For the latest stable version, please use Spring Data Relational 3.4.4!spring-doc.cn
Object Mapping Fundamentals
This section covers the fundamentals of Spring Data object mapping, object creation, field and property access, mutability and immutability. Note, that this section only applies to Spring Data modules that do not use the object mapping of the underlying data store (like JPA). Also be sure to consult the store-specific sections for store-specific object mapping, like indexes, customizing column or field names or the like.spring-doc.cn
Core responsibility of the Spring Data object mapping is to create instances of domain objects and map the store-native data structures onto those. This means we need two fundamental steps:spring-doc.cn
  1. Instance creation by using one of the constructors exposed.spring-doc.cn
  2. Instance population to materialize all exposed properties.spring-doc.cn
Object creation
Spring Data automatically tries to detect a persistent entity’s constructor to be used to materialize objects of that type. The resolution algorithm works as follows:spring-doc.cn
  1. If there is a single static factory method annotated with @PersistenceCreator then it is used.spring-doc.cn
  2. If there is a single constructor, it is used.spring-doc.cn
  3. If there are multiple constructors and exactly one is annotated with @PersistenceCreator, it is used.spring-doc.cn
  4. If the type is a Java Record the canonical constructor is used.spring-doc.cn
  5. If there’s a no-argument constructor, it is used. Other constructors will be ignored.spring-doc.cn
The value resolution assumes constructor/factory method argument names to match the property names of the entity, i.e. the resolution will be performed as if the property was to be populated, including all customizations in mapping (different datastore column or field name etc.). This also requires either parameter names information available in the class file or an @ConstructorProperties annotation being present on the constructor.spring-doc.cn
The value resolution can be customized by using Spring Framework’s @Value value annotation using a store-specific SpEL expression. Please consult the section on store specific mappings for further details.spring-doc.cn
Object creation internals
To avoid the overhead of reflection, Spring Data object creation uses a factory class generated at runtime by default, which will call the domain classes constructor directly. I.e. for this example type:spring-doc.cn
class Person {
  Person(String firstname, String lastname) { … }
we will create a factory class semantically equivalent to this one at runtime:spring-doc.cn
class PersonObjectInstantiator implements ObjectInstantiator {
  Object newInstance(Object... args) {
    return new Person((String) args[0], (String) args[1]);
This gives us a roundabout 10% performance boost over reflection. For the domain class to be eligible for such optimization, it needs to adhere to a set of constraints:spring-doc.cn
If any of these criteria match, Spring Data will fall back to entity instantiation via reflection.spring-doc.cn
Property population
Once an instance of the entity has been created, Spring Data populates all remaining persistent properties of that class. Unless already populated by the entity’s constructor (i.e. consumed through its constructor argument list), the identifier property will be populated first to allow the resolution of cyclic object references. After that, all non-transient properties that have not already been populated by the constructor are set on the entity instance. For that we use the following algorithm:spring-doc.cn
  1. If the property is immutable but exposes a with… method (see below), we use the with… method to create a new entity instance with the new property value.spring-doc.cn
  2. If property access (i.e. access through getters and setters) is defined, we’re invoking the setter method.spring-doc.cn
  3. If the property is mutable we set the field directly.spring-doc.cn
  4. If the property is immutable we’re using the constructor to be used by persistence operations (see Object creation) to create a copy of the instance.spring-doc.cn
  5. By default, we set the field value directly.spring-doc.cn
Property population internals
Similarly to our optimizations in object construction we also use Spring Data runtime generated accessor classes to interact with the entity instance.spring-doc.cn
class Person {
  private final Long id;
  private String firstname;
  private @AccessType(Type.PROPERTY) String lastname;
  Person() {
    this.id = null;
  Person(Long id, String firstname, String lastname) {
    // Field assignments
  Person withId(Long id) {
    return new Person(id, this.firstname, this.lastame);
  void setLastname(String lastname) {
    this.lastname = lastname;
A generated Property Accessor
class PersonPropertyAccessor implements PersistentPropertyAccessor {
  private static final MethodHandle firstname;              (2)
  private Person person;                                    (1)
  public void setProperty(PersistentProperty property, Object value) {
    String name = property.getName();
    if ("firstname".equals(name)) {
      firstname.invoke(person, (String) value);             (2)
    } else if ("id".equals(name)) {
      this.person = person.withId((Long) value);            (3)
    } else if ("lastname".equals(name)) {
      this.person.setLastname((String) value);              (4)
1 PropertyAccessor’s hold a mutable instance of the underlying object. This is, to enable mutations of otherwise immutable properties.
2 By default, Spring Data uses field-access to read and write property values. As per visibility rules of private fields, MethodHandles are used to interact with fields.
3 The class exposes a withId(…) method that’s used to set the identifier, e.g. when an instance is inserted into the datastore and an identifier has been generated. Calling withId(…) creates a new Person object. All subsequent mutations will take place in the new instance leaving the previous untouched.
4 Using property-access allows direct method invocations without using MethodHandles.
This gives us a roundabout 25% performance boost over reflection. For the domain class to be eligible for such optimization, it needs to adhere to a set of constraints:spring-doc.cn
  • Types must not reside in the default or under the java package.spring-doc.cn
  • Types and their constructors must be publicspring-doc.cn
  • Types that are inner classes must be static.spring-doc.cn
  • The used Java Runtime must allow for declaring classes in the originating ClassLoader. Java 9 and newer impose certain limitations.spring-doc.cn
By default, Spring Data attempts to use generated property accessors and falls back to reflection-based ones if a limitation is detected.spring-doc.cn
Let’s have a look at the following entity:spring-doc.cn
A sample entity
class Person {
  private final @Id Long id;                                                (1)
  private final String firstname, lastname;                                 (2)
  private final LocalDate birthday;
  private final int age;                                                    (3)
  private String comment;                                                   (4)
  private @AccessType(Type.PROPERTY) String remarks;                        (5)
  static Person of(String firstname, String lastname, LocalDate birthday) { (6)
    return new Person(null, firstname, lastname, birthday,
      Period.between(birthday, LocalDate.now()).getYears());
  Person(Long id, String firstname, String lastname, LocalDate birthday, int age) { (6)
    this.id = id;
    this.firstname = firstname;
    this.birthday = birthday;
    this.age = age;
  Person withId(Long id) {                                                  (1)
    return new Person(id, this.firstname, this.lastname, this.birthday, this.age);
  void setRemarks(String remarks) {                                         (5)
    this.remarks = remarks;
1 The identifier property is final but set to null in the constructor. The class exposes a withId(…) method that’s used to set the identifier, e.g. when an instance is inserted into the datastore and an identifier has been generated. The original Person instance stays unchanged as a new one is created. The same pattern is usually applied for other properties that are store managed but might have to be changed for persistence operations. The wither method is optional as the persistence constructor (see 6) is effectively a copy constructor and setting the property will be translated into creating a fresh instance with the new identifier value applied.
2 The firstname and lastname properties are ordinary immutable properties potentially exposed through getters.
3 The age property is an immutable but derived one from the birthday property. With the design shown, the database value will trump the defaulting as Spring Data uses the only declared constructor. Even if the intent is that the calculation should be preferred, it’s important that this constructor also takes age as parameter (to potentially ignore it) as otherwise the property population step will attempt to set the age field and fail due to it being immutable and no with… method being present.
4 The comment property is mutable and is populated by setting its field directly.
5 The remarks property is mutable and is populated by invoking the setter method.
6 The class exposes a factory method and a constructor for object creation. The core idea here is to use factory methods instead of additional constructors to avoid the need for constructor disambiguation through @PersistenceCreator. Instead, defaulting of properties is handled within the factory method. If you want Spring Data to use the factory method for object instantiation, annotate it with @PersistenceCreator.
General recommendations
  • Try to stick to immutable objects — Immutable objects are straightforward to create as materializing an object is then a matter of calling its constructor only. Also, this avoids your domain objects to be littered with setter methods that allow client code to manipulate the objects state. If you need those, prefer to make them package protected so that they can only be invoked by a limited amount of co-located types. Constructor-only materialization is up to 30% faster than properties population.spring-doc.cn
  • Provide an all-args constructor — Even if you cannot or don’t want to model your entities as immutable values, there’s still value in providing a constructor that takes all properties of the entity as arguments, including the mutable ones, as this allows the object mapping to skip the property population for optimal performance.spring-doc.cn
  • Use factory methods instead of overloaded constructors to avoid @PersistenceCreator — With an all-argument constructor needed for optimal performance, we usually want to expose more application use case specific constructors that omit things like auto-generated identifiers etc. It’s an established pattern to rather use static factory methods to expose these variants of the all-args constructor.spring-doc.cn
  • Make sure you adhere to the constraints that allow the generated instantiator and property accessor classes to be used — spring-doc.cn
  • For identifiers to be generated, still use a final field in combination with an all-arguments persistence constructor (preferred) or a with… method — spring-doc.cn
  • Use Lombok to avoid boilerplate code — As persistence operations usually require a constructor taking all arguments, their declaration becomes a tedious repetition of boilerplate parameter to field assignments that can best be avoided by using Lombok’s @AllArgsConstructor.spring-doc.cn
Overriding Properties
Java allows a flexible design of domain classes where a subclass could define a property that is already declared with the same name in its superclass. Consider the following example:spring-doc.cn
public class SuperType {
   private CharSequence field;
   public SuperType(CharSequence field) {
      this.field = field;
   public CharSequence getField() {
      return this.field;
   public void setField(CharSequence field) {
      this.field = field;
public class SubType extends SuperType {
   private String field;
   public SubType(String field) {
      super(field);
      this.field = field;
   public String getField() {
      return this.field;
   public void setField(String field) {
      this.field = field;
      // optional
      super.setField(field);
Both classes define a field using assignable types. SubType however shadows SuperType.field. Depending on the class design, using the constructor could be the only default approach to set SuperType.field. Alternatively, calling super.setField(…) in the setter could set the field in SuperType. All these mechanisms create conflicts to some degree because the properties share the same name yet might represent two distinct values. Spring Data skips super-type properties if types are not assignable. That is, the type of the overridden property must be assignable to its super-type property type to be registered as override, otherwise the super-type property is considered transient. We generally recommend using distinct property names.spring-doc.cn
Spring Data modules generally support overridden properties holding different values. From a programming model perspective there are a few things to consider:spring-doc.cn
  1. Which property should be persisted (default to all declared properties)? You can exclude properties by annotating these with @Transient.spring-doc.cn
  2. How to represent properties in your data store? Using the same field/column name for different values typically leads to corrupt data so you should annotate least one of the properties using an explicit field/column name.spring-doc.cn
  3. Using @AccessType(PROPERTY) cannot be used as the super-property cannot be generally set without making any further assumptions of the setter implementation.spring-doc.cn
Kotlin support
Spring Data adapts specifics of Kotlin to allow object creation and mutation.spring-doc.cn
Kotlin object creation
Kotlin classes are supported to be instantiated, all classes are immutable by default and require explicit property declarations to define mutable properties.spring-doc.cn
  1. If there is a constructor that is annotated with @PersistenceCreator, it is used.spring-doc.cn
  2. If the type is a Kotlin data class the primary constructor is used.spring-doc.cn
  3. If there is a single static factory method annotated with @PersistenceCreator then it is used.spring-doc.cn
  4. If there is a single constructor, it is used.spring-doc.cn
  5. If there are multiple constructors and exactly one is annotated with @PersistenceCreator, it is used.spring-doc.cn
  6. If the type is a Java Record the canonical constructor is used.spring-doc.cn
  7. If there’s a no-argument constructor, it is used. Other constructors will be ignored.spring-doc.cn
Consider the following data class Person:spring-doc.cn
data class Person(val id: String, val name: String)
The class above compiles to a typical class with an explicit constructor. We can customize this class by adding another constructor and annotate it with @PersistenceCreator to indicate a constructor preference:spring-doc.cn
data class Person(var id: String, val name: String) {
    @PersistenceCreator
    constructor(id: String) : this(id, "unknown")
Kotlin supports parameter optionality by allowing default values to be used if a parameter is not provided. When Spring Data detects a constructor with parameter defaulting, then it leaves these parameters absent if the data store does not provide a value (or simply returns null) so Kotlin can apply parameter defaulting. Consider the following class that applies parameter defaulting for namespring-doc.cn
data class Person(var id: String, val name: String = "unknown")
Every time the name parameter is either not part of the result or its value is null, then the name defaults to unknown.spring-doc.cn
Delegated properties are not supported with Spring Data. The mapping metadata filters delegated properties for Kotlin Data classes. In all other cases you can exclude synthetic fields for delegated properties by annotating the property with @delegate:org.springframework.data.annotation.Transient.
Property population of Kotlin data classes
In Kotlin, all classes are immutable by default and require explicit property declarations to define mutable properties. Consider the following data class Person:spring-doc.cn
This class is effectively immutable. It allows creating new instances as Kotlin generates a copy(…) method that creates new object instances copying all property values from the existing object and applying property values provided as arguments to the method.spring-doc.cn
Kotlin Overriding Properties
Kotlin allows declaring property overrides to alter properties in subclasses.spring-doc.cn
open class SuperType(open var field: Int)
class SubType(override var field: Int = 1) :
	SuperType(field) {
Such an arrangement renders two properties with the name field. Kotlin generates property accessors (getters and setters) for each property in each class. Effectively, the code looks like as follows:spring-doc.cn
   private int field;
   public SuperType(int field) {
      this.field = field;
   public int getField() {
      return this.field;
   public void setField(int field) {
      this.field = field;
public final class SubType extends SuperType {
   private int field;
   public SubType(int field) {
      super(field);
      this.field = field;
      return this.field;
      this.field = field;
Getters and setters on SubType set only SubType.field and not SuperType.field. In such an arrangement, using the constructor is the only default approach to set SuperType.field. Adding a method to SubType to set SuperType.field via this.SuperType.field = … is possible but falls outside of supported conventions. Property overrides create conflicts to some degree because the properties share the same name yet might represent two distinct values. We generally recommend using distinct property names.spring-doc.cn
  3. Using @AccessType(PROPERTY) cannot be used as the super-property cannot be set.spring-doc.cn
Kotlin Value Classes
Kotlin Value Classes are designed for a more expressive domain model to make underlying concepts explicit. Spring Data can read and write types that define properties using Value Classes.spring-doc.cn
Consider the following domain model:spring-doc.cn
@JvmInline
value class EmailAddress(val theAddress: String)                                    (1)
data class Contact(val id: String, val name:String, val emailAddress: EmailAddress) (2)
1 A simple value class with a non-nullable value type.
2 Data class defining a property using the EmailAddress value class.
Non-nullable properties using non-primitive value types are flattened in the compiled class to the value type. Nullable primitive value types or nullable value-in-value types are represented with their wrapper type and that affects how value types are represented in the database.
