For the latest stable version, please use Spring Data Relational 3.4.4! |
Mapping
Rich mapping support is provided by the BasicJdbcConverter
. BasicJdbcConverter
has a rich metadata model that allows mapping domain objects to a data row.
The mapping metadata model is populated by using annotations on your domain objects.
However, the infrastructure is not limited to using annotations as the only source of metadata information.
The BasicJdbcConverter
also lets you map objects to rows without providing any additional metadata, by following a set of conventions.
This section describes the features of the BasicJdbcConverter
, including how to use conventions for mapping objects to rows and how to override those conventions with annotation-based mapping metadata.
Read on the basics about Object Mapping Fundamentals before continuing with this chapter.
Convention-based Mapping
BasicJdbcConverter
has a few conventions for mapping objects to rows when no additional mapping metadata is provided.
The conventions are:
The short Java class name is mapped to the table name in the following manner. The
com.bigbank.SavingsAccount
class maps to theSAVINGS_ACCOUNT
table name. The same name mapping is applied for mapping fields to column names. For example, thefirstName
field maps to theFIRST_NAME
column. You can control this mapping by providing a customNamingStrategy
. See Mapping Configuration for more detail. Table and column names that are derived from property or class names are used in SQL statements without quotes by default. You can control this behavior by settingRelationalMappingContext.setForceQuote(true)
The converter uses any Spring Converters registered with
CustomConversions
to override the default mapping of object properties to row columns and values. -
The fields of an object are used to convert to and from columns in the row. Public
JavaBean
properties are not used. -
If you have a single non-zero-argument constructor whose constructor argument names match top-level column names of the row, that constructor is used. Otherwise, the zero-argument constructor is used. If there is more than one non-zero-argument constructor, an exception is thrown. Refer to Object Creation for further details.
Supported Types in Your Entity
The properties of the following types are currently supported:
All primitive types and their boxed types (
int
,float
,Integer
,Float
, and so on) -
Enums get mapped to their name.
String
java.util.Date
,java.time.LocalDate
,java.time.LocalDateTime
, andjava.time.LocalTime
Arrays and Collections of the types mentioned above can be mapped to columns of array type if your database supports that.
Anything your database driver accepts.
References to other entities. They are considered a one-to-one relationship, or an embedded type. It is optional for one-to-one relationship entities to have an
id
attribute. The table of the referenced entity is expected to have an additional column with a name based on the referencing entity see Back References. Embedded entities do not need anid
. If one is present it gets mapped as a normal attribute without any special meaning. -
Set<some entity>
is considered a one-to-many relationship. The table of the referenced entity is expected to have an additional column with a name based on the referencing entity see Back References. -
Map<simple type, some entity>
is considered a qualified one-to-many relationship. The table of the referenced entity is expected to have two additional columns: One named based on the referencing entity for the foreign key (see Back References) and one with the same name and an additional_key
suffix for the map key. -
List<some entity>
is mapped as aMap<Integer, some entity>
. The same additional columns are expected and the names used can be customized in the same way.For
List
,Set
, andMap
naming of the back reference can be controlled by implementingNamingStrategy.getReverseColumnName(RelationalPersistentEntity<?> owner)
andNamingStrategy.getKeyColumn(RelationalPersistentProperty property)
, respectively. Alternatively you may annotate the attribute with@MappedCollection(idColumn="your_column_name", keyColumn="your_key_column_name")
. Specifying a key column for aSet
has no effect. -
Types for which you registered suitable custom converters.
Mapping Annotation Overview
The RelationalConverter
can use metadata to drive the mapping of objects to rows.
The following annotations are available:
@Id
: Applied at the field level to mark the primary key. -
@Table
: Applied at the class level to indicate this class is a candidate for mapping to the database. You can specify the name of the table where the database is stored. -
@Transient
: By default, all fields are mapped to the row. This annotation excludes the field where it is applied from being stored in the database. Transient properties cannot be used within a persistence constructor as the converter cannot materialize a value for the constructor argument. -
@PersistenceCreator
: Marks a given constructor or static factory method — even a package protected one — to use when instantiating the object from the database. Constructor arguments are mapped by name to the values in the retrieved row. -
@Value
: This annotation is part of the Spring Framework. Within the mapping framework it can be applied to constructor arguments. This lets you use a Spring Expression Language statement to transform a key’s value retrieved in the database before it is used to construct a domain object. In order to reference a column of a given row one has to use expressions like:@Value("#root.myProperty")
where root refers to the root of the givenRow
@Column
: Applied at the field level to describe the name of the column as it is represented in the row, letting the name be different from the field name of the class. Names specified with a@Column
annotation are always quoted when used in SQL statements. For most databases, this means that these names are case-sensitive. It also means that you can use special characters in these names. However, this is not recommended, since it may cause problems with other tools. -
@Version
: Applied at field level is used for optimistic locking and checked for modification on save operations. The value isnull
(zero
for primitive types) is considered as marker for entities to be new. The initially stored value iszero
(one
for primitive types). The version gets incremented automatically on every update.
See Optimistic Locking for further reference.
The mapping metadata infrastructure is defined in the separate spring-data-commons
project that is technology-agnostic.
Specific subclasses are used in the JDBC support to support annotation based metadata.
Other strategies can also be put in place (if there is demand).
Referenced Entities
The handling of referenced entities is limited. This is based on the idea of aggregate roots as described above. If you reference another entity, that entity is, by definition, part of your aggregate. So, if you remove the reference, the previously referenced entity gets deleted. This also means references are 1-1 or 1-n, but not n-1 or n-m.
If you have n-1 or n-m references, you are, by definition, dealing with two separate aggregates.
References between those may be encoded as simple id
values, which map properly with Spring Data JDBC.
A better way to encode these, is to make them instances of AggregateReference
An AggregateReference
is a wrapper around an id value which marks that value as a reference to a different aggregate.
Also, the type of that aggregate is encoded in a type parameter.
Back References
All references in an aggregate result in a foreign key relationship in the opposite direction in the database. By default, the name of the foreign key column is the table name of the referencing entity.
Alternatively you may choose to have them named by the entity name of the referencing entity ignoring @Table
annotations.
You activate this behaviour by calling setForeignKeyNaming(ForeignKeyNaming.IGNORE_RENAMING)
on the RelationalMappingContext
For List
and Map
references an additional column is required for holding the list index or map key.
It is based on the foreign key column with an additional _KEY
suffix.
If you want a completely different way of naming these back references you may implement NamingStrategy.getReverseColumnName(RelationalPersistentEntity<?> owner)
in a way that fits your needs.
AggregateReference
class Person {
@Id long id;
AggregateReference<Person, Long> bestFriend;
Person p1, p2 = // some initialization
p1.bestFriend = AggregateReference.to(p2.id);
You should not include attributes in your entities to hold the actual value of a back reference, nor of the key column of maps or lists.
If you want these value to be available in your domain model we recommend to do this in a AfterConvertCallback
and store the values in transient values.
Naming Strategy
By convention, Spring Data applies a NamingStrategy
to determine table, column, and schema names defaulting to snake case.
An object property named firstName
becomes first_name
You can tweak that by providing a NamingStrategy
in your application context.
Override table names
When the table naming strategy does not match your database table names, you can override the table name with the Table
annotation.
The element value
of this annotation provides the custom table name.
The following example maps the MyEntity
class to the CUSTOM_TABLE_NAME
table in the database:
@Table("CUSTOM_TABLE_NAME")
class MyEntity {
@Id
Integer id;
String name;
You may use Spring Data’s SpEL support to dynamically create the table name. Once generated the table name will be cached, so it is dynamic per mapping context only.
Override column names
When the column naming strategy does not match your database table names, you can override the table name with the Column
annotation.
The element value
of this annotation provides the custom column name.
The following example maps the name
property of the MyEntity
class to the CUSTOM_COLUMN_NAME
column in the database:
class MyEntity {
@Id
Integer id;
@Column("CUSTOM_COLUMN_NAME")
String name;
The MappedCollection
annotation can be used on a reference type (one-to-one relationship) or on Sets, Lists, and Maps (one-to-many relationship).
idColumn
element of the annotation provides a custom name for the foreign key column referencing the id column in the other table.
In the following example the corresponding table for the MySubEntity
class has a NAME
column, and the CUSTOM_MY_ENTITY_ID_COLUMN_NAME
column of the MyEntity
id for relationship reasons:
class MyEntity {
@Id
Integer id;
@MappedCollection(idColumn = "CUSTOM_MY_ENTITY_ID_COLUMN_NAME")
Set<MySubEntity> subEntities;
class MySubEntity {
String name;
When using List
and Map
you must have an additional column for the position of a dataset in the List
or the key value of the entity in the Map
This additional column name may be customized with the keyColumn
Element of the MappedCollection
annotation:
class MyEntity {
@Id
Integer id;
@MappedCollection(idColumn = "CUSTOM_COLUMN_NAME", keyColumn = "CUSTOM_KEY_COLUMN_NAME")
List<MySubEntity> name;
class MySubEntity {
String name;
You may use Spring Data’s SpEL support to dynamically create column names. Once generated the names will be cached, so it is dynamic per mapping context only.
Embedded entities
Embedded entities are used to have value objects in your java data model, even if there is only one table in your database.
In the following example you see, that MyEntity
is mapped with the @Embedded
annotation.
The consequence of this is, that in the database a table my_entity
with the two columns id
and name
(from the EmbeddedEntity
class) is expected.
However, if the name
column is actually null
within the result set, the entire property embeddedEntity
will be set to null according to the onEmpty
of @Embedded
, which null
s objects when all nested properties are null
Opposite to this behavior USE_EMPTY
tries to create a new instance using either a default constructor or one that accepts nullable parameter values from the result set.
class MyEntity {
@Id
Integer id;
@Embedded(onEmpty = USE_NULL) (1)
EmbeddedEntity embeddedEntity;
class EmbeddedEntity {
String name;
1 | Null s embeddedEntity if name in null .
Use USE_EMPTY to instantiate embeddedEntity with a potential null value for the name property. |
If you need a value object multiple times in an entity, this can be achieved with the optional prefix
element of the @Embedded
annotation.
This element represents a prefix and is prepend for each column name in the embedded object.
Make use of the shortcuts
Embedded entities containing a Collection
or a Map
will always be considered non-empty since they will at least contain the empty collection or map.
Such an entity will therefore never be null
even when using @Embedded(onEmpty = USE_NULL).
Read Only Properties
Attributes annotated with @ReadOnlyProperty
will not be written to the database by Spring Data, but they will be read when an entity gets loaded.
Spring Data will not automatically reload an entity after writing it. Therefore, you have to reload it explicitly if you want to see data that was generated in the database for such columns.
If the annotated attribute is an entity or collection of entities, it is represented by one or more separate rows in separate tables. Spring Data will not perform any insert, delete or update for these rows.
Insert Only Properties
Attributes annotated with @InsertOnlyProperty
will only be written to the database by Spring Data during insert operations.
For updates these properties will be ignored.
@InsertOnlyProperty
is only supported for the aggregate root.
Customized Object Construction
The mapping subsystem allows the customization of the object construction by annotating a constructor with the @PersistenceConstructor
annotation.The values to be used for the constructor parameters are resolved in the following way:
If a parameter is annotated with the
@Value
annotation, the given expression is evaluated, and the result is used as the parameter value. -
If the Java type has a property whose name matches the given field of the input row, then its property information is used to select the appropriate constructor parameter to which to pass the input field value. This works only if the parameter name information is present in the Java
.class
files, which you can achieve by compiling the source with debug information or using the-parameters
command-line switch forjavac
in Java 8. -
Otherwise, a
MappingException
is thrown to indicate that the given constructor parameter could not be bound.
class OrderItem {
private @Id final String id;
private final int quantity;
private final double unitPrice;
OrderItem(String id, int quantity, double unitPrice) {
this.id = id;
this.quantity = quantity;
this.unitPrice = unitPrice;
// getters/setters omitted
Overriding Mapping with Explicit Converters
Spring Data allows registration of custom converters to influence how values are mapped in the database. Currently, converters are only applied on property-level, i.e. you can only convert single values in your domain to single values in the database and back. Conversion between complex objects and multiple columns isn’t supported.
Writing a Property by Using a Registered Spring Converter
The following example shows an implementation of a Converter
that converts from a Boolean
object to a String
value:
import org.springframework.core.convert.converter.Converter;
@WritingConverter
public class BooleanToStringConverter implements Converter<Boolean, String> {
public String convert(Boolean source) {
return source != null && source ? "T" : "F";
There are a couple of things to notice here: Boolean
and String
are both simple types hence Spring Data requires a hint in which direction this converter should apply (reading or writing).
By annotating this converter with @WritingConverter
you instruct Spring Data to write every Boolean
property as String
in the database.
Reading by Using a Spring Converter
that converts from a String
to a Boolean
value:
@ReadingConverter
public class StringToBooleanConverter implements Converter<String, Boolean> {
public Boolean convert(String source) {
return source != null && source.equalsIgnoreCase("T") ? Boolean.TRUE : Boolean.FALSE;
There are a couple of things to notice here: String
and Boolean
By annotating this converter with @ReadingConverter
you instruct Spring Data to convert every String
value from the database that should be assigned to a Boolean
property.
Registering Spring Converters with the JdbcConverter
class MyJdbcConfiguration extends AbstractJdbcConfiguration {
protected List<?> userConverters() {
return Arrays.asList(new BooleanToStringConverter(), new StringToBooleanConverter());
In previous versions of Spring Data JDBC it was recommended to directly overwrite AbstractJdbcConfiguration.jdbcCustomConversions() .
This is no longer necessary or even recommended, since that method assembles conversions intended for all databases, conversions registered by the Dialect used and conversions registered by the user.
If you are migrating from an older version of Spring Data JDBC and have AbstractJdbcConfiguration.jdbcCustomConversions() overwritten conversions from your Dialect will not get registered.
If you want to rely on Spring Boot to bootstrap Spring Data JDBC, but still want to override certain aspects of the configuration, you may want to expose beans of that type.
For custom conversions you may e.g. choose to register a bean of type |
JdbcValue
Value conversion uses JdbcValue
to enrich values propagated to JDBC operations with a java.sql.Types
type.
Register a custom write converter if you need to specify a JDBC-specific type instead of using type derivation.
This converter should convert the value to JdbcValue
which has a field for the value and for the actual JDBCType
