此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 spring-cloud-contract 4.2.1spring-doc.cadn.net.cn
YML 架构
您可以在下面找到 YAML 协定的 JSON 架构定义。spring-doc.cadn.net.cn
  "type" : "object",
  "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract",
  "properties" : {
    "request" : {
      "type" : "object",
      "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:Request",
      "properties" : {
        "method" : {
          "type" : "string"
        "url" : {
          "type" : "string"
        "urlPath" : {
          "type" : "string"
        "queryParameters" : {
          "type" : "object",
          "additionalProperties" : {
            "type" : "object",
            "id" : "urn:jsonschema:java:lang:Object"
        "headers" : {
          "type" : "object",
            "type" : "object",
            "$ref" : "urn:jsonschema:java:lang:Object"
        "cookies" : {
          "type" : "object",
            "type" : "object",
        "body" : {
          "type" : "object",
        "bodyFromFile" : {
          "type" : "string"
        "bodyFromFileAsBytes" : {
          "type" : "string"
        "matchers" : {
          "type" : "object",
          "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:StubMatchers",
          "properties" : {
            "url" : {
              "type" : "object",
              "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:KeyValueMatcher",
              "properties" : {
                "key" : {
                  "type" : "string"
                "regex" : {
                  "type" : "string"
                "predefined" : {
                  "type" : "string",
                  "enum" : [ "only_alpha_unicode", "number", "any_double", "any_boolean", "ip_address", "hostname", "email", "url", "uuid", "iso_date", "iso_date_time", "iso_time", "iso_8601_with_offset", "non_empty", "non_blank" ]
                "command" : {
                  "type" : "string"
                "regexType" : {
                  "type" : "string",
                  "enum" : [ "as_integer", "as_double", "as_float", "as_long", "as_short", "as_boolean", "as_string" ]
            "body" : {
              "type" : "array",
              "items" : {
                "type" : "object",
                "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:BodyStubMatcher",
                "properties" : {
                  "path" : {
                    "type" : "string"
                  "type" : {
                    "type" : "string",
                    "enum" : [ "by_date", "by_time", "by_timestamp", "by_regex", "by_equality", "by_type", "by_null" ]
                  "value" : {
                    "type" : "string"
                  "predefined" : {
                    "type" : "string",
                  "minOccurrence" : {
                    "type" : "integer"
                  "maxOccurrence" : {
                    "type" : "integer"
                  "regexType" : {
                    "type" : "string",
            "headers" : {
              "type" : "array",
              "items" : {
                "type" : "object",
                "$ref" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:KeyValueMatcher"
              "type" : "array",
              "items" : {
                "type" : "object",
                "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:QueryParameterMatcher",
                "properties" : {
                  "key" : {
                    "type" : "string"
                  "type" : {
                    "type" : "string",
                    "enum" : [ "equal_to", "containing", "matching", "not_matching", "equal_to_json", "equal_to_xml", "absent", "binary_equal_to" ]
                  "value" : {
                    "type" : "object",
            "cookies" : {
              "type" : "array",
              "items" : {
                "type" : "object",
            "multipart" : {
              "type" : "object",
              "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:MultipartStubMatcher",
              "properties" : {
                "params" : {
                  "type" : "array",
                  "items" : {
                    "type" : "object",
                "named" : {
                  "type" : "array",
                  "items" : {
                    "type" : "object",
                    "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:MultipartNamedStubMatcher",
                    "properties" : {
                      "paramName" : {
                        "type" : "string"
                      "fileName" : {
                        "type" : "object",
                        "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:ValueMatcher",
                        "properties" : {
                          "regex" : {
                            "type" : "string"
                          "predefined" : {
                            "type" : "string",
                      "fileContent" : {
                        "type" : "object",
                        "$ref" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:ValueMatcher"
                      "contentType" : {
                        "type" : "object",
        "multipart" : {
          "type" : "object",
          "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:Multipart",
          "properties" : {
            "params" : {
              "type" : "object",
                "type" : "string"
            "named" : {
              "type" : "array",
              "items" : {
                "type" : "object",
                "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:Named",
                "properties" : {
                  "paramName" : {
                    "type" : "string"
                  "fileName" : {
                    "type" : "string"
                  "fileContent" : {
                    "type" : "string"
                  "fileContentAsBytes" : {
                    "type" : "string"
                  "fileContentFromFileAsBytes" : {
                    "type" : "string"
                  "contentType" : {
                    "type" : "string"
                  "fileNameCommand" : {
                    "type" : "string"
                  "fileContentCommand" : {
                    "type" : "string"
                  "contentTypeCommand" : {
                    "type" : "string"
    "response" : {
      "type" : "object",
      "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:Response",
      "properties" : {
        "status" : {
          "type" : "integer"
        "headers" : {
          "type" : "object",
            "type" : "object",
        "cookies" : {
          "type" : "object",
            "type" : "object",
        "body" : {
          "type" : "object",
        "bodyFromFile" : {
          "type" : "string"
          "type" : "string"
        "matchers" : {
          "type" : "object",
          "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:TestMatchers",
          "properties" : {
            "body" : {
              "type" : "array",
              "items" : {
                "type" : "object",
                "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:BodyTestMatcher",
                "properties" : {
                  "path" : {
                    "type" : "string"
                  "type" : {
                    "type" : "string",
                    "enum" : [ "by_date", "by_time", "by_timestamp", "by_regex", "by_equality", "by_type", "by_command", "by_null" ]
                  "value" : {
                    "type" : "string"
                  "minOccurrence" : {
                    "type" : "integer"
                  "maxOccurrence" : {
                    "type" : "integer"
                  "predefined" : {
                    "type" : "string",
                  "regexType" : {
                    "type" : "string",
            "headers" : {
              "type" : "array",
              "items" : {
                "type" : "object",
                "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:TestHeaderMatcher",
                "properties" : {
                  "key" : {
                    "type" : "string"
                  "regex" : {
                    "type" : "string"
                  "command" : {
                    "type" : "string"
                  "predefined" : {
                    "type" : "string",
                  "regexType" : {
                    "type" : "string",
            "cookies" : {
              "type" : "array",
              "items" : {
                "type" : "object",
                "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:TestCookieMatcher",
                "properties" : {
                  "key" : {
                    "type" : "string"
                  "regex" : {
                    "type" : "string"
                  "command" : {
                    "type" : "string"
                  "predefined" : {
                    "type" : "string",
                  "regexType" : {
                    "type" : "string",
        "async" : {
          "type" : "boolean"
        "fixedDelayMilliseconds" : {
          "type" : "integer"
    "input" : {
      "type" : "object",
      "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:Input",
      "properties" : {
        "triggeredBy" : {
          "type" : "string"
        "assertThat" : {
          "type" : "string"
    "outputMessage" : {
      "type" : "object",
      "id" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:OutputMessage",
      "properties" : {
        "sentTo" : {
          "type" : "string"
        "headers" : {
          "type" : "object",
            "type" : "object",
        "body" : {
          "type" : "object",
        "bodyFromFile" : {
          "type" : "string"
          "type" : "string"
        "assertThat" : {
          "type" : "string"
        "matchers" : {
          "type" : "object",
          "$ref" : "urn:jsonschema:org:springframework:cloud:contract:verifier:converter:YamlContract:TestMatchers"
    "description" : {
      "type" : "string"
    "label" : {
      "type" : "string"
    "name" : {
      "type" : "string"
    "priority" : {
      "type" : "integer"
    "ignored" : {
      "type" : "boolean"
    "inProgress" : {
      "type" : "boolean"
    "metadata" : {
      "type" : "object",
        "type" : "object",
