Appendix
XML Schemas
This part of the appendix lists XML schemas related to integration technologies.spring-doc.cn
The jee Schema
The jee elements deal with issues related to Jakarta EE (Enterprise Edition) configuration, such as looking up a JNDI object and defining EJB references.spring-doc.cn
To use the elements in the jee schema, you need to have the following preamble at the top of your Spring XML configuration file. The text in the following snippet references the correct schema so that the elements in the jee namespace are available to you:spring-doc.cn
	xmlns:jee="http://www.springframework.org/schema/jee"
	xsi:schemaLocation="
		https://www.springframework.org/schema/jee/spring-jee.xsd">
	<!-- bean definitions here -->
</beans>
<jee:jndi-lookup/> (simple)
The following example shows how to use JNDI to look up a data source without the jee schema:spring-doc.cn
<bean id="dataSource" class="org.springframework.jndi.JndiObjectFactoryBean">
	<property name="jndiName" value="jdbc/MyDataSource"/>
</bean>
<bean id="userDao" class="com.foo.JdbcUserDao">
	<!-- Spring will do the cast automatically (as usual) -->
	<property name="dataSource" ref="dataSource"/>
</bean>
The following example shows how to use JNDI to look up a data source with the jee schema:spring-doc.cn
<jee:jndi-lookup id="dataSource" jndi-name="jdbc/MyDataSource"/>
</bean>
<jee:jndi-lookup/> (with Single JNDI Environment Setting)
The following example shows how to use JNDI to look up an environment variable without jee:spring-doc.cn
<bean id="simple" class="org.springframework.jndi.JndiObjectFactoryBean">
	<property name="jndiEnvironment">
		<props>
			<prop key="ping">pong</prop>
		</props>
	</property>
</bean>
The following example shows how to use JNDI to look up an environment variable with jee:spring-doc.cn
<jee:jndi-lookup id="simple" jndi-name="jdbc/MyDataSource">
	<jee:environment>ping=pong</jee:environment>
</jee:jndi-lookup>
<jee:jndi-lookup/> (with Multiple JNDI Environment Settings)
The following example shows how to use JNDI to look up multiple environment variables without jee:spring-doc.cn
		<props>
			<prop key="sing">song</prop>
		</props>
	</property>
</bean>
The following example shows how to use JNDI to look up multiple environment variables with jee:spring-doc.cn
	<!-- newline-separated, key-value pairs for the environment (standard Properties format) -->
	<jee:environment>
		sing=song
		ping=pong
	</jee:environment>
</jee:jndi-lookup>
<jee:jndi-lookup/> (Complex)
The following example shows how to use JNDI to look up a data source and a number of different properties without jee:spring-doc.cn
	<property name="cache" value="true"/>
	<property name="resourceRef" value="true"/>
	<property name="lookupOnStartup" value="false"/>
	<property name="expectedType" value="com.myapp.DefaultThing"/>
	<property name="proxyInterface" value="com.myapp.Thing"/>
</bean>
The following example shows how to use JNDI to look up a data source and a number of different properties with jee:spring-doc.cn
		cache="true"
		resource-ref="true"
		lookup-on-startup="false"
		expected-type="com.myapp.DefaultThing"
		proxy-interface="com.myapp.Thing"/>
<jee:local-slsb/> (Simple)
The <jee:local-slsb/> element configures a reference to a local EJB Stateless Session Bean.spring-doc.cn
The following example shows how to configures a reference to a local EJB Stateless Session Bean without jee:spring-doc.cn
<bean id="simple"
		class="org.springframework.ejb.access.LocalStatelessSessionProxyFactoryBean">
	<property name="jndiName" value="ejb/RentalServiceBean"/>
	<property name="businessInterface" value="com.foo.service.RentalService"/>
</bean>
The following example shows how to configures a reference to a local EJB Stateless Session Bean with jee:spring-doc.cn
<jee:local-slsb id="simpleSlsb" jndi-name="ejb/RentalServiceBean"
		business-interface="com.foo.service.RentalService"/>
<jee:local-slsb/> (Complex)
The following example shows how to configures a reference to a local EJB Stateless Session Bean and a number of properties without jee:spring-doc.cn
<bean id="complexLocalEjb"
	<property name="businessInterface" value="com.example.service.RentalService"/>
	<property name="cacheHome" value="true"/>
	<property name="lookupHomeOnStartup" value="true"/>
</bean>
The following example shows how to configures a reference to a local EJB Stateless Session Bean and a number of properties with jee:spring-doc.cn
<jee:local-slsb id="complexLocalEjb"
		cache-home="true"
		lookup-home-on-startup="true"
		resource-ref="true">
<jee:remote-slsb/>
The <jee:remote-slsb/> element configures a reference to a remote EJB Stateless Session Bean.spring-doc.cn
The following example shows how to configures a reference to a remote EJB Stateless Session Bean without jee:spring-doc.cn
<bean id="complexRemoteEjb"
		class="org.springframework.ejb.access.SimpleRemoteStatelessSessionProxyFactoryBean">
	<property name="jndiName" value="ejb/MyRemoteBean"/>
	<property name="homeInterface" value="com.foo.service.RentalService"/>
	<property name="refreshHomeOnConnectFailure" value="true"/>
</bean>
The following example shows how to configures a reference to a remote EJB Stateless Session Bean with jee:spring-doc.cn
<jee:remote-slsb id="complexRemoteEjb"
		jndi-name="ejb/MyRemoteBean"
		cache-home="true"
		resource-ref="true"
		home-interface="com.foo.service.RentalService"
		refresh-home-on-connect-failure="true">
The jms Schema
The jms elements deal with configuring JMS-related beans, such as Spring’s Message Listener Containers. These elements are detailed in the section of the JMS chapter entitled JMS Namespace Support . See that chapter for full details on this support and the jms elements themselves.spring-doc.cn
In the interest of completeness, to use the elements in the jms schema, you need to have the following preamble at the top of your Spring XML configuration file. The text in the following snippet references the correct schema so that the elements in the jms namespace are available to you:spring-doc.cn
	xmlns:jms="http://www.springframework.org/schema/jms"
		https://www.springframework.org/schema/jms/spring-jms.xsd">
</beans>
Using <context:mbean-export/>
The cache Schema
You can use the cache elements to enable support for Spring’s @CacheEvict, @CachePut, and @Caching annotations. It it also supports declarative XML-based caching. See Enabling Caching Annotations and Declarative XML-based Caching for details.spring-doc.cn
To use the elements in the cache schema, you need to have the following preamble at the top of your Spring XML configuration file. The text in the following snippet references the correct schema so that the elements in the cache namespace are available to you:spring-doc.cn
	xmlns:cache="http://www.springframework.org/schema/cache"
		https://www.springframework.org/schema/cache/spring-cache.xsd">
</beans>
