Default Servlet
Spring MVC allows for mapping the DispatcherServlet to / (thus overriding the mapping of the container’s default Servlet), while still allowing static resource requests to be handled by the container’s default Servlet. It configures a DefaultServletHttpRequestHandler with a URL mapping of /** and the lowest priority relative to other URL mappings.spring-doc.cn
This handler forwards all requests to the default Servlet. Therefore, it must remain last in the order of all other URL HandlerMappings. That is the case if you use <mvc:annotation-driven>. Alternatively, if you set up your own customized HandlerMapping instance, be sure to set its order property to a value lower than that of the DefaultServletHttpRequestHandler, which is Integer.MAX_VALUE.spring-doc.cn
The following example shows how to enable the feature by using the default setup:spring-doc.cn
public class WebConfiguration implements WebMvcConfigurer {
	public void configureDefaultServletHandling(DefaultServletHandlerConfigurer configurer) {
		configurer.enable();
class WebConfiguration : WebMvcConfigurer {
	override fun configureDefaultServletHandling(configurer: DefaultServletHandlerConfigurer) {
		configurer.enable()
<mvc:default-servlet-handler/>
The caveat to overriding the / Servlet mapping is that the RequestDispatcher for the default Servlet must be retrieved by name rather than by path. The DefaultServletHttpRequestHandler tries to auto-detect the default Servlet for the container at startup time, using a list of known names for most of the major Servlet containers (including Tomcat, Jetty, GlassFish, JBoss, WebLogic, and WebSphere). If the default Servlet has been custom-configured with a different name, or if a different Servlet container is being used where the default Servlet name is unknown, then you must explicitly provide the default Servlet’s name, as the following example shows:spring-doc.cn
public class CustomDefaultServletConfiguration implements WebMvcConfigurer {
		configurer.enable("myCustomDefaultServlet");
class CustomDefaultServletConfiguration : WebMvcConfigurer {
<mvc:default-servlet-handler default-servlet-name="myCustomDefaultServlet"/>
