This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0!spring-doc.cn
Changes between 6.3 and 6.4
New Components
A BaseMessageBuilder class has been extracted from the MessageBuilder to simplify a custom builder implementation where the most of the logic should be the same as MessageBuilder one. See MessageBuilder for more information.spring-doc.cn
The new Control Bus interaction model is implemented in the ControlBusCommandRegistry. A new ControlBusFactoryBean class is recommended to be used instead of deprecated ExpressionControlBusFactoryBean. See Control Bus for more information.spring-doc.cn
Also, a ControlBusController (together with an @EnableControlBusController) is introduced for managing exposed commands by the mentioned ControlBusCommandRegistry. See HTTP Support for more information.spring-doc.cn
The SpEL evaluation infrastructure now supports configuration for IndexAccessor. Also, an out-of-the-box JsonIndexAccessor is provided. See SpEL Support for more information.spring-doc.cn
General Changes
The Java DSL SourcePollingChannelAdapterSpec can now be configured with a custom TaskSchedulerspring-doc.cn
Remote File Adapters Changes
The AbstractRemoteFileStreamingMessageSource has now a convenient clearFetchedCache() API to remove references from cache for not processed remote files. The references stay in cache because polling configuration does not allow to process all the fetched in one cycle, and the target SessionFactory might be changed between polling cycles, e.g. via RotatingServerAdvice.spring-doc.cn
JDBC Changes
The LobHandler (and respective API) has been deprecated for removal in Spring Framework 6.2. Respective option on JdbcMessageStore (and similar) have been deprecated as well. The byte array handling for serialized message is fully deferred to JDBC driver.spring-doc.cn
The LockRepository.delete() method return the result of removing ownership of a distributed lock. And the JdbcLockRegistry.JdbcLock.unlock() method throws ConcurrentModificationException if the ownership of the lock is expired. See JDBC Support for more information.spring-doc.cn
ZeroMQ Changes
The outbound component ZeroMqMessageHandler (and respective API) can now bind a TCP port instead of connecting to a given URL. See ZeroMQ Support for more information.spring-doc.cn
Redis Changes
Instead of throwing IllegalStateException, the RedisLockRegistry.RedisLock.unlock() method throws ConcurrentModificationException if the ownership of the lock is expired. Add a RedisLockRegistry.setRenewalTaskScheduler() to periodic lock renewal. See Redis Support for more information.spring-doc.cn
Groovy Changes
The ControlBusFactoryBean (and respective <int-groovy:control-bus> XML tag) has been deprecated (for removal) in favor of new introduced ControlBusFactoryBean based on a new model implemented in the ControlBusCommandRegistry. See Control Bus for more information.spring-doc.cn
SFTP Support Changes
The DefaultSftpSessionFactory now exposes a Consumer<SshClient> configurer property to further customize an internal SshClient. See SFTP Session Factory for more information.spring-doc.cn
MQTT Support Changes
Multiple instances of MqttPahoMessageDrivenChannelAdapter and Mqttv5PahoMessageDrivenChannelAdapter can now be added at runtime using corresponding ClientManager through IntegrationFlowContext Also a MqttMessageNotDeliveredEvent event has been introduced to emit when action callback reacts to the delivery failure. See MQTT Support for more information.spring-doc.cn
Zip Support Changes
The ZipTransformer now exposes a fileNameGenerator property to customize a target zip file (and optional zip entry) name generation. See Zip Support for more information.spring-doc.cn
Scripting Changes
The Python scripts evaluation is now migrated to the GraalVM Polyglot. See Scripting Support for more information.spring-doc.cn
Mail Changes
The AbstractMailReceiver exposes an option to disable setting Flags.Flag.FLAGGED into a received message as fallback flag. See Mail Support for more information.spring-doc.cn
