Validation
By default, if Bean Validation is present on the classpath (for example, Hibernate Validator), the LocalValidatorFactoryBean is registered as a global Validator for use with @Valid and @Validated on controller method arguments.spring-doc.cn
You can customize the global Validator instance, as the following example shows:spring-doc.cn
public class WebConfiguration implements WebMvcConfigurer {
	public Validator getValidator() {
		Validator validator = new OptionalValidatorFactoryBean();
		return validator;
class WebConfiguration : WebMvcConfigurer {
	override fun getValidator(): Validator {
		val validator = OptionalValidatorFactoryBean()
		return validator
<mvc:annotation-driven validator="globalValidator"/>
Note that you can also register Validator implementations locally, as the following example shows:spring-doc.cn
@Controller
public class MyController {
	@InitBinder
	public void initBinder(WebDataBinder binder) {
		binder.addValidators(new FooValidator());
@Controller
	@InitBinder
	fun initBinder(binder: WebDataBinder) {
		binder.addValidators(FooValidator())
If you need to have a LocalValidatorFactoryBean injected somewhere, create a bean and mark it with @Primary in order to avoid conflict with the one declared in the MVC configuration.
