此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Security 6.4.3! |
Kotlin 配置
Spring Security Kotlin 配置从 Spring Security 5.3 开始可用。 它允许用户使用本机 Kotlin DSL 配置 Spring Security。
Spring Security 提供了一个示例应用程序来演示 Spring Security Kotlin 配置的使用。 |
HttpSecurity 安全
Spring Security 如何知道我们要要求所有用户都经过身份验证?
Spring Security 如何知道我们想要支持基于表单的身份验证?
有一个配置类(称为SecurityFilterChain
),该 API 的调用正在后台调用。
它使用以下默认实现进行配置:
import org.springframework.security.config.annotation.web.invoke
http {
authorizeHttpRequests {
formLogin { }
httpBasic { }
return http.build()
Make sure to import the invoke
function in your class, as the IDE will not always auto-import the method, causing compilation issues.
The default configuration (shown in the preceding listing):
Ensures that any request to our application requires the user to be authenticated
Lets users authenticate with form-based login
Lets users authenticate with HTTP Basic authentication
Note that this configuration parallels the XML namespace configuration:
<http>
<intercept-url pattern="/**" access="authenticated"/>
<form-login />
<http-basic />
</http>
Multiple HttpSecurity Instances
We can configure multiple HttpSecurity
instances, just as we can have multiple <http>
blocks.
The key is to register multiple SecurityFilterChain
s.
The following example has a different configuration for URLs that start with /api/
@EnableWebSecurity
class MultiHttpSecurityConfig {
@Bean (1)
public fun userDetailsService(): UserDetailsService {
val users: User.UserBuilder = User.withDefaultPasswordEncoder()
val manager = InMemoryUserDetailsManager()
manager.createUser(users.username("user").password("password").roles("USER").build())
manager.createUser(users.username("admin").password("password").roles("USER","ADMIN").build())
return manager
@Order(1) (2)
open fun apiFilterChain(http: HttpSecurity): SecurityFilterChain {
http {
securityMatcher("/api/**") (3)
authorize(anyRequest, hasRole("ADMIN"))
httpBasic { }
return http.build()
@Bean (4)
open fun formLoginFilterChain(http: HttpSecurity): SecurityFilterChain {
http {
formLogin { }
return http.build()
1
Configure Authentication as usual.
2
Create an instance of SecurityFilterChain
that contains @Order
to specify which SecurityFilterChain
should be considered first.
3
The http.securityMatcher
states that this HttpSecurity
is applicable only to URLs that start with /api/
4
Create another instance of SecurityFilterChain
If the URL does not start with /api/
, this configuration is used.
This configuration is considered after apiFilterChain
, since it has an @Order
value after 1
(no @Order
defaults to last).
