For the latest stable version, please use Spring Data Relational 3.4.4!spring-doc.cn
Kotlin
This part of the reference documentation explains the specific Kotlin functionality offered by Spring Data R2DBC. See Kotlin Support for the general functionality provided by Spring Data.spring-doc.cn
To retrieve a list of SWCharacter objects in Java, you would normally write the following:spring-doc.cn
Flux<SWCharacter> characters = client.select().from(SWCharacter.class).fetch().all();
With Kotlin and the Spring Data extensions, you can instead write the following:spring-doc.cn
val characters =  client.select().from<SWCharacter>().fetch().all()
// or (both are equivalent)
val characters : Flux<SWCharacter> = client.select().from().fetch().all()
As in Java, characters in Kotlin is strongly typed, but Kotlin’s clever type inference allows for shorter syntax.spring-doc.cn
Spring Data R2DBC provides the following extensions:spring-doc.cn
