This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.0! |
Context Hierarchy
DispatcherServlet
expects a WebApplicationContext
(an extension of a plain
ApplicationContext
) for its own configuration. WebApplicationContext
has a link to the
ServletContext
and the Servlet
with which it is associated. It is also bound to the ServletContext
such that applications can use static methods on RequestContextUtils
to look up the
if they need access to it.
For many applications, having a single WebApplicationContext
is simple and suffices.
It is also possible to have a context hierarchy where one root WebApplicationContext
is shared across multiple DispatcherServlet
(or other Servlet
) instances, each with
its own child WebApplicationContext
configuration.
See Additional Capabilities of the ApplicationContext
for more on the context hierarchy feature.
The root WebApplicationContext
typically contains infrastructure beans, such as data repositories and
business services that need to be shared across multiple Servlet
instances. Those beans
are effectively inherited and can be overridden (that is, re-declared) in the Servlet-specific
, which typically contains beans local to the given Servlet
The following image shows this relationship:
The following example configures a WebApplicationContext
hierarchy:
Java
Kotlin
public class MyWebAppInitializer extends AbstractAnnotationConfigDispatcherServletInitializer {
protected Class<?>[] getRootConfigClasses() {
return new Class<?>[] { RootConfig.class };
protected Class<?>[] getServletConfigClasses() {
return new Class<?>[] { App1Config.class };
protected String[] getServletMappings() {
return new String[] { "/app1/*" };
class MyWebAppInitializer : AbstractAnnotationConfigDispatcherServletInitializer() {
override fun getRootConfigClasses(): Array<Class<*>> {
return arrayOf(RootConfig::class.java)
override fun getServletConfigClasses(): Array<Class<*>> {
return arrayOf(App1Config::class.java)
override fun getServletMappings(): Array<String> {
return arrayOf("/app1/*")
If an application context hierarchy is not required, applications can return all
configuration through getRootConfigClasses() and null from getServletConfigClasses() .
The following example shows the web.xml
equivalent:
<web-app>
<listener>
<listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
</listener>
<context-param>
<param-name>contextConfigLocation</param-name>
<param-value>/WEB-INF/root-context.xml</param-value>
</context-param>
<servlet>
<servlet-name>app1</servlet-name>
<servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
<init-param>
<param-value>/WEB-INF/app1-context.xml</param-value>
</init-param>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>/app1/*</url-pattern>
</servlet-mapping>
</web-app>
If an application context hierarchy is not required, applications may configure a
“root” context only and leave the contextConfigLocation Servlet parameter empty.
