Ahead of Time Optimizations
This chapter covers Spring’s Ahead of Time (AOT) optimizations.spring-doc.cn
For AOT support specific to integration tests, see Ahead of Time Support for Tests.spring-doc.cn
Introduction to Ahead of Time Optimizations
Spring’s support for AOT optimizations is meant to inspect an ApplicationContext at build time and apply decisions and discovery logic that usually happens at runtime. Doing so allows building an application startup arrangement that is more straightforward and focused on a fixed set of features based mainly on the classpath and the Environment.spring-doc.cn
Applying such optimizations early implies the following restrictions:spring-doc.cn
  • The classpath is fixed and fully defined at build time.spring-doc.cn
  • The beans defined in your application cannot change at runtime, meaning:spring-doc.cn
    • @Profile, in particular profile-specific configuration, needs to be chosen at build time and is automatically enabled at runtime when AOT is enabled.spring-doc.cn
    • Environment properties that impact the presence of a bean (@Conditional) are only considered at build time.spring-doc.cn
  • Bean definitions with instance suppliers (lambdas or method references) cannot be transformed ahead-of-time.spring-doc.cn
  • Beans registered as singletons (using registerSingleton, typically from ConfigurableListableBeanFactory) cannot be transformed ahead-of-time either.spring-doc.cn
  • As we cannot rely on the instance, make sure that the bean type is as precise as possible.spring-doc.cn
See also the Best Practices section.
When these restrictions are in place, it becomes possible to perform ahead-of-time processing at build time and generate additional assets. A Spring AOT processed application typically generates:spring-doc.cn
At the moment, AOT is focused on allowing Spring applications to be deployed as native images using GraalVM. We intend to support more JVM-based use cases in future generations.
AOT Engine Overview
The entry point of the AOT engine for processing an ApplicationContext is ApplicationContextAotGenerator. It takes care of the following steps, based on a GenericApplicationContext that represents the application to optimize and a GenerationContext:spring-doc.cn
  • Refresh an ApplicationContext for AOT processing. Contrary to a traditional refresh, this version only creates bean definitions, not bean instances.spring-doc.cn
  • Invoke the available BeanFactoryInitializationAotProcessor implementations and apply their contributions against the GenerationContext. For instance, a core implementation iterates over all candidate bean definitions and generates the necessary code to restore the state of the BeanFactory.spring-doc.cn
Once this process completes, the GenerationContext will have been updated with the generated code, resources, and classes that are necessary for the application to run. The RuntimeHints instance can also be used to generate the relevant GraalVM native image configuration files.spring-doc.cn
ApplicationContextAotGenerator#processAheadOfTime returns the class name of the ApplicationContextInitializer entry point that allows the context to be started with AOT optimizations.spring-doc.cn
Those steps are covered in greater detail in the sections below.spring-doc.cn
Refresh for AOT Processing
Refresh for AOT processing is supported on all GenericApplicationContext implementations. An application context is created with any number of entry points, usually in the form of @Configuration-annotated classes.spring-doc.cn
Let’s look at a basic example:spring-doc.cn
	@Configuration(proxyBeanMethods=false)
	@ComponentScan
	@Import({DataSourceConfiguration.class, ContainerConfiguration.class})
	public class MyApplication {
Starting this application with the regular runtime involves a number of steps including classpath scanning, configuration class parsing, bean instantiation, and lifecycle callback handling. Refresh for AOT processing only applies a subset of what happens with a regular refresh. AOT processing can be triggered as follows:spring-doc.cn
		RuntimeHints hints = new RuntimeHints();
		AnnotationConfigApplicationContext context = new AnnotationConfigApplicationContext();
		context.register(MyApplication.class);
		context.refreshForAotProcessing(hints);
		context.close();
In this mode, BeanFactoryPostProcessor implementations are invoked as usual. This includes configuration class parsing, import selectors, classpath scanning, etc. Such steps make sure that the BeanRegistry contains the relevant bean definitions for the application. If bean definitions are guarded by conditions (such as @Profile), these are evaluated, and bean definitions that don’t match their conditions are discarded at this stage.spring-doc.cn
If custom code needs to register extra beans programmatically, make sure that custom registration code uses BeanDefinitionRegistry instead of BeanFactory as only bean definitions are taken into account. A good pattern is to implement ImportBeanDefinitionRegistrar and register it via an @Import on one of your configuration classes.spring-doc.cn
Because this mode does not actually create bean instances, BeanPostProcessor implementations are not invoked, except for specific variants that are relevant for AOT processing. These are:spring-doc.cn
  • MergedBeanDefinitionPostProcessor implementations post-process bean definitions to extract additional settings, such as init and destroy methods.spring-doc.cn
  • SmartInstantiationAwareBeanPostProcessor implementations determine a more precise bean type if necessary. This makes sure to create any proxy that will be required at runtime.spring-doc.cn
Once this part completes, the BeanFactory contains the bean definitions that are necessary for the application to run. It does not trigger bean instantiation but allows the AOT engine to inspect the beans that will be created at runtime.spring-doc.cn
Bean Factory Initialization AOT Contributions
Components that want to participate in this step can implement the BeanFactoryInitializationAotProcessor interface. Each implementation can return an AOT contribution, based on the state of the bean factory.spring-doc.cn
An AOT contribution is a component that contributes generated code which reproduces a particular behavior. It can also contribute RuntimeHints to indicate the need for reflection, resource loading, serialization, or JDK proxies.spring-doc.cn
A BeanFactoryInitializationAotProcessor implementation can be registered in META-INF/spring/aot.factories with a key equal to the fully-qualified name of the interface.spring-doc.cn
The BeanFactoryInitializationAotProcessor interface can also be implemented directly by a bean. In this mode, the bean provides an AOT contribution equivalent to the feature it provides with a regular runtime. Consequently, such a bean is automatically excluded from the AOT-optimized context.spring-doc.cn
If a bean implements the BeanFactoryInitializationAotProcessor interface, the bean and all of its dependencies will be initialized during AOT processing. We generally recommend that this interface is only implemented by infrastructure beans such as BeanFactoryPostProcessor which have limited dependencies and are already initialized early in the bean factory lifecycle. If such a bean is registered using an @Bean factory method, ensure the method is static so that its enclosing @Configuration class does not have to be initialized.spring-doc.cn
Bean Registration AOT Contributions
A core BeanFactoryInitializationAotProcessor implementation is responsible for collecting the necessary contributions for each candidate BeanDefinition. It does so using a dedicated BeanRegistrationAotProcessor.spring-doc.cn
This interface is used as follows:spring-doc.cn
  • Implemented by a BeanPostProcessor bean, to replace its runtime behavior. For instance AutowiredAnnotationBeanPostProcessor implements this interface to generate code that injects members annotated with @Autowired.spring-doc.cn
  • Implemented by a type registered in META-INF/spring/aot.factories with a key equal to the fully-qualified name of the interface. Typically used when the bean definition needs to be tuned for specific features of the core framework.spring-doc.cn
If a bean implements the BeanRegistrationAotProcessor interface, the bean and all of its dependencies will be initialized during AOT processing. We generally recommend that this interface is only implemented by infrastructure beans such as BeanFactoryPostProcessor which have limited dependencies and are already initialized early in the bean factory lifecycle. If such a bean is registered using an @Bean factory method, ensure the method is static so that its enclosing @Configuration class does not have to be initialized.spring-doc.cn
If no BeanRegistrationAotProcessor handles a particular registered bean, a default implementation processes it. This is the default behavior, since tuning the generated code for a bean definition should be restricted to corner cases.spring-doc.cn
Taking our previous example, let’s assume that DataSourceConfiguration is as follows:spring-doc.cn
public class DataSourceConfiguration {
	public SimpleDataSource dataSource() {
		return new SimpleDataSource();
	fun dataSource() = SimpleDataSource()
Kotlin class names with backticks that use invalid Java identifiers (not starting with a letter, containing spaces, etc.) are not supported.
Since there isn’t any particular condition on this class, dataSourceConfiguration and dataSource are identified as candidates. The AOT engine will convert the configuration class above to code similar to the following:spring-doc.cn
 * Bean definitions for {@link DataSourceConfiguration}
@Generated
public class DataSourceConfiguration__BeanDefinitions {
	 * Get the bean definition for 'dataSourceConfiguration'
	public static BeanDefinition getDataSourceConfigurationBeanDefinition() {
		Class<?> beanType = DataSourceConfiguration.class;
		RootBeanDefinition beanDefinition = new RootBeanDefinition(beanType);
		beanDefinition.setInstanceSupplier(DataSourceConfiguration::new);
		return beanDefinition;
	 * Get the bean instance supplier for 'dataSource'.
	private static BeanInstanceSupplier<SimpleDataSource> getDataSourceInstanceSupplier() {
		return BeanInstanceSupplier.<SimpleDataSource>forFactoryMethod(DataSourceConfiguration.class, "dataSource")
				.withGenerator((registeredBean) -> registeredBean.getBeanFactory().getBean(DataSourceConfiguration.class).dataSource());
	 * Get the bean definition for 'dataSource'
	public static BeanDefinition getDataSourceBeanDefinition() {
		Class<?> beanType = SimpleDataSource.class;
		beanDefinition.setInstanceSupplier(getDataSourceInstanceSupplier());
The exact code generated may differ depending on the exact nature of your bean definitions.
Each generated class is annotated with org.springframework.aot.generate.Generated to identify them if they need to be excluded, for instance by static analysis tools.
The generated code above creates bean definitions equivalent to the @Configuration class, but in a direct way and without the use of reflection if at all possible. There is a bean definition for dataSourceConfiguration and one for dataSourceBean. When a datasource instance is required, a BeanInstanceSupplier is called. This supplier invokes the dataSource() method on the dataSourceConfiguration bean.spring-doc.cn
Running with AOT Optimizations
AOT is a mandatory step to transform a Spring application to a native executable, so it is automatically enabled when running in this mode. It is possible to use those optimizations on the JVM by setting the spring.aot.enabled System property to true.spring-doc.cn
When AOT optimizations are included, some decisions that have been taken at build-time are hard-coded in the application setup. For instance, profiles that have been enabled at build-time are automatically enabled at runtime as well.
Best Practices
The AOT engine is designed to handle as many use cases as possible, with no code change in applications. However, keep in mind that some optimizations are made at build time based on a static definition of the beans.spring-doc.cn
This section lists the best practices that make sure your application is ready for AOT.spring-doc.cn
Programmatic Bean Registration
The AOT engine takes care of the @Configuration model and any callback that might be invoked as part of processing your configuration. If you need to register additional beans programmatically, make sure to use a BeanDefinitionRegistry to register bean definitions.spring-doc.cn
This can typically be done via a BeanDefinitionRegistryPostProcessor. Note that, if it is registered itself as a bean, it will be invoked again at runtime unless you make sure to implement BeanFactoryInitializationAotProcessor as well. A more idiomatic way is to implement ImportBeanDefinitionRegistrar and register it using @Import on one of your configuration classes. This invokes your custom code as part of configuration class parsing.spring-doc.cn
If you declare additional beans programmatically using a different callback, they are likely not going to be handled by the AOT engine, and therefore no hints are going to be generated for them. Depending on the environment, those beans may not be registered at all. For instance, classpath scanning does not work in a native image as there is no notion of a classpath. For cases like this, it is crucial that the scanning happens at build time.spring-doc.cn
Expose the Most Precise Bean Type
While your application may interact with an interface that a bean implements, it is still very important to declare the most precise type. The AOT engine performs additional checks on the bean type, such as detecting the presence of @Autowired members or lifecycle callback methods.spring-doc.cn
For @Configuration classes, make sure that the return type of the factory @Bean method is as precise as possible. Consider the following example:spring-doc.cn
public class UserConfiguration {
	public MyInterface myInterface() {
		return new MyImplementation();
	fun myInterface(): MyInterface = MyImplementation()
In the example above, the declared type for the myInterface bean is MyInterface. None of the usual post-processing will take MyImplementation into account. For instance, if there is an annotated handler method on MyImplementation that the context should register, it won’t be detected upfront.spring-doc.cn
The example above should be rewritten as follows:spring-doc.cn
	public MyImplementation myInterface() {
	fun myInterface() = MyImplementation()
If you are registering bean definitions programmatically, consider using RootBeanBefinition as it allows to specify a ResolvableType that handles generics.spring-doc.cn
Avoid Multiple Constructors
The container is able to choose the most appropriate constructor to use based on several candidates. However, this is not a best practice and flagging the preferred constructor with @Autowired if necessary is preferred.spring-doc.cn
In case you are working on a code base that you cannot modify, you can set the preferredConstructors attribute on the related bean definition to indicate which constructor should be used.spring-doc.cn
Avoid Complex Data Structures for Constructor Parameters and Properties
When crafting a RootBeanDefinition programmatically, you are not constrained in terms of types that you can use. For instance, you may have a custom record with several properties that your bean takes as a constructor argument.spring-doc.cn
While this works fine with the regular runtime, AOT does not know how to generate the code of your custom data structure. A good rule of thumb is to keep in mind that bean definitions are an abstraction on top of several models. Rather than using such structures, decomposing to simple types or referring to a bean that is built as such is recommended.spring-doc.cn
As a last resort, you can implement your own org.springframework.aot.generate.ValueCodeGenerator$Delegate. To use it, register its fully qualified name in META-INF/spring/aot.factories using the Delegate as the key.spring-doc.cn
Avoid Creating Beans with Custom Arguments
Spring AOT detects what needs to be done to create a bean and translates that in generated code using an instance supplier. The container also supports creating a bean with custom arguments that leads to several issues with AOT:spring-doc.cn
  1. The custom arguments require dynamic introspection of a matching constructor or factory method. Those arguments cannot be detected by AOT, so the necessary reflection hints will have to be provided manually.spring-doc.cn
  2. By-passing the instance supplier means that all other optimizations after creation are skipped as well. For instance, autowiring on fields and methods will be skipped as they are handled in the instance supplier.spring-doc.cn
Rather than having prototype-scoped beans created with custom arguments, we recommend a manual factory pattern where a bean is responsible for the creation of the instance.spring-doc.cn
Avoid Circular Dependencies
Certain use cases can result in circular dependencies between one or more beans. With the regular runtime, it may be possible to wire those circular dependencies via @Autowired on setter methods or fields. However, an AOT-optimized context will fail to start with explicit circular dependencies.spring-doc.cn
In an AOT-optimized application, you should therefore strive to avoid circular dependencies. If that is not possible, you can use @Lazy injection points or ObjectProvider to lazily access or retrieve the necessary collaborating beans. See this tip for further information.spring-doc.cn
FactoryBean
FactoryBean should be used with care as it introduces an intermediate layer in terms of bean type resolution that may not be conceptually necessary. As a rule of thumb, if the FactoryBean instance does not hold long-term state and is not needed at a later point in time at runtime, it should be replaced by a regular factory method, possibly with a FactoryBean adapter layer on top (for declarative configuration purposes).spring-doc.cn
If your FactoryBean implementation does not resolve the object type (i.e. T), extra care is necessary. Consider the following example:spring-doc.cn
public class ClientFactoryBean<T extends AbstractClient> implements FactoryBean<T> {
class ClientFactoryBean<T : AbstractClient> : FactoryBean<T> {
A concrete client declaration should provide a resolved generic for the client, as shown in the following example:spring-doc.cn
	public ClientFactoryBean<MyClient> myClient() {
		return new ClientFactoryBean<>(...);
	fun myClient() = ClientFactoryBean<MyClient>(...)
If the FactoryBean bean definition is registered programmatically, make sure to follow these steps:spring-doc.cn
  1. Use RootBeanDefinition.spring-doc.cn
  2. Set the beanClass to the FactoryBean class so that AOT knows that it is an intermediate layer.spring-doc.cn
  3. Set the ResolvableType to a resolved generic, which makes sure the most precise type is exposed.spring-doc.cn
The following example showcases a basic definition:spring-doc.cn
RootBeanDefinition beanDefinition = new RootBeanDefinition(ClientFactoryBean.class);
beanDefinition.setTargetType(ResolvableType.forClassWithGenerics(ClientFactoryBean.class, MyClient.class));
registry.registerBeanDefinition("myClient", beanDefinition);
val beanDefinition = RootBeanDefinition(ClientFactoryBean::class.java)
beanDefinition.setTargetType(ResolvableType.forClassWithGenerics(ClientFactoryBean::class.java, MyClient::class.java));
JPA
The JPA persistence unit has to be known upfront for certain optimizations to apply. Consider the following basic example:spring-doc.cn
LocalContainerEntityManagerFactoryBean customDBEntityManagerFactory(DataSource dataSource) {
	LocalContainerEntityManagerFactoryBean factoryBean = new LocalContainerEntityManagerFactoryBean();
	factoryBean.setDataSource(dataSource);
	factoryBean.setPackagesToScan("com.example.app");
	return factoryBean;
fun customDBEntityManagerFactory(dataSource: DataSource): LocalContainerEntityManagerFactoryBean {
	val factoryBean = LocalContainerEntityManagerFactoryBean()
	factoryBean.dataSource = dataSource
	return factoryBean
To make sure the scanning occurs ahead of time, a PersistenceManagedTypes bean must be declared and used by the factory bean definition, as shown by the following example:spring-doc.cn
PersistenceManagedTypes persistenceManagedTypes(ResourceLoader resourceLoader) {
	return new PersistenceManagedTypesScanner(resourceLoader)
			.scan("com.example.app");
LocalContainerEntityManagerFactoryBean customDBEntityManagerFactory(DataSource dataSource, PersistenceManagedTypes managedTypes) {
	factoryBean.setManagedTypes(managedTypes);
	return factoryBean;
fun persistenceManagedTypes(resourceLoader: ResourceLoader): PersistenceManagedTypes {
	return PersistenceManagedTypesScanner(resourceLoader)
fun customDBEntityManagerFactory(dataSource: DataSource, managedTypes: PersistenceManagedTypes): LocalContainerEntityManagerFactoryBean {
	return factoryBean
Runtime Hints
Running an application as a native image requires additional information compared to a regular JVM runtime. For instance, GraalVM needs to know ahead of time if a component uses reflection. Similarly, classpath resources are not included in a native image unless specified explicitly. Consequently, if the application needs to load a resource, it must be referenced from the corresponding GraalVM native image configuration file.spring-doc.cn
The RuntimeHints API collects the need for reflection, resource loading, serialization, and JDK proxies at runtime. The following example makes sure that config/app.properties can be loaded from the classpath at runtime within a native image:spring-doc.cn
runtimeHints.resources().registerPattern("config/app.properties");
A number of contracts are handled automatically during AOT processing. For instance, the return type of a @Controller method is inspected, and relevant reflection hints are added if Spring detects that the type should be serialized (typically to JSON).spring-doc.cn
For cases that the core container cannot infer, you can register such hints programmatically. A number of convenient annotations are also provided for common use cases.spring-doc.cn
@ImportRuntimeHints
RuntimeHintsRegistrar implementations allow you to get a callback to the RuntimeHints instance managed by the AOT engine. Implementations of this interface can be registered using @ImportRuntimeHints on any Spring bean or @Bean factory method. RuntimeHintsRegistrar implementations are detected and invoked at build time.spring-doc.cn
import java.util.Locale;
import org.springframework.aot.hint.RuntimeHints;
import org.springframework.aot.hint.RuntimeHintsRegistrar;
import org.springframework.context.annotation.ImportRuntimeHints;
import org.springframework.core.io.ClassPathResource;
@Component
@ImportRuntimeHints(SpellCheckService.SpellCheckServiceRuntimeHints.class)
public class SpellCheckService {
	public void loadDictionary(Locale locale) {
		ClassPathResource resource = new ClassPathResource("dicts/" + locale.getLanguage() + ".txt");
	static class SpellCheckServiceRuntimeHints implements RuntimeHintsRegistrar {
		public void registerHints(RuntimeHints hints, ClassLoader classLoader) {
			hints.resources().registerPattern("dicts/*");
If at all possible, @ImportRuntimeHints should be used as close as possible to the component that requires the hints. This way, if the component is not contributed to the BeanFactory, the hints won’t be contributed either.spring-doc.cn
It is also possible to register an implementation statically by adding an entry in META-INF/spring/aot.factories with a key equal to the fully-qualified name of the RuntimeHintsRegistrar interface.spring-doc.cn
@Reflective
@Reflective provides an idiomatic way to flag the need for reflection on an annotated element. For instance, @EventListener is meta-annotated with @Reflective since the underlying implementation invokes the annotated method using reflection.spring-doc.cn
Out-of-the-box, only Spring beans are considered but you can opt-in for scanning using @ReflectiveScan. In the example below, all types of the package com.example.app and their subpackages are considered:spring-doc.cn
import org.springframework.context.annotation.ReflectiveScan;
@ReflectiveScan("com.example.app")
public class MyConfiguration {
Scanning happens during AOT processing and the types in the target packages do not need to have a class-level annotation to be considered. This performs a "deep scan" and the presence of @Reflective, either directly or as a meta-annotation, is checked on types, fields, constructors, methods, and enclosed elements.spring-doc.cn
By default, @Reflective registers an invocation hint for the annotated element. This can be tuned by specifying a custom ReflectiveProcessor implementation via the @Reflective annotation.spring-doc.cn
Library authors can reuse this annotation for their own purposes. An example of such customization is covered in the next section.spring-doc.cn
@RegisterReflection
@RegisterReflection is a specialization of @Reflective that provides a declarative way of registering reflection for arbitrary types.spring-doc.cn
As a specialization of @Reflective, this is also detected if you’re using @ReflectiveScan.
In the following example, public constructors and public methods can be invoked via reflection on AccountService:spring-doc.cn
@RegisterReflection(classes = AccountService.class, memberCategories =
		{ MemberCategory.INVOKE_PUBLIC_CONSTRUCTORS, MemberCategory.INVOKE_PUBLIC_METHODS })
@RegisterReflection can be applied to any target type at the class level, but it can also be applied directly to a method to better indicate where the hints are actually required.spring-doc.cn
@RegisterReflection can be used as a meta-annotation to provide more specific needs. @RegisterReflectionForBinding is such composed annotation and registers the need for serializing arbitrary types. A typical use case is the use of DTOs that the container cannot infer, such as using a web client within a method body.spring-doc.cn
The following example registers Order for serialization.spring-doc.cn
@Component
class OrderService {
	@RegisterReflectionForBinding(Order.class)
	public void process(Order order) {
This registers hints for constructors, fields, properties, and record components of Order. Hints are also registered for types transitively used on properties and record components. In other words, if Order exposes others types, hints are registered for those as well.spring-doc.cn
Testing Runtime Hints
Spring Core also ships RuntimeHintsPredicates, a utility for checking that existing hints match a particular use case. This can be used in your own tests to validate that a RuntimeHintsRegistrar contains the expected results. We can write a test for our SpellCheckService and ensure that we will be able to load a dictionary at runtime:spring-doc.cn
	@Test
	void shouldRegisterResourceHints() {
		new SpellCheckServiceRuntimeHints().registerHints(hints, getClass().getClassLoader());
		assertThat(RuntimeHintsPredicates.resource().forResource("dicts/en.txt"))
				.accepts(hints);
With RuntimeHintsPredicates, we can check for reflection, resource, serialization, or proxy generation hints. This approach works well for unit tests but implies that the runtime behavior of a component is well known.spring-doc.cn
You can learn more about the global runtime behavior of an application by running its test suite (or the app itself) with the GraalVM tracing agent. This agent will record all relevant calls requiring GraalVM hints at runtime and write them out as JSON configuration files.spring-doc.cn
For more targeted discovery and testing, Spring Framework ships a dedicated module with core AOT testing utilities, "org.springframework:spring-core-test". This module contains the RuntimeHints Agent, a Java agent that records all method invocations that are related to runtime hints and helps you to assert that a given RuntimeHints instance covers all recorded invocations. Let’s consider a piece of infrastructure for which we’d like to test the hints we’re contributing during the AOT processing phase.spring-doc.cn
import java.lang.reflect.Method;
import org.apache.commons.logging.Log;
import org.apache.commons.logging.LogFactory;
import org.springframework.util.ClassUtils;
public class SampleReflection {
	private final Log logger = LogFactory.getLog(SampleReflection.class);
	public void performReflection() {
		try {
			Class<?> springVersion = ClassUtils.forName("org.springframework.core.SpringVersion", null);
			Method getVersion = ClassUtils.getMethod(springVersion, "getVersion");
			String version = (String) getVersion.invoke(null);
			logger.info("Spring version: " + version);
		catch (Exception exc) {
			logger.error("reflection failed", exc);
We can then write a unit test (no native compilation required) that checks our contributed hints:spring-doc.cn
import java.util.List;
import org.junit.jupiter.api.Test;
import org.springframework.aot.hint.ExecutableMode;
import org.springframework.aot.test.agent.EnabledIfRuntimeHintsAgent;
import org.springframework.aot.test.agent.RuntimeHintsInvocations;
import org.springframework.aot.test.agent.RuntimeHintsRecorder;
import org.springframework.core.SpringVersion;
import static org.assertj.core.api.Assertions.assertThat;
// @EnabledIfRuntimeHintsAgent signals that the annotated test class or test
// method is only enabled if the RuntimeHintsAgent is loaded on the current JVM.
// It also tags tests with the "RuntimeHints" JUnit tag.
class SampleReflectionRuntimeHintsTests {
	@Test
	void shouldRegisterReflectionHints() {
		RuntimeHints runtimeHints = new RuntimeHints();
		// Call a RuntimeHintsRegistrar that contributes hints like:
		runtimeHints.reflection().registerType(SpringVersion.class, typeHint ->
				typeHint.withMethod("getVersion", List.of(), ExecutableMode.INVOKE));
		// Invoke the relevant piece of code we want to test within a recording lambda
		RuntimeHintsInvocations invocations = RuntimeHintsRecorder.record(() -> {
			SampleReflection sample = new SampleReflection();
			sample.performReflection();
		// assert that the recorded invocations are covered by the contributed hints
		assertThat(invocations).match(runtimeHints);
If you forgot to contribute a hint, the test will fail and provide some details about the invocation:spring-doc.cn
org.springframework.docs.core.aot.hints.testing.SampleReflection performReflection
INFO: Spring version: 6.2.0
Missing <"ReflectionHints"> for invocation <java.lang.Class#forName>
with arguments ["org.springframework.core.SpringVersion",
    false,
    jdk.internal.loader.ClassLoaders$AppClassLoader@251a69d7].
Stacktrace:
<"org.springframework.util.ClassUtils#forName, Line 284
io.spring.runtimehintstesting.SampleReflection#performReflection, Line 19
io.spring.runtimehintstesting.SampleReflectionRuntimeHintsTests#lambda$shouldRegisterReflectionHints$0, Line 25
There are various ways to configure this Java agent in your build, so please refer to the documentation of your build tool and test execution plugin. The agent itself can be configured to instrument specific packages (by default, only org.springframework is instrumented). You’ll find more details in the Spring Framework buildSrc README file.spring-doc.cn
