For the latest stable version, please use Spring Data Relational 3.4.4!spring-doc.cn
Persisting Entities
Saving an aggregate can be performed with the CrudRepository.save(…) method. If the aggregate is new, this results in an insert for the aggregate root, followed by insert statements for all directly or indirectly referenced entities.spring-doc.cn
If the aggregate root is not new, all referenced entities get deleted, the aggregate root gets updated, and all referenced entities get inserted again. Note that whether an instance is new is part of the instance’s state.spring-doc.cn
This approach has some obvious downsides. If only few of the referenced entities have been actually changed, the deletion and insertion is wasteful. While this process could and probably will be improved, there are certain limitations to what Spring Data JDBC can offer. It does not know the previous state of an aggregate. So any update process always has to take whatever it finds in the database and make sure it converts it to whatever is the state of the entity passed to the save method.
See also Entity State Detection for further details.spring-doc.cn
Loading Aggregates
Spring Data JDBC offers two ways how it can load aggregates:spring-doc.cn
  1. The traditional and before version 3.2 the only way is really simple: Each query loads the aggregate roots, independently if the query is based on a CrudRepository method, a derived query or a annotated query. If the aggregate root references other entities those are loaded with separate statements.spring-doc.cn
  2. Spring Data JDBC 3.2 allows the use of Single Query Loading. With this an arbitrary number of aggregates can be fully loaded with a single SQL query. This should be significantly more efficient, especially for complex aggregates, consisting of many entities.spring-doc.cn
    Currently, Single Query Loading is restricted in different ways:spring-doc.cn
    1. The aggregate must not have nested collections, this includes Map. The plan is to remove this constraint in the future.spring-doc.cn
    2. The aggregate must not use AggregateReference or embedded entities. The plan is to remove this constraint in the future.spring-doc.cn
    3. The database dialect must support it.Of the dialects provided by Spring Data JDBC all but H2 and HSQL support this. H2 and HSQL don’t support analytic functions (aka windowing functions).spring-doc.cn
    4. It only works for the find methods in CrudRepository, not for derived queries and not for annotated queries. The plan is to remove this constraint in the future.spring-doc.cn
    5. Single Query Loading needs to be enabled in the JdbcMappingContext, by calling setSingleQueryLoadingEnabled(true)spring-doc.cn
If any condition is not fulfilled Spring Data JDBC falls back to the default approach of loading aggregates.spring-doc.cn
Single Query Loading is to be considered experimental. We appreciate feedback on how it works for you.
While Single Query Loading can be abbreviated as SQL, but we highly discourage doing so since confusion with Structured Query Language is almost guaranteed.
ID Generation
Spring Data uses the identifer property to identify entities. The ID of an entity must be annotated with Spring Data’s @Id annotation.spring-doc.cn
When your database has an auto-increment column for the ID column, the generated value gets set in the entity after inserting it into the database.spring-doc.cn
Spring Data does not attempt to insert values of identifier columns when the entity is new and the identifier value defaults to its initial value. That is 0 for primitive types and null if the identifier property uses a numeric wrapper type such as Long.spring-doc.cn
Entity State Detection explains in detail the strategies to detect whether an entity is new or whether it is expected to exist in your database.spring-doc.cn
One important constraint is that, after saving an entity, the entity must not be new anymore. Note that whether an entity is new is part of the entity’s state. With auto-increment columns, this happens automatically, because the ID gets set by Spring Data with the value from the ID column.spring-doc.cn
Template API
As an alternative to repositories Spring Data JDBC offers the JdbcAggregateTemplate as a more direct means to load and persist entities in a relational database. To a large extent, repositories use JdbcAggregateTemplate to implement their features.spring-doc.cn
This section highlights only the most interesting parts of the JdbcAggregateTemplate. For a more complete overview, see the JavaDoc of JdbcAggregateTemplate.spring-doc.cn
Accessing the JdbcAggregateTemplate
JdbcAggregateTemplate is intended to be used as a Spring bean. If you have set up your application to include Spring Data JDBC, you can configure a dependency on JdbcAggregateTemplate in any Spring bean, and the Spring Framework injects a properly configured instance.spring-doc.cn
This includes fragments you use to implement custom methods for your Spring Data Repositories, letting you to use JdbcAggregateTemplate to customize and extend your repositories.spring-doc.cn
Persisting
JdbcAggregateTemplate offers three types of methods for persisting entities: save, insert, and update. Each comes in two flavors: Operating on single aggregates, named exactly as mentioned above, and with an All suffix operation on an Iterable.spring-doc.cn
save does the same as the method of same name in a repository.spring-doc.cn
insert and update skip the test if the entity is new and assume a new or existing aggregate as indicated by their name.spring-doc.cn
Querying
JdbcAggregateTemplate offers a considerable array of methods for querying aggregates and about collections of aggregates. There is one type of method that requires special attention. That’s the methods taking a Query as an argument. They allow the execution of programmatically constructed queries, as follows:spring-doc.cn
template.findOne(query(where("name").is("Gandalf")), Person.class);
The Query returned by the query method defines the list of columns to select, a where clause (through a CriteriaDefinition), and specification of limit and offset clauses. For details of the Query class, see its JavaDoc.spring-doc.cn
The Criteria class, of which where is a static member, provides implementations of org.springframework.data.relational.core.query.CriteriaDefinition[], which represent the where-clause of the query.spring-doc.cn
Methods for the Criteria Class
The Criteria class provides the following methods, all of which correspond to SQL operators:spring-doc.cn
  • Criteria and (String column): Adds a chained Criteria with the specified property to the current Criteria and returns the newly created one.spring-doc.cn
  • Criteria or (String column): Adds a chained Criteria with the specified property to the current Criteria and returns the newly created one.spring-doc.cn
  • Criteria greaterThan (Object o): Creates a criterion by using the > operator.spring-doc.cn
  • Criteria greaterThanOrEquals (Object o): Creates a criterion by using the >= operator.spring-doc.cn
  • Criteria in (Object…​ o): Creates a criterion by using the IN operator for a varargs argument.spring-doc.cn
  • Criteria in (Collection<?> collection): Creates a criterion by using the IN operator using a collection.spring-doc.cn
  • Criteria is (Object o): Creates a criterion by using column matching (property = value).spring-doc.cn
  • Criteria isNull (): Creates a criterion by using the IS NULL operator.spring-doc.cn
  • Criteria isNotNull (): Creates a criterion by using the IS NOT NULL operator.spring-doc.cn
  • Criteria lessThan (Object o): Creates a criterion by using the < operator.spring-doc.cn
  • Criteria lessThanOrEquals (Object o): Creates a criterion by using the operator.spring-doc.cn
  • Criteria like (Object o): Creates a criterion by using the LIKE operator without escape character processing.spring-doc.cn
  • Criteria not (Object o): Creates a criterion by using the != operator.spring-doc.cn
  • Criteria notIn (Object…​ o): Creates a criterion by using the NOT IN operator for a varargs argument.spring-doc.cn
  • Criteria notIn (Collection<?> collection): Creates a criterion by using the NOT IN operator using a collection.spring-doc.cn
Optimistic Locking
Spring Data supports optimistic locking by means of a numeric attribute that is annotated with @Version on the aggregate root. Whenever Spring Data saves an aggregate with such a version attribute two things happen:spring-doc.cn
  • The update statement for the aggregate root will contain a where clause checking that the version stored in the database is actually unchanged.spring-doc.cn
  • If this isn’t the case an OptimisticLockingFailureException will be thrown.spring-doc.cn
Also, the version attribute gets increased both in the entity and in the database so a concurrent action will notice the change and throw an OptimisticLockingFailureException if applicable as described above.spring-doc.cn
This process also applies to inserting new aggregates, where a null or 0 version indicates a new instance and the increased instance afterwards marks the instance as not new anymore, making this work rather nicely with cases where the id is generated during object construction for example when UUIDs are used.spring-doc.cn
During deletes the version check also applies but no version is increased.spring-doc.cn
