This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0!spring-doc.cn
SFTP Session Factory
As of version 3.0, sessions are no longer cached by default. See SFTP Session Caching.
Before configuring SFTP adapters, you must configure an SFTP session factory. You can configure the SFTP session factory with a regular bean definition, as the following example shows:spring-doc.cn
<beans:bean id="sftpSessionFactory"
    class="org.springframework.integration.sftp.session.DefaultSftpSessionFactory">
    <beans:property name="host" value="localhost"/>
    <beans:property name="privateKey" value="classpath:META-INF/keys/sftpTest"/>
    <beans:property name="privateKeyPassphrase" value="springIntegration"/>
    <beans:property name="port" value="22"/>
    <beans:property name="user" value="kermit"/>
</beans:bean>
Every time an adapter requests a session object from its SessionFactory, a new SFTP session is created. Under the covers, the SFTP Session Factory relies on the Apache MINA SSHD library to provide the SFTP capabilities.spring-doc.cn
However, Spring Integration also supports the caching of SFTP sessions. See SFTP Session Caching for more information.spring-doc.cn
The DefaultSftpSessionFactory can use an externally configured or extended SshClient. For example, the org.eclipse.jgit.internal.transport.sshd.JGitSshClient extension from the org.eclipse.jgit:org.eclipse.jgit.ssh.apache library may be used to provide support for HTTP/SOCKS proxies.
The SshClient supports multiple channels (operations) over a connection to the server. By default, the Spring Integration session factory uses a separate physical connection for each channel. Since Spring Integration 3.0, you can configure the session factory (using a boolean constructor arg - default false) to use a single connection to the server and create multiple SftpClient instances on that single connection.spring-doc.cn
When using this feature, you must wrap the session factory in a caching session factory, as described later, so that the connection is not physically closed when an operation completes.spring-doc.cn
If the cache is reset, the session is disconnected only when the last channel is closed.spring-doc.cn
The connection is refreshed if it to be disconnected when a new operation obtains a session.spring-doc.cn
Now all you need to do is inject this SFTP session factory into your adapters.spring-doc.cn
A more practical way to provide values for the SFTP session factory is to use Spring’s property placeholder support.
Starting with version 6.1.3, the DefaultSftpSessionFactory introduces a createSftpClient(…​) to support a custom SftpClient. See a sample below of how to override createSftpChannelSubsystem() method in your custom SftpClient to add, for example, some custom RequestHandler for SFTP sub-system requests and replies:spring-doc.cn
protected ChannelSubsystem createSftpChannelSubsystem(ClientSession clientSession) {
    ChannelSubsystem sftpChannelSubsystem = super.createSftpChannelSubsystem(clientSession);
    sftpChannelSubsystem.addRequestHandler((channel, request, wantReply, buffer) -> ...);
    return sftpChannelSubsystem;
Configuration Properties
The following list describes all the properties that are exposed by the DefaultSftpSessionFactory.spring-doc.cn
isSharedSession (constructor argument)::When true, a single SftpClient is used for all the requested SftpSession instances. It defaults to false.spring-doc.cn
sftpVersionSelector::An SftpVersionSelector instance for SFTP protocol selection. The default one is SftpVersionSelector.CURRENT.spring-doc.cn
host::The URL of the host to which to connect. Required.spring-doc.cn
hostConfig::An org.apache.sshd.client.config.hosts.HostConfigEntry instance as an alternative for the user/host/port options. Can be configured with a proxy jump property.spring-doc.cn
port::The port over which the SFTP connection shall be established. If not specified, this value defaults to 22. If specified, this properties must be a positive number.spring-doc.cn
user::The remote user to use. Required.spring-doc.cn
knownHostsResource::An org.springframework.core.io.Resource that used for a host key repository. The content of the resource has to be the same format as OpenSSH known_hosts file and is required and must be pre-populated if allowUnknownKeys is false.spring-doc.cn
password::The password to authenticate against the remote host. If a password is not provided, then the privateKey property is required.spring-doc.cn
privateKey::An org.springframework.core.io.Resource that represents the location of the private key used for authenticating against the remote host. If the privateKey is not provided, then the password property is required.spring-doc.cn
privateKeyPassphrase::The password for the private key. If you set userInfo, privateKeyPassphrase is not allowed . The passphrase is obtained from that object. Optional.spring-doc.cn
timeout::The timeout property is used as the socket timeout parameter, as well as the default connection timeout. Defaults to 30 seconds. Setting to 0 means no timeout; to null - infinite wait.spring-doc.cn
allowUnknownKeys::Set to true to allow connections to hosts with unknown (or changed) keys. Its default is 'false'. If false, a pre-populated knownHosts file is required.spring-doc.cn
userInteraction::A custom org.apache.sshd.client.auth.keyboard.UserInteraction to be used during authentication.spring-doc.cn
Starting with version 6.4, the DefaultSftpSessionFactory expose a Consumer<SshClient> configurer property to further customize an internal SshClient. For example, this is how to change a default number of NIO workers and packet size for the client:spring-doc.cn
sftpSessionFactory.setSshClientConfigurer((sshClient) -> {
    sshClient.setNioWorkers(27);
    PropertyResolverUtils.updateProperty(sshClient, CoreModuleProperties.MAX_PACKET_SIZE.getName(), 48 * 1024);
