@ModelAttribute
The @ModelAttribute method parameter annotation binds form data, query parameters, URI path variables, and request headers onto a model object. For example:spring-doc.cn
@PostMapping("/owners/{ownerId}/pets/{petId}/edit")
public String processSubmit(@ModelAttribute Pet pet) { } (1)
1 Bind to an instance of Pet.
fun processSubmit(@ModelAttribute pet: Pet): String { } (1)
Form data and query parameters take precedence over URI variables and headers, which are included only if they don’t override request parameters with the same name. Dashes are stripped from header names.spring-doc.cn
The Pet instance may be:spring-doc.cn
  • Accessed from the model where it could have been added by a Model.spring-doc.cn
  • Accessed from the HTTP session if the model attribute was listed in the class-level @SessionAttributes.spring-doc.cn
  • Instantiated through a default constructor.spring-doc.cn
  • Instantiated through a “primary constructor” with arguments that match to Servlet request parameters. Argument names are determined through runtime-retained parameter names in the bytecode.spring-doc.cn
By default, both constructor and property data binding are applied. However, model object design requires careful consideration, and for security reasons it is recommended either to use an object tailored specifically for web binding, or to apply constructor binding only. If property binding must still be used, then allowedFields patterns should be set to limit which properties can be set. For further details on this and example configuration, see model design.spring-doc.cn
When using constructor binding, you can customize request parameter names through an @BindParam annotation. For example:spring-doc.cn
class Account {
    private final String firstName;
	public Account(@BindParam("first-name") String firstName) {
		this.firstName = firstName;
class Account(@BindParam("first-name") val firstName: String)
The @BindParam may also be placed on the fields that correspond to constructor parameters. While @BindParam is supported out of the box, you can also use a different annotation by setting a DataBinder.NameResolver on DataBinder
Constructor binding supports List, Map, and array arguments either converted from a single string, for example, comma-separated list, or based on indexed keys such as accounts[2].name or account[KEY].name.spring-doc.cn
WebFlux, unlike Spring MVC, supports reactive types in the model, for example, Mono<Account>. You can declare a @ModelAttribute argument with or without a reactive type wrapper, and it will be resolved accordingly to the actual value.spring-doc.cn
If data binding results in errors, by default a WebExchangeBindException is raised, but you can also add a BindingResult argument immediately next to the @ModelAttribute in order to handle such errors in the controller method. For example:spring-doc.cn
public String processSubmit(@ModelAttribute("pet") Pet pet, BindingResult result) { (1)
	if (result.hasErrors()) {
		return "petForm";
1 Adding a BindingResult.
fun processSubmit(@ModelAttribute("pet") pet: Pet, result: BindingResult): String { (1)
		return "petForm"
To use a BindingResult argument, you must declare the @ModelAttribute argument before it without a reactive type wrapper. If you want to use the reactive, you can handle errors directly through it. For example:spring-doc.cn
public Mono<String> processSubmit(@Valid @ModelAttribute("pet") Mono<Pet> petMono) {
	return petMono
		.flatMap(pet -> {
		.onErrorResume(ex -> {
fun processSubmit(@Valid @ModelAttribute("pet") petMono: Mono<Pet>): Mono<String> {
	return petMono
			.flatMap { pet ->
			.onErrorResume{ ex ->
You can automatically apply validation after data binding by adding the jakarta.validation.Valid annotation or Spring’s @Validated annotation (see Bean Validation and Spring validation). For example:spring-doc.cn
public String processSubmit(@Valid @ModelAttribute("pet") Pet pet, BindingResult result) { (1)
		return "petForm";
1 Using @Valid on a model attribute argument.
fun processSubmit(@Valid @ModelAttribute("pet") pet: Pet, result: BindingResult): String { (1)
		return "petForm"
If method validation applies because other parameters have @Constraint annotations, then HandlerMethodValidationException would be raised instead. See the section on controller method Validation.spring-doc.cn
Using @ModelAttribute is optional. By default, any argument that is not a simple value type as determined by BeanUtils#isSimpleProperty AND that is not resolved by any other argument resolver is treated as an implicit @ModelAttribute.
When compiling to a native image with GraalVM, the implicit @ModelAttribute support described above does not allow proper ahead-of-time inference of related data binding reflection hints. As a consequence, it is recommended to explicitly annotate method parameters with @ModelAttribute for use in a GraalVM native image.
