrospector. This implementation below does three things:spring-doc.cn
  • Delegates to the introspection endpoint, to affirm the token’s validityspring-doc.cn
  • Looks up the appropriate client registration associated with the /userinfo endpointspring-doc.cn
  • Invokes and returns the response from the /userinfo endpointspring-doc.cn
public class UserInfoOpaqueTokenIntrospector implements ReactiveOpaqueTokenIntrospector {
	private final ReactiveOpaqueTokenIntrospector delegate =
	private final ReactiveOAuth2UserService<OAuth2UserRequest, OAuth2User> oauth2UserService =
			new DefaultReactiveOAuth2UserService();
	private final ReactiveClientRegistrationRepository repository;
	// ... constructor
		return Mono.zip(this.delegate.introspect(token), this.repository.findByRegistrationId("registration-id"))
				.map(t -> {
					OAuth2AuthenticatedPrincipal authorized = t.getT1();
					ClientRegistration clientRegistration = t.getT2();
					Instant issuedAt = authorized.getAttribute(ISSUED_AT);
					Instant expiresAt = authorized.getAttribute(OAuth2IntrospectionClaimNames.EXPIRES_AT);
					OAuth2AccessToken accessToken = new OAuth2AccessToken(BEARER, token, issuedAt, expiresAt);
					return new OAuth2UserRequest(clientRegistration, accessToken);
				.flatMap(this.oauth2UserService::loadUser);
class UserInfoOpaqueTokenIntrospector : ReactiveOpaqueTokenIntrospector {
    private val oauth2UserService: ReactiveOAuth2UserService<OAuth2UserRequest, OAuth2User> = DefaultReactiveOAuth2UserService()
    private val repository: ReactiveClientRegistrationRepository? = null
    // ... constructor
    override fun introspect(token: String?): Mono<OAuth2AuthenticatedPrincipal> {
        return Mono.zip<OAuth2AuthenticatedPrincipal, ClientRegistration>(delegate.introspect(token), repository!!.findByRegistrationId("registration-id"))
                .map<OAuth2UserRequest> { t: Tuple2<OAuth2AuthenticatedPrincipal, ClientRegistration> ->
                    val authorized = t.t1
                    val clientRegistration = t.t2
                    val issuedAt: Instant? = authorized.getAttribute(ISSUED_AT)
                    val expiresAt: Instant? = authorized.getAttribute(OAuth2IntrospectionClaimNames.EXPIRES_AT)
                    val accessToken = OAuth2AccessToken(BEARER, token, issuedAt, expiresAt)
                .flatMap { userRequest: OAuth2UserRequest -> oauth2UserService.loadUser(userRequest) }
If you aren’t using spring-security-oauth2-client, it’s still quite simple. You will simply need to invoke the /userinfo with your own instance of WebClient:spring-doc.cn
    private final WebClient rest = WebClient.create();
		        .map(this::makeUserInfoRequest);
    private val rest: WebClient = WebClient.create()
Either way, having created your ReactiveOpaqueTokenIntrospector, you should publish it as a @Bean to override the defaults:spring-doc.cn
    return new UserInfoOpaqueTokenIntrospector();
    return UserInfoOpaqueTokenIntrospector()
