For the latest stable version, please use Spring Data Relational 3.4.4!spring-doc.cn
Migration Guide
The following sections explain how to migrate to a newer version of Spring Data R2DBC.spring-doc.cn
Upgrading from 1.1.x to 1.2.x
Spring Data R2DBC was developed with the intent to evaluate how well R2DBC can integrate with Spring applications. One of the main aspects was to move core support into Spring Framework once R2DBC support has proven useful. Spring Framework 5.3 ships with a new module: Spring R2DBC (spring-r2dbc).spring-doc.cn
spring-r2dbc ships core R2DBC functionality (a slim variant of DatabaseClient, Transaction Manager, Connection Factory initialization, Exception translation) that was initially provided by Spring Data R2DBC. The 1.2.0 release aligns with what’s provided in Spring R2DBC by making several changes outlined in the following sections.spring-doc.cn
Spring R2DBC’s DatabaseClient is a more lightweight implementation that encapsulates a pure SQL-oriented interface. You will notice that the method to run SQL statements changed from DatabaseClient.execute(…) to DatabaseClient.sql(…). The fluent API for CRUD operations has moved into R2dbcEntityTemplate.spring-doc.cn
If you use logging of SQL statements through the logger prefix org.springframework.data.r2dbc, make sure to update it to org.springframework.r2dbc (that is removing .data) to point to Spring R2DBC components.spring-doc.cn
Deprecations
  • Deprecation of o.s.d.r2dbc.core.DatabaseClient and its support classes ConnectionAccessor, FetchSpec, SqlProvider and a few more. Named parameter support classes such as NamedParameterExpander are encapsulated by Spring R2DBC’s DatabaseClient implementation hence we’re not providing replacements as this was internal API in the first place. Use o.s.r2dbc.core.DatabaseClient and their Spring R2DBC replacements available from org.springframework.r2dbc.core. Entity-based methods (select/insert/update/delete) methods are available through R2dbcEntityTemplate which was introduced with version 1.1.spring-doc.cn
  • Deprecation of o.s.d.r2dbc.connectionfactory, o.s.d.r2dbc.connectionfactory.init, and o.s.d.r2dbc.connectionfactory.lookup packages. Use Spring R2DBC’s variant which you can find at o.s.r2dbc.connection.spring-doc.cn
  • Deprecation of o.s.d.r2dbc.convert.ColumnMapRowMapper. Use o.s.r2dbc.core.ColumnMapRowMapper instead.spring-doc.cn
  • Deprecation of binding support classes o.s.d.r2dbc.dialect.Bindings, BindMarker, BindMarkers, BindMarkersFactory and related types. Use replacements from org.springframework.r2dbc.core.binding.spring-doc.cn
  • Deprecation of BadSqlGrammarException, UncategorizedR2dbcException and exception translation at o.s.d.r2dbc.support. Spring R2DBC provides a slim exception translation variant without an SPI for now available through o.s.r2dbc.connection.ConnectionFactoryUtils#convertR2dbcException.spring-doc.cn
Usage of replacements provided by Spring R2DBC
To ease migration, several deprecated types are now subtypes of their replacements provided by Spring R2DBC. Spring Data R2DBC has changes several methods or introduced new methods accepting Spring R2DBC types. Specifically the following classes are changed:spring-doc.cn
We recommend that you review and update your imports if you work with these types directly.spring-doc.cn
Breaking Changes
  • OutboundRow and statement mappers switched from using SettableValue to Parameterspring-doc.cn
  • Repository factory support requires o.s.r2dbc.core.DatabaseClient instead of o.s.data.r2dbc.core.DatabaseClient.spring-doc.cn
Dependency Changes
To make use of Spring R2DBC, make sure to include the following dependency:spring-doc.cn
