Varargs Invocations
The Spring Expression Language supports varargs invocations for constructors, methods, and user-defined functions.spring-doc.cn
The following example shows how to invoke the java.lang.String#formatted(Object…​) varargs method within an expression by supplying the variable argument list as separate arguments ('blue', 1).spring-doc.cn
// evaluates to "blue is color #1"
String expression = "'%s is color #%d'.formatted('blue', 1)";
String message = parser.parseExpression(expression).getValue(String.class);
val expression = "'%s is color #%d'.formatted('blue', 1)"
val message = parser.parseExpression(expression).getValue(String::class.java)
A variable argument list can also be supplied as an array, as demonstrated in the following example (new Object[] {'blue', 1}).spring-doc.cn
String expression = "'%s is color #%d'.formatted(new Object[] {'blue', 1})";
val expression = "'%s is color #%d'.formatted(new Object[] {'blue', 1})"
As an alternative, a variable argument list can be supplied as a java.util.List – for example, as an inline list ({'blue', 1}). The following example shows how to do that.spring-doc.cn
String expression = "'%s is color #%d'.formatted({'blue', 1})";
val expression = "'%s is color #%d'.formatted({'blue', 1})"
Varargs Type Conversion
In contrast to the standard support for varargs invocations in Java, type conversion may be applied to the individual arguments when invoking varargs constructors, methods, or functions in SpEL.spring-doc.cn
For example, if we have registered a custom function in the EvaluationContext under the name #reverseStrings for a method with the signature String reverseStrings(String…​ strings), we can invoke that function within a SpEL expression with any argument that can be converted to a String, as demonstrated in the following example.spring-doc.cn
// evaluates to "3.0, 2.0, 1, SpEL"
String expression = "#reverseStrings('SpEL', 1, 10F / 5, 3.0000)";
		.getValue(evaluationContext, String.class);
val expression = "#reverseStrings('SpEL', 1, 10F / 5, 3.0000)"
		.getValue(evaluationContext, String::class.java)
Similarly, any array whose component type is a subtype of the required varargs type can be supplied as the variable argument list for a varargs invocation. For example, a String[] array can be supplied to a varargs invocation that accepts an Object…​ argument list.spring-doc.cn
The following listing demonstrates that we can supply a String[] array to the java.lang.String#formatted(Object…​) varargs method. It also highlights that 1 will be automatically converted to "1".spring-doc.cn
String expression = "'%s is color #%s'.formatted(new String[] {'blue', 1})";
val expression = "'%s is color #%s'.formatted(new String[] {'blue', 1})"
