For the latest stable version, please use Spring Data Relational 3.4.4!spring-doc.cn
Requirements
Spring Data supports Kotlin 1.3 and requires kotlin-stdlib (or one of its variants, such as kotlin-stdlib-jdk8) and kotlin-reflect to be present on the classpath. Those are provided by default if you bootstrap a Kotlin project via start.spring.io.spring-doc.cn
