WebSocket Security
Spring Security 4 added support for securing Spring’s WebSocket support. This section describes how to use Spring Security’s WebSocket support.spring-doc.cn
Direct JSR-356 Support
Spring Security does not provide direct JSR-356 support, because doing so would provide little value. This is because the format is unknown, and there is little Spring can do to secure an unknown format. Additionally, JSR-356 does not provide a way to intercept messages, so security would be invasive.spring-doc.cn
WebSocket Authentication
WebSockets reuse the same authentication information that is found in the HTTP request when the WebSocket connection was made. This means that the Principal on the HttpServletRequest will be handed off to WebSockets. If you are using Spring Security, the Principal on the HttpServletRequest is overridden automatically.spring-doc.cn
More concretely, to ensure a user has authenticated to your WebSocket application, all that is necessary is to ensure that you setup Spring Security to authenticate your HTTP based web application.spring-doc.cn
WebSocket Authorization
Spring Security 4.0 has introduced authorization support for WebSockets through the Spring Messaging abstraction.spring-doc.cn
In Spring Security 5.8, this support has been refreshed to use the AuthorizationManager API.spring-doc.cn
To configure authorization using Java Configuration, simply include the @EnableWebSocketSecurity annotation and publish an AuthorizationManager<Message<?>> bean or in XML use the use-authorization-manager attribute. One way to do this is by using the AuthorizationManagerMessageMatcherRegistry to specify endpoint patterns like so:spring-doc.cn
@EnableWebSocketSecurity (1) (2)
public class WebSocketSecurityConfig {
    AuthorizationManager<Message<?>> messageAuthorizationManager(MessageMatcherDelegatingAuthorizationManager.Builder messages) {
        messages
                .simpDestMatchers("/user/**").authenticated() (3)
        return messages.build();
open class WebSocketSecurityConfig { (1) (2)
    fun messageAuthorizationManager(messages: MessageMatcherDelegatingAuthorizationManager.Builder): AuthorizationManager<Message<?>> {
        messages.simpDestMatchers("/user/**").authenticated() (3)
1 Any inbound CONNECT message requires a valid CSRF token to enforce the Same Origin Policy.
2 The SecurityContextHolder is populated with the user within the simpUser header attribute for any inbound request.
3 Our messages require the proper authorization. Specifically, any inbound message that starts with /user/ will requires ROLE_USER. You can find additional details on authorization in WebSocket Authorization
Spring Security also provides XML Namespace support for securing WebSockets. A comparable XML based configuration looks like the following:spring-doc.cn
<websocket-message-broker use-authorization-manager="true"> (1) (2)
    <intercept-message pattern="/user/**" access="authenticated"/> (3)
</websocket-message-broker>
This will ensure that:spring-doc.cn
1 Any inbound CONNECT message requires a valid CSRF token to enforce Same Origin Policy
3 Our messages require the proper authorization. Specifically, any inbound message that starts with "/user/" will require ROLE_USER. Additional details on authorization can be found in WebSocket Authorization
Custom Authorization
When using AuthorizationManager, customization is quite simple. For example, you can publish an AuthorizationManager that requires that all messages have a role of "USER" using AuthorityAuthorizationManager, as seen below:spring-doc.cn
        return AuthorityAuthorizationManager.hasRole("USER");
        return AuthorityAuthorizationManager.hasRole("USER") (3)
<bean id="authorizationManager" class="org.example.MyAuthorizationManager"/>
<websocket-message-broker authorization-manager-ref="myAuthorizationManager"/>
There are several ways to further match messages, as can be seen in a more advanced example below:spring-doc.cn
    public AuthorizationManager<Message<?>> messageAuthorizationManager(MessageMatcherDelegatingAuthorizationManager.Builder messages) {
        messages
                .nullDestMatcher().authenticated() (1)
                .simpSubscribeDestMatchers("/user/queue/errors").permitAll() (2)
                .simpDestMatchers("/app/**").hasRole("USER") (3)
                .simpSubscribeDestMatchers("/user/**", "/topic/friends/*").hasRole("USER") (4)
                .simpTypeMatchers(MESSAGE, SUBSCRIBE).denyAll() (5)
                .anyMessage().denyAll(); (6)
    fun messageAuthorizationManager(messages: MessageMatcherDelegatingAuthorizationManager.Builder): AuthorizationManager<Message<?> {
        messages
            .anyMessage().denyAll() (6)
    (1)
    <intercept-message type="CONNECT" access="permitAll" />
    <intercept-message type="UNSUBSCRIBE" access="permitAll" />
    <intercept-message type="DISCONNECT" access="permitAll" />
    <intercept-message pattern="/user/queue/errors" type="SUBSCRIBE" access="permitAll" /> (2)
    <intercept-message pattern="/app/**" access="hasRole('USER')" />      (3)
    (4)
    <intercept-message pattern="/user/**" type="SUBSCRIBE" access="hasRole('USER')" />
    <intercept-message pattern="/topic/friends/*" type="SUBSCRIBE" access="hasRole('USER')" />
    (5)
    <intercept-message type="MESSAGE" access="denyAll" />
    <intercept-message type="SUBSCRIBE" access="denyAll" />
    <intercept-message pattern="/**" access="denyAll" /> (6)
1 Any message without a destination (i.e. anything other than Message type of MESSAGE or SUBSCRIBE) will require the user to be authenticated
2 Anyone can subscribe to /user/queue/errors
3 Any message that has a destination starting with "/app/" will be require the user to have the role ROLE_USER
4 Any message that starts with "/user/" or "/topic/friends/" that is of type SUBSCRIBE will require ROLE_USER
5 Any other message of type MESSAGE or SUBSCRIBE is rejected. Due to 6 we do not need this step, but it illustrates how one can match on specific message types.
6 Any other Message is rejected. This is a good idea to ensure that you do not miss any messages.
WebSocket Authorization Notes
To properly secure your application, you need to understand Spring’s WebSocket support.spring-doc.cn
WebSocket Authorization on Message Types
You need to understand the distinction between SUBSCRIBE and MESSAGE types of messages and how they work within Spring.spring-doc.cn
Consider a chat application:spring-doc.cn
  • The system can send a notification MESSAGE to all users through a destination of /topic/system/notifications.spring-doc.cn
  • Clients can receive notifications by SUBSCRIBE to the /topic/system/notifications.spring-doc.cn
While we want clients to be able to SUBSCRIBE to /topic/system/notifications, we do not want to enable them to send a MESSAGE to that destination. If we allowed sending a MESSAGE to /topic/system/notifications, clients could send a message directly to that endpoint and impersonate the system.spring-doc.cn
In general, it is common for applications to deny any MESSAGE sent to a destination that starts with the broker prefix (/topic/ or /queue/).spring-doc.cn
WebSocket Authorization on Destinations
You should also understand how destinations are transformed.spring-doc.cn
  • Users can send messages to a specific user by sending a message to the /app/chat destination.spring-doc.cn
  • The application sees the message, ensures that the from attribute is specified as the current user (we cannot trust the client).spring-doc.cn
  • The application then sends the message to the recipient by using SimpMessageSendingOperations.convertAndSendToUser("toUser", "/queue/messages", message).spring-doc.cn
  • The message gets turned into the destination of /queue/user/messages-<sessionid>.spring-doc.cn
With this chat application, we want to let our client to listen /user/queue, which is transformed into /queue/user/messages-<sessionid>. However, we do not want the client to be able to listen to /queue/*, because that would let the client see messages for every user.spring-doc.cn
In general, it is common for applications to deny any SUBSCRIBE sent to a message that starts with the broker prefix (/topic/ or /queue/). We may provide exceptions to account for things likespring-doc.cn
Outbound Messages
The Spring Framework reference documentation contains a section titled “Flow of Messages” that describes how messages flow through the system. Note that Spring Security secures only the clientInboundChannel. Spring Security does not attempt to secure the clientOutboundChannel.spring-doc.cn
The most important reason for this is performance. For every message that goes in, typically many more go out. Instead of securing the outbound messages, we encourage securing the subscription to the endpoints.spring-doc.cn
Enforcing Same Origin Policy
Note that the browser does not enforce the Same Origin Policy for WebSocket connections. This is an extremely important consideration.spring-doc.cn
Why Same Origin?
Consider the following scenario. A user visits bank.com and authenticates to their account. The same user opens another tab in their browser and visits evil.com. The Same Origin Policy ensures that evil.com cannot read data from or write data to bank.com.spring-doc.cn
With WebSockets, the Same Origin Policy does not apply. In fact, unless bank.com explicitly forbids it, evil.com can read and write data on behalf of the user. This means that anything the user can do over the webSocket (such as transferring money), evil.com can do on that user’s behalf.spring-doc.cn
Since SockJS tries to emulate WebSockets, it also bypasses the Same Origin Policy. This means that developers need to explicitly protect their applications from external domains when they use SockJS.spring-doc.cn
Spring WebSocket Allowed Origin
Fortunately, since Spring 4.1.5 Spring’s WebSocket and SockJS support restricts access to the current domain. Spring Security adds an additional layer of protection to provide defense in depth.spring-doc.cn
Adding CSRF to Stomp Headers
By default, Spring Security requires the CSRF token in any CONNECT message type. This ensures that only a site that has access to the CSRF token can connect. Since only the same origin can access the CSRF token, external domains are not allowed to make a connection.spring-doc.cn
Typically we need to include the CSRF token in an HTTP header or an HTTP parameter. However, SockJS does not allow for these options. Instead, we must include the token in the Stomp headers.spring-doc.cn
Applications can obtain a CSRF token by accessing the request attribute named _csrf. For example, the following allows accessing the CsrfToken in a JSP:spring-doc.cn
var headerName = "${_csrf.headerName}";
var token = "${_csrf.token}";
If you use static HTML, you can expose the CsrfToken on a REST endpoint. For example, the following would expose the CsrfToken on the /csrf URL:spring-doc.cn
@RestController
public class CsrfController {
    @RequestMapping("/csrf")
    public CsrfToken csrf(CsrfToken token) {
        return token;
@RestController
    fun csrf(token: CsrfToken): CsrfToken {
        return token
The JavaScript can make a REST call to the endpoint and use the response to populate the headerName and the token.spring-doc.cn
We can now include the token in our Stomp client:spring-doc.cn
var headers = {};
headers[headerName] = token;
stompClient.connect(headers, function(frame) {
Disable CSRF within WebSockets
At this point, CSRF is not configurable when using @EnableWebSocketSecurity, though this will likely be added in a future release.
To disable CSRF, instead of using @EnableWebSocketSecurity, you can use XML support or add the Spring Security components yourself, like so:spring-doc.cn
public class WebSocketSecurityConfig implements WebSocketMessageBrokerConfigurer {
    public void addArgumentResolvers(List<HandlerMethodArgumentResolver> argumentResolvers) {
        argumentResolvers.add(new AuthenticationPrincipalArgumentResolver());
    public void configureClientInboundChannel(ChannelRegistration registration) {
        AuthorizationManager<Message<?>> myAuthorizationRules = AuthenticatedAuthorizationManager.authenticated();
        AuthorizationChannelInterceptor authz = new AuthorizationChannelInterceptor(myAuthorizationRules);
        AuthorizationEventPublisher publisher = new SpringAuthorizationEventPublisher(this.context);
        authz.setAuthorizationEventPublisher(publisher);
        registration.interceptors(new SecurityContextChannelInterceptor(), authz);
open class WebSocketSecurityConfig : WebSocketMessageBrokerConfigurer {
    override fun addArgumentResolvers(argumentResolvers: List<HandlerMethodArgumentResolver>) {
        argumentResolvers.add(AuthenticationPrincipalArgumentResolver())
    override fun configureClientInboundChannel(registration: ChannelRegistration) {
        var myAuthorizationRules: AuthorizationManager<Message<?>> = AuthenticatedAuthorizationManager.authenticated()
        var authz: AuthorizationChannelInterceptor = AuthorizationChannelInterceptor(myAuthorizationRules)
        var publisher: AuthorizationEventPublisher = SpringAuthorizationEventPublisher(this.context)
        registration.interceptors(SecurityContextChannelInterceptor(), authz)
<websocket-message-broker use-authorization-manager="true" same-origin-disabled="true">
    <intercept-message pattern="/**" access="authenticated"/>
On the other hand, if you are using the legacy AbstractSecurityWebSocketMessageBrokerConfigurer and you want to allow other domains to access your site, you can disable Spring Security’s protection. For example, in Java Configuration you can use the following:spring-doc.cn
public class WebSocketSecurityConfig extends AbstractSecurityWebSocketMessageBrokerConfigurer {
    protected boolean sameOriginDisabled() {
        return true;
open class WebSocketSecurityConfig : AbstractSecurityWebSocketMessageBrokerConfigurer() {
    override fun sameOriginDisabled(): Boolean {
        return true
Custom Expression Handler
At times, there may be value in customizing how the access expressions are handled defined in your intercept-message XML elements. To do this, you can create a class of type SecurityExpressionHandler<MessageAuthorizationContext<?>> and refer to it in your XML definition like so:spring-doc.cn
    <expression-handler ref="myRef"/>
<b:bean ref="myRef" class="org.springframework.security.messaging.access.expression.MessageAuthorizationContextSecurityExpressionHandler"/>
If you are migrating from a legacy usage of websocket-message-broker that implements a SecurityExpressionHandler<Message<?>>, you can: 1. Additionally implement the createEvaluationContext(Supplier, Message) method and then 2. Wrap that value in a MessageAuthorizationContextSecurityExpressionHandler like so:spring-doc.cn
<b:bean ref="myRef" class="org.springframework.security.messaging.access.expression.MessageAuthorizationContextSecurityExpressionHandler">
    <b:constructor-arg>
        <b:bean class="org.example.MyLegacyExpressionHandler"/>
    </b:constructor-arg>
</b:bean>
Working with SockJS
SockJS provides fallback transports to support older browsers. When using the fallback options, we need to relax a few security constraints to allow SockJS to work with Spring Security.spring-doc.cn
SockJS & frame-options
SockJS may use a transport that leverages an iframe. By default, Spring Security denies the site from being framed to prevent clickjacking attacks. To allow SockJS frame-based transports to work, we need to configure Spring Security to let the same origin frame the content.spring-doc.cn
You can customize X-Frame-Options with the frame-options element. For example, the following instructs Spring Security to use X-Frame-Options: SAMEORIGIN, which allows iframes within the same domain:spring-doc.cn
<http>
    <headers>
        <frame-options
          policy="SAMEORIGIN" />
    </headers>
</http>
Similarly, you can customize frame options to use the same origin within Java Configuration by using the following:spring-doc.cn
@EnableWebSecurity
public class WebSecurityConfig {
        http
            .headers(headers -> headers
                .frameOptions(frameOptions -> frameOptions
                     .sameOrigin()
        return http.build();
@EnableWebSecurity
open class WebSecurityConfig {
        http {
            headers {
                frameOptions {
                    sameOrigin = true
        return http.build()
SockJS & Relaxing CSRF
SockJS uses a POST on the CONNECT messages for any HTTP-based transport. Typically, we need to include the CSRF token in an HTTP header or an HTTP parameter. However, SockJS does not allow for these options. Instead, we must include the token in the Stomp headers as described in Adding CSRF to Stomp Headers.spring-doc.cn
It also means that we need to relax our CSRF protection with the web layer. Specifically, we want to disable CSRF protection for our connect URLs. We do NOT want to disable CSRF protection for every URL. Otherwise, our site is vulnerable to CSRF attacks.spring-doc.cn
We can easily achieve this by providing a CSRF RequestMatcher. Our Java configuration makes this easy. For example, if our stomp endpoint is /chat, we can disable CSRF protection only for URLs that start with /chat/ by using the following configuration:spring-doc.cn
@EnableWebSecurity
        http
            .csrf(csrf -> csrf
                // ignore our stomp endpoints since they are protected using Stomp headers
                .ignoringRequestMatchers("/chat/**")
                // allow same origin to frame our site to support iframe SockJS
                    .sameOrigin()
@EnableWebSecurity
        http {
            csrf {
            headers {
                frameOptions {
                    sameOrigin = true
            authorizeRequests {
If we use XML-based configuration, we can use thecsrf@request-matcher-ref.spring-doc.cn
<http ...>
    <csrf request-matcher-ref="csrfMatcher"/>
    <headers>
        <frame-options policy="SAMEORIGIN"/>
    </headers>
</http>
<b:bean id="csrfMatcher"
    class="AndRequestMatcher">
    <b:constructor-arg value="#{T(org.springframework.security.web.csrf.CsrfFilter).DEFAULT_CSRF_MATCHER}"/>
    <b:constructor-arg>
        <b:bean class="org.springframework.security.web.util.matcher.NegatedRequestMatcher">
          <b:bean class="org.springframework.security.web.util.matcher.AntPathRequestMatcher">
            <b:constructor-arg value="/chat/**"/>
          </b:bean>
        </b:bean>
</b:bean>
Legacy WebSocket Configuration
Before Spring Security 5.8, the way to configure messaging authorization using Java Configuration, was to extend the AbstractSecurityWebSocketMessageBrokerConfigurer and configure the MessageSecurityMetadataSourceRegistry. For example:spring-doc.cn
      extends AbstractSecurityWebSocketMessageBrokerConfigurer { (1) (2)
    protected void configureInbound(MessageSecurityMetadataSourceRegistry messages) {
        messages
open class WebSocketSecurityConfig : AbstractSecurityWebSocketMessageBrokerConfigurer() { (1) (2)
    override fun configureInbound(messages: MessageSecurityMetadataSourceRegistry) {
Using the legacy configuration is helpful in the event that you have a custom SecurityExpressionHandler that extends AbstractSecurityExpressionHandler and overrides createEvaluationContextInternal or createSecurityExpressionRoot. In order to defer Authorization lookup, the new AuthorizationManager API does not invoke these when evaluating expressions.spring-doc.cn
If you are using XML, you can use the legacy APIs simply by not using the use-authorization-manager element or setting it to false.spring-doc.cn
