This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0!spring-doc.cn
Inbound Channel Adapters: Controlling Remote File Fetching
You should consider two properties when configuring inbound channel adapters. max-messages-per-poll, as with all pollers, can be used to limit the number of messages emitted on each poll (if more than the configured value are ready). max-fetch-size (since version 5.0) can limit the number of files retrieved from the remote server at a time.spring-doc.cn
The following scenarios assume the starting state is an empty local directory:spring-doc.cn
  • max-messages-per-poll=2 and max-fetch-size=1: The adapter fetches one file, emits it, fetches the next file, and emit it. Then it sleeps until the next poll.spring-doc.cn
  • max-messages-per-poll=2 and max-fetch-size=2): The adapter fetch both files and then emits each one.spring-doc.cn
  • max-messages-per-poll=2 and max-fetch-size=4: The adapter fetches up to 4 files (if available) and emits the first two (if there are at least two). The next two files will be emitted on the next poll.spring-doc.cn
  • max-messages-per-poll=2 and max-fetch-size not specified: The adapter fetches all remote files and emits the first two (if there are at least two). The subsequent files are emitted on subsequent polls (two at a time). When all are consumed, the remote fetch is attempted again, to pick up any new files.spring-doc.cn
When you deploy multiple instances of an application, we recommend setting a small max-fetch-size, to avoid one instance “grabbing” all the files and starving other instances.
Another use for max-fetch-size is when you want to stop fetching remote files but continue to process files that have already been fetched. Setting the maxFetchSize property on the MessageSource (programmatically, via JMX, or via a control bus) effectively stops the adapter from fetching more files but lets the poller continue to emit messages for files that have previously been fetched. If the poller is active when the property is changed, the change takes effect on the next poll.spring-doc.cn
Starting with version 5.1, the synchronizer can be provided with a Comparator<?>. This is useful when restricting the number of files fetched with maxFetchSize.spring-doc.cn
Starting with version 6.4, the AbstractRemoteFileStreamingMessageSource has now a convenient clearFetchedCache() API to remove references from cache for not processed remote files. The references stay in cache because polling configuration does not allow to process all of them in one cycle, and the target SessionFactory might be changed between polling cycles, e.g. via RotatingServerAdvice.spring-doc.cn
Also see general SFTP Inbound Channel Adapter chapter for information about FileListFilter configuration.spring-doc.cn
