Bean References
If the evaluation context has been configured with a bean resolver, you can look up beans from an expression by using the @ symbol as a prefix. The following example shows how to do so:spring-doc.cn
ExpressionParser parser = new SpelExpressionParser();
StandardEvaluationContext context = new StandardEvaluationContext();
context.setBeanResolver(new MyBeanResolver());
// This will end up calling resolve(context, "someBean") on MyBeanResolver
// during evaluation.
Object bean = parser.parseExpression("@someBean").getValue(context);
val parser = SpelExpressionParser()
val context = StandardEvaluationContext()
context.setBeanResolver(MyBeanResolver())
val bean = parser.parseExpression("@someBean").getValue(context)
If a bean name contains a dot (.) or other special characters, you must provide the name of the bean as a string literal – for example, @'order.service'.spring-doc.cn
To access a factory bean itself, you should instead prefix the bean name with an & symbol. The following example shows how to do so:spring-doc.cn
// This will end up calling resolve(context, "&someFactoryBean") on
// MyBeanResolver during evaluation.
Object factoryBean = parser.parseExpression("&someFactoryBean").getValue(context);
val factoryBean = parser.parseExpression("&someFactoryBean").getValue(context)
