此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Security 6.4.3! |
用户名/密码身份验证
对用户进行身份验证的最常见方法之一是验证用户名和密码。 Spring Security 为使用用户名和密码进行身份验证提供了全面的支持。
您可以使用以下内容配置用户名和密码身份验证:
Java
XML
Kotlin
@EnableWebSecurity
public class SecurityConfig {
public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
http
.authorizeHttpRequests((authorize) -> authorize
.anyRequest().authenticated()
.httpBasic(Customizer.withDefaults())
.formLogin(Customizer.withDefaults());
return http.build();
public UserDetailsService userDetailsService() {
UserDetails userDetails = User.withDefaultPasswordEncoder()
.username("user")
.password("password")
.roles("USER")
return new InMemoryUserDetailsManager(userDetails);
<http>
<intercept-url pattern="/**" access="authenticated"/>
<form-login />
<http-basic />
<user-service>
<user name="user"
password="{noop}password"
authorities="ROLE_USER" />
</user-service>
</http>
import org.springframework.security.config.annotation.web.invoke
@EnableWebSecurity
fun securityFilterChain(http: HttpSecurity): SecurityFilterChain {
http {
authorizeHttpRequests {
formLogin { }
httpBasic { }
return http.build()
fun userDetailsService(): UserDetailsService {
val user = User.withDefaultPasswordEncoder()
.username("user")
.roles("USER")
.build()
return InMemoryUserDetailsManager(user)
The preceding configuration automatically registers an in-memory UserDetailsService
with the SecurityFilterChain
, registers the DaoAuthenticationProvider
with the default AuthenticationManager
, and enables Form Login and HTTP Basic authentication.
To learn more about username/password authentication, consider the following use cases:
I want to learn how Form Login works
I want to manage users in memory
I want to manage users in a database
I want to manage users in LDAP
I want to publish an AuthenticationManager
bean for custom authentication
Publish an AuthenticationManager
bean
A fairly common requirement is publishing an AuthenticationManager
bean to allow for custom authentication, such as in a @Service
or Spring MVC @Controller
For example, you may want to authenticate users via a REST API instead of using Form Login.
You can publish such an AuthenticationManager
for custom authentication scenarios using the following configuration:
Publish AuthenticationManager
bean for Custom Authentication
Java
XML
Kotlin
@EnableWebSecurity
http
.requestMatchers("/login").permitAll()
public AuthenticationManager authenticationManager(
UserDetailsService userDetailsService,
PasswordEncoder passwordEncoder) {
DaoAuthenticationProvider authenticationProvider = new DaoAuthenticationProvider();
authenticationProvider.setUserDetailsService(userDetailsService);
authenticationProvider.setPasswordEncoder(passwordEncoder);
return new ProviderManager(authenticationProvider);
.username("user")
.roles("USER")
public PasswordEncoder passwordEncoder() {
return PasswordEncoderFactories.createDelegatingPasswordEncoder();
<http>
<intercept-url pattern="/login" access="permitAll"/>
<bean id="authenticationManager"
class="org.springframework.security.authentication.ProviderManager">
<constructor-arg>
<bean class="org.springframework.security.authentication.dao.DaoAuthenticationProvider">
<property name="userDetailsService" ref="userDetailsService" />
<property name="passwordEncoder" ref="passwordEncoder" />
</bean>
</constructor-arg>
</bean>
<user-service id="userDetailsService">
<user name="user"
</user-service>
<bean id="passwordEncoder"
class="org.springframework.security.crypto.factory.PasswordEncoderFactories" factory-method="createDelegatingPasswordEncoder"/>
</http>
@EnableWebSecurity
http {
authorize("/login", permitAll)
return http.build()
fun authenticationManager(
userDetailsService: UserDetailsService,
passwordEncoder: PasswordEncoder): AuthenticationManager {
val authenticationProvider = DaoAuthenticationProvider()
return ProviderManager(authenticationProvider)
.username("user")
.roles("USER")
.build()
fun passwordEncoder(): PasswordEncoder {
With the preceding configuration in place, you can create a @RestController
that uses the AuthenticationManager
as follows:
Create a @RestController
for Authentication
Java
Kotlin
@RestController
public class LoginController {
private final AuthenticationManager authenticationManager;
public LoginController(AuthenticationManager authenticationManager) {
this.authenticationManager = authenticationManager;
@PostMapping("/login")
public ResponseEntity<Void> login(@RequestBody LoginRequest loginRequest) {
Authentication authenticationRequest =
UsernamePasswordAuthenticationToken.unauthenticated(loginRequest.username(), loginRequest.password());
Authentication authenticationResponse =
this.authenticationManager.authenticate(authenticationRequest);
public record LoginRequest(String username, String password) {
@RestController
class LoginController(val authenticationManager: AuthenticationManager) {
fun login(@RequestBody loginRequest: LoginRequest): ResponseEntity<Void> {
val authenticationRequest =
loginRequest.username, loginRequest.password)
val authenticationResponse =
data class LoginRequest(val username: String, val password: String)
In this example, it is your responsibility to save the authenticated user in the SecurityContextRepository
if needed.
For example, if using the HttpSession
to persist the SecurityContext
between requests, you can use HttpSessionSecurityContextRepository
Customize the AuthenticationManager
Normally, Spring Security builds an AuthenticationManager
internally composed of a DaoAuthenticationProvider
for username/password authentication.
In certain cases, it may still be desired to customize the instance of AuthenticationManager
used by Spring Security.
For example, you may need to simply disable credential erasure for cached users.
To do this, you can take advantage of the fact that the AuthenticationManagerBuilder
used to build Spring Security’s global AuthenticationManager
is published as a bean.
You can configure the builder as follows:
Configure global AuthenticationManagerBuilder
Java
Kotlin
@EnableWebSecurity
// Return a UserDetailsService that caches users
@Autowired
public void configure(AuthenticationManagerBuilder builder) {
builder.eraseCredentials(false);
@EnableWebSecurity
return http.build()
@Autowired
fun configure(builder: AuthenticationManagerBuilder) {
Alternatively, you may configure a local AuthenticationManager
to override the global one.
Configure local AuthenticationManager
for Spring Security
Java
XML
Kotlin
@EnableWebSecurity
http
.authenticationManager(authenticationManager());
private AuthenticationManager authenticationManager() {
authenticationProvider.setUserDetailsService(userDetailsService());
authenticationProvider.setPasswordEncoder(passwordEncoder());
ProviderManager providerManager = new ProviderManager(authenticationProvider);
providerManager.setEraseCredentialsAfterAuthentication(false);
return providerManager;
private UserDetailsService userDetailsService() {
.username("user")
.roles("USER")
private PasswordEncoder passwordEncoder() {
<http authentication-manager-ref="authenticationManager">
<form-login />
<http-basic />
<constructor-arg>
</bean>
</constructor-arg>
</bean>
<user name="user"
</user-service>
</http>
@EnableWebSecurity
http {
formLogin { }
httpBasic { }
authenticationManager = authenticationManager()
return http.build()
fun authenticationManager(): AuthenticationManager {
val providerManager = ProviderManager(authenticationProvider)
providerManager.eraseCredentialsAfterAuthentication = false
private fun userDetailsService(): UserDetailsService {
.username("user")
.roles("USER")
.build()
private fun passwordEncoder(): PasswordEncoder {
Section Summary
