This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.0! |
Message Converters
You can set the HttpMessageConverter
instances to use in Java configuration,
replacing the ones used by default, by overriding
configureMessageConverters()
You can also customize the list of configured message converters at the end by overriding
extendMessageConverters()
In a Spring Boot application, the WebMvcAutoConfiguration adds any
HttpMessageConverter beans it detects, in addition to default converters. Hence, in a
Boot application, prefer to use the HttpMessageConverters
mechanism. Or alternatively, use extendMessageConverters to modify message converters
at the end.
The following example adds XML and Jackson JSON converters with a customized ObjectMapper
instead of the default ones:
Java
Kotlin
Xml
public class WebConfiguration implements WebMvcConfigurer {
public void configureMessageConverters(List<HttpMessageConverter<?>> converters) {
Jackson2ObjectMapperBuilder builder = new Jackson2ObjectMapperBuilder()
.indentOutput(true)
.dateFormat(new SimpleDateFormat("yyyy-MM-dd"))
.modulesToInstall(new ParameterNamesModule());
converters.add(new MappingJackson2HttpMessageConverter(builder.build()));
converters.add(new MappingJackson2XmlHttpMessageConverter(builder.createXmlMapper(true).build()));
class WebConfiguration : WebMvcConfigurer {
override fun configureMessageConverters(converters: MutableList<HttpMessageConverter<*>>) {
val builder = Jackson2ObjectMapperBuilder()
.indentOutput(true)
.dateFormat(SimpleDateFormat("yyyy-MM-dd"))
.modulesToInstall(ParameterNamesModule())
converters.add(MappingJackson2HttpMessageConverter(builder.build()))
converters.add(MappingJackson2XmlHttpMessageConverter(builder.createXmlMapper(true).build()))
<mvc:annotation-driven>
<mvc:message-converters>
<bean class="org.springframework.http.converter.json.MappingJackson2HttpMessageConverter">
<property name="objectMapper" ref="objectMapper"/>
</bean>
<bean class="org.springframework.http.converter.xml.MappingJackson2XmlHttpMessageConverter">
<property name="objectMapper" ref="xmlMapper"/>
</bean>
</mvc:message-converters>
</mvc:annotation-driven>
<bean id="objectMapper" class="org.springframework.http.converter.json.Jackson2ObjectMapperFactoryBean"
p:indentOutput="true"
p:simpleDateFormat="yyyy-MM-dd"
p:modulesToInstall="com.fasterxml.jackson.module.paramnames.ParameterNamesModule"/>
<bean id="xmlMapper" parent="objectMapper" p:createXmlMapper="true"/>
In the preceding example,
is used to create a common configuration for both MappingJackson2HttpMessageConverter
and
with indentation enabled, a customized date format,
and the registration of
jackson-module-parameter-names
Which adds support for accessing parameter names (a feature added in Java 8).
This builder customizes Jackson’s default properties as follows:
DeserializationFeature.FAIL_ON_UNKNOWN_PROPERTIES
is disabled. -
MapperFeature.DEFAULT_VIEW_INCLUSION
is disabled.
It also automatically registers the following well-known modules if they are detected on the classpath:
jackson-datatype-jsr310: Support for Java 8 Date and Time API types.
jackson-datatype-jdk8: Support for other Java 8 types, such as
Optional
jackson-module-kotlin: Support for Kotlin classes and data classes.
Enabling indentation with Jackson XML support requires
woodstox-core-asl
dependency in addition to jackson-dataformat-xml one.
Other interesting Jackson modules are available:
jackson-datatype-money: Support for
javax.money
types (unofficial module). -
jackson-datatype-hibernate: Support for Hibernate-specific types and properties (including lazy-loading aspects).
