For the latest stable version, please use Spring Data Relational 3.4.4! |
Publishing Events from Aggregate Roots
Entities managed by repositories are aggregate roots.
In a Domain-Driven Design application, these aggregate roots usually publish domain events.
Spring Data provides an annotation called @DomainEvents
that you can use on a method of your aggregate root to make that publication as easy as possible, as shown in the following example:
class AnAggregateRoot {
@DomainEvents (1)
Collection<Object> domainEvents() {
// … return events you want to get published here
@AfterDomainEventPublication (2)
void callbackMethod() {
// … potentially clean up domain events list
1 | The method that uses @DomainEvents can return either a single event instance or a collection of events.
It must not take any arguments. |
2 | After all events have been published, we have a method annotated with @AfterDomainEventPublication .
You can use it to potentially clean the list of events to be published (among other uses). |
The methods are called every time one of the following a Spring Data repository methods are called:
save(…)
,saveAll(…)
delete(…)
,deleteAll(…)
,deleteAllInBatch(…)
,deleteInBatch(…)
Note, that these methods take the aggregate root instances as arguments.
This is why deleteById(…)
is notably absent, as the implementations might choose to issue a query deleting the instance and thus we would never have access to the aggregate instance in the first place.
