This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Content Enricher
At times, you may have a requirement to enhance a request with more information than was provided by the target system. The data enricher pattern describes various scenarios as well as the component (Enricher) that lets you address such requirements.
The Spring Integration Core
module includes two enrichers:
It also includes three adapter-specific header enrichers:
See the adapter-specific sections of this reference manual to learn more about those adapters.
For more information regarding expressions support, see Spring Expression Language (SpEL).
Header Enricher
If you need do nothing more than add headers to a message and the headers are not dynamically determined by the message content, referencing a custom implementation of a transformer may be overkill.
For that reason, Spring Integration provides support for the header enricher pattern.
It is exposed through the <header-enricher>
element.
The following example shows how to use it:
<int:header-enricher input-channel="in" output-channel="out">
<int:header name="foo" value="123"/>
<int:header name="bar" ref="someBean"/>
</int:header-enricher>
The header enricher also provides helpful sub-elements to set well known header names, as the following example shows:
<int:error-channel ref="applicationErrorChannel"/>
<int:reply-channel ref="quoteReplyChannel"/>
<int:correlation-id value="123"/>
<int:priority value="HIGHEST"/>
<routing-slip value="channel1; routingSlipRoutingStrategy; request.headers[myRoutingSlipChannel]"/>
The preceding configuration shows that, for well known headers (such as errorChannel
, correlationId
, priority
, replyChannel
, routing-slip
, and others), instead of using generic <header>
sub-elements where you would have to provide both header 'name' and 'value', you can use convenient sub-elements to set those values directly.
Starting with version 4.1, the header enricher provides a routing-slip
sub-element.
See Routing Slip for more information.
POJO Support
Often, a header value cannot be defined statically and has to be determined dynamically based on some content in the message.
That is why the header enricher lets you also specify a bean reference by using the ref
and method
attributes.
The specified method calculates the header value.
Consider the following configuration and a bean with a method that modifies a String
<int:header name="something" method="computeValue" ref="myBean"/>
<bean id="myBean" class="thing1.thing2.MyBean"/>
public class MyBean {
public String computeValue(String payload){
return payload.toUpperCase() + "_US";
You can also configure your POJO as an inner bean, as the following example shows:
<int:header-enricher input-channel="inputChannel" output-channel="outputChannel">
<int:header name="some_header">
<bean class="org.MyEnricher"/>
</int:header>
You can similarly point to a Groovy script, as the following example shows:
<int-groovy:script location="org/SampleGroovyHeaderEnricher.groovy"/>
</int:header>
SpEL Support
In Spring Integration 2.0, we introduced the convenience of the Spring Expression Language (SpEL) to help configure many different components. The header enricher is one of them. Look again at the POJO example shown earlier. You can see that the computation logic to determine the header value is pretty simple. A natural question would be: "Is there an even simpler way to accomplish this?". That is where SpEL shows its true power. Consider the following example:
<int:header name="foo" expression="payload.toUpperCase() + '_US'"/>
By using SpEL for such simple cases, you no longer have to provide a separate class and configure it in the application context.
All you need do is configured the expression
attribute with a valid SpEL expression.
The 'payload' and 'headers' variables are bound to the SpEL evaluation context, giving you full access to the incoming message.
Configuring a Header Enricher with Java Configuration
The following two examples show how to use Java Configuration for header enrichers:
@Transformer(inputChannel = "enrichHeadersChannel", outputChannel = "emailChannel")
public HeaderEnricher enrichHeaders() {
Map<String, ? extends HeaderValueMessageProcessor<?>> headersToAdd =
Collections.singletonMap("emailUrl",
new StaticHeaderValueMessageProcessor<>(this.imapUrl));
HeaderEnricher enricher = new HeaderEnricher(headersToAdd);
return enricher;
@Transformer(inputChannel="enrichHeadersChannel", outputChannel="emailChannel")
Map<String, HeaderValueMessageProcessor<?>> headersToAdd = new HashMap<>();
headersToAdd.put("emailUrl", new StaticHeaderValueMessageProcessor<String>(this.imapUrl));
Expression expression = new SpelExpressionParser().parseExpression("payload.from[0].toString()");
headersToAdd.put("from",
new ExpressionEvaluatingHeaderValueMessageProcessor<>(expression, String.class));
return enricher;
The first example adds a single literal header. The second example adds two headers, a literal header and one based on a SpEL expression.
Configuring a Header Enricher with the Java DSL
The following example shows Java DSL Configuration for a header enricher:
public IntegrationFlow enrichHeadersInFlow() {
return f -> f
.enrichHeaders(h -> h.header("emailUrl", this.emailUrl)
.headerExpression("from", "payload.from[0].toString()"))
.handle(...);
Header Channel Registry
Starting with Spring Integration 3.0, a new sub-element <int:header-channels-to-string/>
is available.
It has no attributes.
This new sub-element converts existing replyChannel
and errorChannel
headers (when they are a MessageChannel
) to a String
and stores the channels in a registry for later resolution, when it is time to send a reply or handle an error.
This is useful for cases where the headers might be lost — for example, when serializing a message into a message store or when transporting the message over JMS.
If the header does not already exist, or it is not a MessageChannel
, no changes are made.
Using this functionality requires the presence of a HeaderChannelRegistry
bean.
By default, the framework creates a DefaultHeaderChannelRegistry
with the default expiry (60 seconds).
Channels are removed from the registry after this time.
To change this behavior, define a bean with an id
of integrationHeaderChannelRegistry
and configure the required default delay by using a constructor argument (in milliseconds).
Since version 4.1, you can set a property called removeOnGet
to true
on the <bean/>
definition, and the mapping entry is removed immediately on first use.
This might be useful in a high-volume environment and when the channel is only used once, rather than waiting for the reaper to remove it.
The HeaderChannelRegistry
has a size()
method to determine the current size of the registry.
The runReaper()
method cancels the current scheduled task and runs the reaper immediately.
The task is then scheduled to run again based on the current delay.
These methods can be invoked directly by getting a reference to the registry, or you can send a message with, for example, the following content to a control bus:
"integrationHeaderChannelRegistry.runReaper"
This sub-element is a convenience, and is the equivalent of specifying the following configuration:
<int:reply-channel
expression="@integrationHeaderChannelRegistry.channelToChannelName(headers.replyChannel)"
overwrite="true" />
<int:error-channel
expression="@integrationHeaderChannelRegistry.channelToChannelName(headers.errorChannel)"
overwrite="true" />
Starting with version 4.1, you can now override the registry’s configured reaper delay so that the channel mapping is retained for at least the specified time, regardless of the reaper delay. The following example shows how to do so:
<int:header-enricher input-channel="inputTtl" output-channel="next">
<int:header-channels-to-string time-to-live-expression="120000" />
<int:header-enricher input-channel="inputCustomTtl" output-channel="next">
time-to-live-expression="headers['channelTTL'] ?: 120000" />
In the first case, the time to live for every header channel mapping will be two minutes. In the second case, the time to live is specified in the message header and uses an Elvis operator to use two minutes if there is no header.
Payload Enricher
In certain situations, the header enricher, as discussed earlier, may not be sufficient and payloads themselves may have to be enriched with additional information. For example, order messages that enter the Spring Integration messaging system have to look up the order’s customer based on the provided customer number and then enrich the original payload with that information.
Spring Integration 2.1 introduced the payload enricher.
The payload enricher defines an endpoint that passes a Message
to the exposed request channel and then expects a reply message.
The reply message then becomes the root object for evaluation of expressions to enrich the target payload.
The payload enricher provides full XML namespace support through the enricher
element.
In order to send request messages, the payload enricher has a request-channel
attribute that lets you dispatch messages to a request channel.
Basically, by defining the request channel, the payload enricher acts as a gateway, waiting for the message sent to the request channel to return. The enricher then augments the message’s payload with the data provided by the reply message.
When sending messages to the request channel, you also have the option to send only a subset of the original payload by using the request-payload-expression
attribute.
The enriching of payloads is configured through SpEL expressions, providing a maximum degree of flexibility.
Therefore, you can not only enrich payloads with direct values from the reply channel’s Message
, but you can use SpEL expressions to extract a subset from that message or to apply additional inline transformations, letting you further manipulate the data.
If you need only to enrich payloads with static values, you need not provide the request-channel
attribute.
Enrichers are a variant of transformers. In many cases, you could use a payload enricher or a generic transformer implementation to add additional data to your message payloads. You should familiarize yourself with all transformation-capable components that are provided by Spring Integration and carefully select the implementation that semantically fits your business case best. |
Configuration
The following example shows all available configuration options for the payload enricher:
<int:enricher request-channel="" (1)
auto-startup="true" (2)
id="" (3)
order="" (4)
output-channel="" (5)
request-payload-expression="" (6)
reply-channel="" (7)
error-channel="" (8)
send-timeout="" (9)
should-clone-payload="false"> (10)
<int:poller></int:poller> (11)
<int:property name="" expression="" null-result-expression="'Could not determine the name'"/> (12)
<int:property name="" value="23" type="java.lang.Integer" null-result-expression="'0'"/>
<int:header name="" expression="" null-result-expression=""/> (13)
<int:header name="" value="" overwrite="" type="" null-result-expression=""/>
</int:enricher>
1 | Channel to which a message is sent to get the data to use for enrichment. Optional. |
2 | Lifecycle attribute signaling whether this component should be started during the application context startup. Defaults to true. Optional. |
3 | ID of the underlying bean definition, which is either an EventDrivenConsumer or a PollingConsumer .
Optional. |
4 | Specifies the order for invocation when this endpoint is connected as a subscriber to a channel. This is particularly relevant when that channel is using a “failover” dispatching strategy. It has no effect when this endpoint is itself a polling consumer for a channel with a queue. Optional. |
5 | Identifies the message channel where a message is sent after it is being processed by this endpoint. Optional. |
6 | By default, the original message’s payload is used as payload that is sent to the request-channel .
By specifying a SpEL expression as the value for the request-payload-expression attribute, you can use a subset of the original payload, a header value, or any other resolvable SpEL expression as the basis for the payload that is sent to the request-channel.
For the expression evaluation, the full message is available as the 'root object'.
For instance, the following SpEL expressions (among others) are possible: payload.something , headers.something , new java.util.Date() , 'thing1' + 'thing2' |
7 | Channel where a reply message is expected. This is optional. Typically, the auto-generated temporary reply channel suffices. Optional. |
8 | The channel to which an ErrorMessage is sent if an Exception occurs downstream of the request-channel .
This enables you to return an alternative object to use for enrichment.
If it is not set, an Exception is thrown to the caller.
Optional. |
9 | Maximum amount of time in milliseconds to wait when sending a message to the channel, if the channel might block.
For example, a queue channel can block until space is available, if its maximum capacity has been reached.
Internally, the send() timeout is set on the MessagingTemplate and ultimately applied when invoking the send operation on the MessageChannel .
By default, the send() timeout is set to '30'.
Optional. |
10 | Boolean value indicating whether any payload that implements Cloneable should be cloned prior to sending the message to the request channel for acquiring the enriching data.
The cloned version would be used as the target payload for the ultimate reply.
The default is false .
Optional. |
11 | Lets you configure a message poller if this endpoint is a polling consumer. Optional. |
12 | Each property sub-element provides the name of a property (through the mandatory name attribute).
That property should be settable on the target payload instance.
Exactly one of the value or expression attributes must be provided as well — the former for a literal value to set and the latter for a SpEL expression to be evaluated.
The root object of the evaluation context is the message that was returned from the flow initiated by this enricher — the input message if there is no request channel or the application context (using the @<beanName>.<beanProperty> SpEL syntax).
Starting with version 4.0, when specifying a value attribute, you can also specify an optional type attribute.
When the destination is a typed setter method, the framework coerces the value appropriately (as long as a PropertyEditor ) exists to handle the conversion.
If, however, the target payload is a Map , the entry is populated with the value without conversion.
The type attribute lets you, for example, convert a String containing a number to an Integer value in the target payload.
Starting with version 4.1, you can also specify an optional null-result-expression attribute.
When the enricher returns null, it is evaluated, and the output of the evaluation is returned instead. |
13 | Each header sub-element provides the name of a message header (through the mandatory name attribute).
Exactly one of the value or expression attributes must also be provided — the former for a literal value to set and the latter for a SpEL expression to be evaluated.
The root object of the evaluation context is the message that was returned from the flow initiated by this enricher — the input message if there is no request channel or the application context (using the '@<beanName>.<beanProperty>' SpEL syntax).
Note that, similarly to the <header-enricher> , the <enricher> element’s header element has type and overwrite attributes.
However, a key difference is that, with the <enricher> , the overwrite attribute is true by default, to be consistent with the <enricher> element’s <property> sub-element.
Examples
This section contains several examples of using a payload enricher in various situations.
The code samples shown here are part of the Spring Integration Samples project. See Spring Integration Samples. |
In the following example, a User
object is passed as the payload of the Message
<int:enricher id="findUserEnricher"
input-channel="findUserEnricherChannel"
request-channel="findUserServiceChannel">
<int:property name="email" expression="payload.email"/>
<int:property name="password" expression="payload.password"/>
</int:enricher>
The User
has several properties, but only the username
is set initially.
The enricher’s request-channel
attribute is configured to pass the User
to the findUserServiceChannel
Through the implicitly set reply-channel
, a User
object is returned and, by using the property
sub-element, properties from the reply are extracted and used to enrich the original payload.
How Do I Pass Only a Subset of Data to the Request Channel?
When using a request-payload-expression
attribute, a single property of the payload instead of the full message can be passed on to the request channel.
In the following example, the username property is passed on to the request channel:
<int:enricher id="findUserByUsernameEnricher"
input-channel="findUserByUsernameEnricherChannel"
request-channel="findUserByUsernameServiceChannel"
request-payload-expression="payload.username">
</int:enricher>
Keep in mind that, although only the username is passed, the resulting message to the request channel contains the full set of MessageHeaders
How Can I Enrich Payloads that Consist of Collection Data?
In the following example, instead of a User
object, a Map
is passed in:
<int:enricher id="findUserWithMapEnricher"
input-channel="findUserWithMapEnricherChannel"
<int:property name="user" expression="payload"/>
</int:enricher>
The Map
contains the username under the username
map key.
Only the username
is passed on to the request channel.
The reply contains a full User
object, which is ultimately added to the Map
under the user
key.
How Can I Enrich Payloads with Static Information without Using a Request Channel?
The following example does not use a request channel at all but solely enriches the message’s payload with static values:
<int:enricher id="userEnricher"
input-channel="input">
<int:property name="user.updateDate" expression="new java.util.Date()"/>
<int:property name="user.firstName" value="William"/>
<int:property name="user.lastName" value="Shakespeare"/>
<int:property name="user.age" value="42"/>
</int:enricher>
Note that the word, 'static', is used loosely here. You can still use SpEL expressions for setting those values.
