@AfterTransaction
@AfterTransaction indicates that the annotated void method should be run after a transaction is ended, for test methods that have been configured to run within a transaction by using Spring’s @Transactional annotation. @AfterTransaction methods are not required to be public and may be declared on Java 8-based interface default methods.spring-doc.cn
@AfterTransaction (1)
void afterTransaction() {
	// logic to be run after a transaction has ended
1 Run this method after a transaction.
fun afterTransaction() {
