For the latest stable version, please use Spring Data Relational 3.4.4!spring-doc.cn
EntityCallbacks
Spring Data R2DBC uses the EntityCallback API for its auditing support and reacts on the following callbacks.spring-doc.cn
Table 1. Supported Entity Callbacks
Callback Method Description Order
BeforeConvertCallbackspring-doc.cn
onBeforeConvert(T entity, SqlIdentifier table)spring-doc.cn
Invoked before a domain object is converted to OutboundRow.spring-doc.cn
Ordered.LOWEST_PRECEDENCEspring-doc.cn
AfterConvertCallbackspring-doc.cn
onAfterConvert(T entity, SqlIdentifier table)spring-doc.cn
Invoked after a domain object is loaded.
Can modify the domain object after reading it from a row.spring-doc.cn
AuditingEntityCallbackspring-doc.cn
Marks an auditable entity created or modifiedspring-doc.cn
100spring-doc.cn
BeforeSaveCallbackspring-doc.cn
onBeforeSave(T entity, OutboundRow row, SqlIdentifier table)spring-doc.cn
Invoked before a domain object is saved.
Can modify the target, to be persisted, OutboundRow containing all mapped entity information.spring-doc.cn
AfterSaveCallbackspring-doc.cn
onAfterSave(T entity, OutboundRow row, SqlIdentifier table)spring-doc.cn
Invoked after a domain object is saved.
Can modify the domain object, to be returned after save, OutboundRow containing all mapped entity information.spring-doc.cn
