@ActiveProfiles
@ActiveProfiles is an annotation that can be applied to a test class to declare which bean definition profiles should be active when loading an ApplicationContext for an integration test.spring-doc.cn
The following example indicates that the dev profile should be active:spring-doc.cn
@ContextConfiguration
@ActiveProfiles("dev") (1)
class DeveloperTests {
	// class body...
1 Indicate that the dev profile should be active.
	// class body...
The following example indicates that both the dev and the integration profiles should be active:spring-doc.cn
@ActiveProfiles({"dev", "integration"}) (1)
class DeveloperIntegrationTests {
	// class body...
1 Indicate that the dev and integration profiles should be active.
@ActiveProfiles(["dev", "integration"]) (1)
	// class body...
@ActiveProfiles provides support for inheriting active bean definition profiles declared by superclasses and enclosing classes by default. You can also resolve active bean definition profiles programmatically by implementing a custom ActiveProfilesResolver and registering it by using the resolver attribute of @ActiveProfiles.
