@TestBean
@TestBean is used on a non-static field in a test class to override a specific bean in the test’s ApplicationContext with an instance provided by a factory method.spring-doc.cn
The associated factory method name is derived from the annotated field’s name, or the bean name if specified. The factory method must be static, accept no arguments, and have a return type compatible with the type of the bean to override. To make things more explicit, or if you’d rather use a different name, the annotation allows for a specific method name to be provided.spring-doc.cn
By default, the annotated field’s type is used to search for candidate beans to override. If multiple candidates match, @Qualifier can be provided to narrow the candidate to override. Alternatively, a candidate whose bean name matches the name of the field will match.spring-doc.cn
A bean will be created if a corresponding bean does not exist. However, if you would like for the test to fail when a corresponding bean does not exist, you can set the enforceOverride attribute to true – for example, @TestBean(enforceOverride = true).spring-doc.cn
To use a by-name override rather than a by-type override, specify the name attribute of the annotation.spring-doc.cn
Qualifiers, including the name of the field, are used to determine if a separate ApplicationContext needs to be created. If you are using this feature to override the same bean in several tests, make sure to name the field consistently to avoid creating unnecessary contexts.spring-doc.cn
There are no restrictions on the visibility of @TestBean fields or factory methods.spring-doc.cn
Such fields and methods can therefore be public, protected, package-private (default visibility), or private depending on the needs or coding practices of the project.spring-doc.cn
The following example shows how to use the default behavior of the @TestBean annotation:spring-doc.cn
class OverrideBeanTests {
	@TestBean (1)
	CustomService customService;
	// test case body...
	static CustomService customService() { (2)
		return new MyFakeCustomService();
1 Mark a field for overriding the bean with type CustomService.
2 The result of this static method will be used as the instance and injected into the field.
In the example above, we are overriding the bean with type CustomService. If more than one bean of that type exists, the bean named customService is considered. Otherwise, the test will fail, and you will need to provide a qualifier of some sort to identify which of the CustomService beans you want to override.spring-doc.cn
The following example uses a by-name lookup, rather than a by-type lookup:spring-doc.cn
	@TestBean(name = "service", methodName = "createCustomService") (1)
	static CustomService createCustomService() { (2)
1 Mark a field for overriding the bean with name service, and specify that the factory method is named createCustomService.
Spring searches for the factory method to invoke in the test class, in the test class hierarchy, and in the enclosing class hierarchy for a @Nested test class.spring-doc.cn
Alternatively, a factory method in an external class can be referenced via its fully-qualified method name following the syntax <fully-qualified class name>#<method name> – for example, methodName = "org.example.TestUtils#createCustomService".spring-doc.cn
Only singleton beans can be overridden. Any attempt to override a non-singleton bean will result in an exception.spring-doc.cn
When overriding a bean created by a FactoryBean, the FactoryBean will be replaced with a singleton bean corresponding to the value returned from the @TestBean factory method.spring-doc.cn
