This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0!spring-doc.cn
Overview
Routers are a crucial element in many messaging architectures. They consume messages from a message channel and forward each consumed message to one or more different message channels depending on a set of conditions.spring-doc.cn
Spring Integration provides the following routers:spring-doc.cn
Router implementations share many configuration parameters. However, certain differences exist between routers. Furthermore, the availability of configuration parameters depends on whether routers are used inside or outside a chain. In order to provide a quick overview, all available attributes are listed in the two following tables .spring-doc.cn
The following table shows the configuration parameters available for a router outside a chain:spring-doc.cn
Table 1. Routers Outside a Chain
Attribute router header value router xpath router payload type router recipient list route exception type router
apply-sequencespring-doc.cn
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
default-output-channelspring-doc.cn
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
resolution-requiredspring-doc.cn
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
ignore-send-failuresspring-doc.cn
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
timeoutspring-doc.cn
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
idspring-doc.cn
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
auto-startupspring-doc.cn
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
input-channelspring-doc.cn
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
orderspring-doc.cn
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
methodspring-doc.cn
tickmark
refspring-doc.cn
tickmark
expressionspring-doc.cn
tickmark
header-namespring-doc.cn
tickmark
evaluate-as-stringspring-doc.cn
tickmark
xpath-expression-refspring-doc.cn
tickmark
converterspring-doc.cn
tickmark
The following table shows the configuration parameters available for a router inside a chain:spring-doc.cn
Table 2. Routers Inside a Chain
Attribute router header value router xpath router payload type router recipient list router exception type router
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
idspring-doc.cn
orderspring-doc.cn
methodspring-doc.cn
tickmark
refspring-doc.cn
tickmark
tickmark
tickmark
tickmark
tickmark
tickmark
As of Spring Integration 2.1, router parameters have been more standardized across all router implementations. Consequently, a few minor changes may break older Spring Integration based applications.spring-doc.cn
Since Spring Integration 2.1, the ignore-channel-name-resolution-failures attribute is removed in favor of consolidating its behavior with the resolution-required attribute. Also, the resolution-required attribute now defaults to true.spring-doc.cn
Prior to these changes, the resolution-required attribute defaulted to false, causing messages to be silently dropped when no channel was resolved and no default-output-channel was set. The new behavior requires at least one resolved channel and, by default, throws a MessageDeliveryException if no channel was determined (or an attempt to send was not successful).spring-doc.cn
If you do desire to drop messages silently, you can set default-output-channel="nullChannel".spring-doc.cn
