Authorize HttpServletRequest with FilterSecurityInterceptor
FilterSecurityInterceptor is in the process of being replaced by AuthorizationFilter. Consider using that instead.spring-doc.cn
This section builds on Servlet Architecture and Implementation by digging deeper into how authorization works within Servlet-based applications.spring-doc.cn
The FilterSecurityInterceptor provides authorization for HttpServletRequest instances. It is inserted into the FilterChainProxy as one of the Security Filters.spring-doc.cn
The following image shows the role of FilterSecurityInterceptor:spring-doc.cn
filtersecurityinterceptor
Figure 1. Authorize HttpServletRequest
number 1 The FilterSecurityInterceptor obtains an Authentication from the SecurityContextHolder. number 2 FilterSecurityInterceptor creates a FilterInvocation from the HttpServletRequest, HttpServletResponse, and FilterChain that are passed into the FilterSecurityInterceptor. number 3 It passes the FilterInvocation to SecurityMetadataSource to get the ConfigAttributes. number 4 It passes the Authentication, FilterInvocation, and ConfigAttributes to the AccessDecisionManager. number 5 If authorization is denied, an AccessDeniedException is thrown. In this case, the ExceptionTranslationFilter handles the AccessDeniedException. number 6 If access is granted, FilterSecurityInterceptor continues with the FilterChain, which lets the application process normally.spring-doc.cn
By default, Spring Security’s authorization requires all requests to be authenticated. The following listing shows the explicit configuration:spring-doc.cn
Every Request Must be Authenticated
	http
		.authorizeRequests(authorize -> authorize
			.anyRequest().authenticated()
	return http.build();
<http>
	<intercept-url pattern="/**" access="authenticated"/>
</http>
    http {
        authorizeRequests {
    return http.build()
We can configure Spring Security to have different rules by adding more rules in order of precedence:spring-doc.cn
Authorize Requests
	http
		.authorizeRequests(authorize -> authorize                                  (1)
			.requestMatchers("/resources/**", "/signup", "/about").permitAll()         (2)
			.requestMatchers("/admin/**").hasRole("ADMIN")                             (3)
			.requestMatchers("/db/**").access("hasRole('ADMIN') and hasRole('DBA')")   (4)
			.anyRequest().denyAll()                                                (5)
<http> (1)
	(2)
	<intercept-url pattern="/resources/**" access="permitAll"/>
	<intercept-url pattern="/signup" access="permitAll"/>
	<intercept-url pattern="/about" access="permitAll"/>
	<intercept-url pattern="/admin/**" access="hasRole('ADMIN')"/> (3)
	<intercept-url pattern="/db/**" access="hasRole('ADMIN') and hasRole('DBA')"/> (4)
	<intercept-url pattern="/**" access="denyAll"/> (5)
</http>
   http {
        authorizeRequests { (1)
            authorize("/resources/**", permitAll) (2)
            authorize("/signup", permitAll)
            authorize("/about", permitAll)
            authorize("/admin/**", hasRole("ADMIN")) (3)
            authorize("/db/**", "hasRole('ADMIN') and hasRole('DBA')") (4)
            authorize(anyRequest, denyAll) (5)
    return http.build()
1 There are multiple authorization rules specified. Each rule is considered in the order they were declared.
2 We specified multiple URL patterns that any user can access. Specifically, any user can access a request if the URL starts with "/resources/", equals "/signup", or equals "/about".
3 Any URL that starts with "/admin/" will be restricted to users who have the role "ROLE_ADMIN". You will notice that since we are invoking the hasRole method we do not need to specify the "ROLE_" prefix.
4 Any URL that starts with "/db/" requires the user to have both "ROLE_ADMIN" and "ROLE_DBA". You will notice that since we are using the hasRole expression we do not need to specify the "ROLE_" prefix.
5 Any URL that has not already been matched on is denied access. This is a good strategy if you do not want to accidentally forget to update your authorization rules.
Configure FilterSecurityInterceptor with Dispatcher Types
By default, the FilterSecurityInterceptor applies to every request. This means that if a request is dispatched from a request that was already filtered, the FilterSecurityInterceptor will perform the same authorization checks on the dispatched request. In some scenarios, you may not want to apply authorization on some dispatcher types:spring-doc.cn
Permit ASYNC and ERROR dispatcher types
SecurityFilterChain web(HttpSecurity http) throws Exception {
    http
        .authorizeRequests((authorize) -> authorize
            .dispatcherTypeMatchers(DispatcherType.ASYNC, DispatcherType.ERROR).permitAll()
            .anyRequest.authenticated()
<http auto-config="true">
    <intercept-url request-matcher-ref="dispatcherTypeMatcher" access="permitAll" />
</http>
<b:bean id="dispatcherTypeMatcher" class="org.springframework.security.web.util.matcher.DispatcherTypeRequestMatcher">
    <b:constructor-arg value="ASYNC"/>
    <b:constructor-arg value="ERROR"/>
</b:bean>
