This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Polled Inbound Channel Adapter
Overview
Version 5.0.1 introduced a polled channel adapter, letting you fetch individual messages on demand — for example, with a MessageSourcePollingTemplate
or a poller.
See Deferred Acknowledgment Pollable Message Source for more information.
It does not currently support XML configuration.
The following example shows how to configure an AmqpMessageSource
Java DSL
Java
public IntegrationFlow flow() {
return IntegrationFlow.from(Amqp.inboundPolledAdapter(connectionFactory(), DSL_QUEUE),
e -> e.poller(Pollers.fixedDelay(1_000)).autoStartup(false))
.handle(p -> {
.get();
public AmqpMessageSource source(ConnectionFactory connectionFactory) {
return new AmqpMessageSource(connectionFactory, "someQueue");
See the Javadoc for configuration properties.
XML
This adapter currently does not have XML configuration support.
Batched Messages
See Batched Messages.
For the polled adapter, there is no listener container, batched messages are always debatched (if the BatchingStrategy
supports doing so).
