For the latest stable version, please use Spring Data Relational 3.4.4!spring-doc.cn
Extensions
Kotlin extensions provide the ability to extend existing classes with additional functionality. Spring Data Kotlin APIs use these extensions to add new Kotlin-specific conveniences to existing Spring APIs.spring-doc.cn
Keep in mind that Kotlin extensions need to be imported to be used. Similar to static imports, an IDE should automatically suggest the import in most cases.spring-doc.cn
For example, Kotlin reified type parameters provide a workaround for JVM generics type erasure, and Spring Data provides some extensions to take advantage of this feature. This allows for a better Kotlin API.spring-doc.cn
