HTTP
All HTTP-based communication, including static resources, should be protected by using TLS.spring-doc.cn
As a framework, Spring Security does not handle HTTP connections and thus does not provide support for HTTPS directly. However, it does provide a number of features that help with HTTPS usage.spring-doc.cn
Redirect to HTTPS
When a client uses HTTP, you can configure Spring Security to redirect to HTTPS in both Servlet and WebFlux environments.spring-doc.cn
Strict Transport Security
Spring Security provides support for Strict Transport Security and enables it by default.spring-doc.cn
Proxy Server Configuration
When using a proxy server, it is important to ensure that you have configured your application properly. For example, many applications have a load balancer that responds to request for https://example.com/ by forwarding the request to an application server at https://192.168.0.107 Without proper configuration, the application server can not know that the load balancer exists and treats the request as though https://192.168.0.107:8080 was requested by the client.spring-doc.cn
To fix this, you can use RFC 7239 to specify that a load balancer is being used. To make the application aware of this, you need to configure your application server to be aware of the X-Forwarded headers. For example, Tomcat uses RemoteIpValve and Jetty uses ForwardedRequestCustomizer. Alternatively, Spring users can use ForwardedHeaderFilter.spring-doc.cn
Spring Boot users can use the server.use-forward-headers property to configure the application. See the Spring Boot documentation for further details.spring-doc.cn
