This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Channel Adapter
A channel adapter is a message endpoint that enables connecting a single sender or receiver to a message channel. Spring Integration provides a number of adapters to support various transports, such as JMS, file, HTTP, web services, mail, and more. Upcoming chapters of this reference guide discuss each adapter. However, this chapter focuses on the simple but flexible method-invoking channel adapter support. There are both inbound and outbound adapters, and each may be configured with XML elements provided in the core namespace. These provide an easy way to extend Spring Integration, as long as you have a method that can be invoked as either a source or a destination.
Configuring An Inbound Channel Adapter
An inbound-channel-adapter
element (a SourcePollingChannelAdapter
in Java configuration) can invoke any method on a Spring-managed object and send a non-null return value to a MessageChannel
after converting the method’s output to a Message
When the adapter’s subscription is activated, a poller tries to receive messages from the source.
The poller is scheduled with the TaskScheduler
according to the provided configuration.
To configure the polling interval or cron expression for an individual channel adapter, you can provide a 'poller' element with one of the scheduling attributes, such as 'fixed-rate' or 'cron'.
The following example defines two inbound-channel-adapter
instances:
Java DSL
Java
Kotlin DSL
XML
public IntegrationFlow source1() {
return IntegrationFlow.from(() -> new GenericMessage<>(...),
e -> e.poller(p -> p.fixedRate(5000)))
.get();
public IntegrationFlow source2() {
e -> e.poller(p -> p.cron("30 * 9-17 * * MON-FRI")))
.get();
public class SourceService {
@InboundChannelAdapter(channel = "channel1", poller = @Poller(fixedRate = "5000"))
Object method1() {
@InboundChannelAdapter(channel = "channel2", poller = @Poller(cron = "30 * 9-17 * * MON-FRI"))
Object method2() {
fun messageSourceFlow() =
integrationFlow( { GenericMessage<>(...) },
{ poller { it.fixedRate(5000) } }) {
<int:inbound-channel-adapter ref="source1" method="method1" channel="channel1">
<int:poller fixed-rate="5000"/>
</int:inbound-channel-adapter>
<int:inbound-channel-adapter ref="source2" method="method2" channel="channel2">
<int:poller cron="30 * 9-17 * * MON-FRI"/>
</int:channel-adapter>
See also Channel Adapter Expressions and Scripts.
If no poller is provided, then a single default poller must be registered within the context. See Endpoint Namespace Support for more detail. |
The default trigger for polling endpoint is a PeriodicTrigger instance with a 1 second fixed delay period.
Important: Poller Configuration
All the
In the first configuration, the polling task is invoked once per poll, and, during each task (poll), the method (which results in the production of the message) is invoked once, based on the
Note that there is no However, in the However, if you are sure that your method can return null, and you need to poll for as many sources as available per each poll, you should explicitly set
Starting with version 5.5, a Starting with version 6.2, the Also see Global Default Poller for more information. |
Configuring An Outbound Channel Adapter
An outbound-channel-adapter
element (a @ServiceActivator
for Java configuration) can also connect a MessageChannel
to any POJO consumer method that should be invoked with the payload of messages sent to that channel.
The following example shows how to define an outbound channel adapter:
Java DSL
Java
Kotlin DSL
XML
public IntegrationFlow outboundChannelAdapterFlow(MyPojo myPojo) {
return f -> f
.handle(myPojo, "handle");
public class MyPojo {
@ServiceActivator(channel = "channel1")
void handle(Object payload) {
fun outboundChannelAdapterFlow(myPojo: MyPojo) =
integrationFlow {
<int:outbound-channel-adapter channel="channel1" ref="target" method="handle"/>
<beans:bean id="target" class="org.MyPojo"/>
If the channel being adapted is a PollableChannel
, you must provide a poller sub-element (the @Poller
sub-annotation on the @ServiceActivator
), as the following example shows:
Java
XML
@ServiceActivator(channel = "channel1", poller = @Poller(fixedRate = "3000"))
<int:outbound-channel-adapter channel="channel2" ref="target" method="handle">
<int:poller fixed-rate="3000" />
</int:outbound-channel-adapter>
You should use a ref
attribute if the POJO consumer implementation can be reused in other <outbound-channel-adapter>
definitions.
However, if the consumer implementation is referenced by only a single definition of the <outbound-channel-adapter>
, you can define it as an inner bean, as the following example shows:
<int:outbound-channel-adapter channel="channel" method="handle">
<beans:bean class="org.Foo"/>
Using both the ref attribute and an inner handler definition in the same <outbound-channel-adapter> configuration is not allowed, as it creates an ambiguous condition.
Such a configuration results in an exception being thrown.
Any channel adapter can be created without a channel
reference, in which case it implicitly creates an instance of DirectChannel
The created channel’s name matches the id
attribute of the <inbound-channel-adapter>
or <outbound-channel-adapter>
element.
Therefore, if channel
is not provided, id
is required.
Like many other Spring Integration components, the <inbound-channel-adapter>
and <outbound-channel-adapter>
also provide support for SpEL expression evaluation.
To use SpEL, provide the expression string in the 'expression' attribute instead of providing the 'ref' and 'method' attributes that are used for method-invocation on a bean.
When an expression is evaluated, it follows the same contract as method-invocation where: the expression for an <inbound-channel-adapter>
generates a message any time the evaluation result is a non-null value, while the expression for an <outbound-channel-adapter>
must be the equivalent of a void-returning method invocation.
Starting with Spring Integration 3.0, an <int:inbound-channel-adapter/>
can also be configured with a SpEL <expression/>
(or even with a <script/>
) sub-element, for when more sophistication is required than can be achieved with the simple 'expression' attribute.
If you provide a script as a Resource
by using the location
attribute, you can also set refresh-check-delay
, which allows the resource to be periodically refreshed.
If you want the script to be checked on each poll, you would need to coordinate this setting with the poller’s trigger, as the following example shows:
<int:poller max-messages-per-poll="1" fixed-delay="5000"/>
<script:script lang="ruby" location="Foo.rb" refresh-check-delay="5000"/>
See also the cacheSeconds
property on the ReloadableResourceBundleExpressionSource
when using the <expression/>
sub-element.
For more information regarding expressions, see Spring Expression Language (SpEL).
For scripts, see Groovy support and Scripting Support.
The <int:inbound-channel-adapter/> (SourcePollingChannelAdapter ) is an endpoint which starts a message flow by periodically triggering to poll some underlying MessageSource .
Since, at the time of polling, there is no message object, expressions and scripts do not have access to a root Message , so there are no payload or headers properties that are available in most other messaging SpEL expressions.
The script can generate and return a complete Message object with headers and payload or only a payload, which is added to a message with basic headers by the framework.
