Matrix Variables
RFC 3986 discusses name-value pairs in path segments. In Spring MVC, we refer to those as “matrix variables” based on an “old post” by Tim Berners-Lee, but they can be also be referred to as URI path parameters.spring-doc.cn
Matrix variables can appear in any path segment, with each variable separated by a semicolon and multiple values separated by comma (for example, /cars;color=red,green;year=2012). Multiple values can also be specified through repeated variable names (for example, color=red;color=green;color=blue).spring-doc.cn
If a URL is expected to contain matrix variables, the request mapping for a controller method must use a URI variable to mask that variable content and ensure the request can be matched successfully independent of matrix variable order and presence. The following example uses a matrix variable:spring-doc.cn
// GET /pets/42;q=11;r=22
@GetMapping("/pets/{petId}")
public void findPet(@PathVariable String petId, @MatrixVariable int q) {
	// petId == 42
	// q == 11
fun findPet(@PathVariable petId: String, @MatrixVariable q: Int) {
	// petId == 42
	// q == 11
Given that all path segments may contain matrix variables, you may sometimes need to disambiguate which path variable the matrix variable is expected to be in. The following example shows how to do so:spring-doc.cn
// GET /owners/42;q=11/pets/21;q=22
@GetMapping("/owners/{ownerId}/pets/{petId}")
		@MatrixVariable(name="q", pathVar="ownerId") int q1,
		@MatrixVariable(name="q", pathVar="petId") int q2) {
	// q1 == 11
	// q2 == 22
fun findPet(
		@MatrixVariable(name = "q", pathVar = "ownerId") q1: Int,
		@MatrixVariable(name = "q", pathVar = "petId") q2: Int) {
	// q1 == 11
	// q2 == 22
A matrix variable may be defined as optional and a default value specified, as the following example shows:spring-doc.cn
// GET /pets/42
public void findPet(@MatrixVariable(required=false, defaultValue="1") int q) {
	// q == 1
// GET /pets/42
fun findPet(@MatrixVariable(required = false, defaultValue = "1") q: Int) {
	// q == 1
To get all matrix variables, you can use a MultiValueMap, as the following example shows:spring-doc.cn
// GET /owners/42;q=11;r=12/pets/21;q=22;s=23
		@MatrixVariable MultiValueMap<String, String> matrixVars,
		@MatrixVariable(pathVar="petId") MultiValueMap<String, String> petMatrixVars) {
	// matrixVars: ["q" : [11,22], "r" : 12, "s" : 23]
	// petMatrixVars: ["q" : 22, "s" : 23]
fun findPet(
		@MatrixVariable matrixVars: MultiValueMap<String, String>,
		@MatrixVariable(pathVar="petId") petMatrixVars: MultiValueMap<String, String>) {
Note that you need to enable the use of matrix variables. In the MVC Java configuration, you need to set a UrlPathHelper with removeSemicolonContent=false through Path Matching. In the MVC XML namespace, you can set <mvc:annotation-driven enable-matrix-variables="true"/>.spring-doc.cn
