OAuth 2.0 Resource Server JWT
Minimal Dependencies for JWT
Most Resource Server support is collected into spring-security-oauth2-resource-server. However, the support for decoding and verifying JWTs is in spring-security-oauth2-jose, meaning that both are necessary to have a working resource server that supports JWT-encoded Bearer Tokens.spring-doc.cn
Minimal Configuration for JWTs
When using Spring Boot, configuring an application as a resource server consists of two basic steps. First, include the needed dependencies. Second, indicate the location of the authorization server.spring-doc.cn
Specifying the Authorization Server
In a Spring Boot application, you need to specify which authorization server to use:spring-doc.cn
spring:
  security:
    oauth2:
      resourceserver:
        jwt:
          issuer-uri: https://idp.example.com/issuer
Where idp.example.com/issuer is the value contained in the iss claim for JWT tokens that the authorization server issues. This resource server uses this property to further self-configure, discover the authorization server’s public keys, and subsequently validate incoming JWTs.spring-doc.cn
To use the issuer-uri property, it must also be true that one of idp.example.com/issuer/.well-known/openid-configuration, idp.example.com/.well-known/openid-configuration/issuer, or idp.example.com/.well-known/oauth-authorization-server/issuer is a supported endpoint for the authorization server. This endpoint is referred to as a Provider Configuration endpoint or a Authorization Server Metadata endpoint.spring-doc.cn
Startup Expectations
When this property and these dependencies are used, Resource Server automatically configures itself to validate JWT-encoded Bearer Tokens.spring-doc.cn
It achieves this through a deterministic startup process:spring-doc.cn
  1. Hit the Provider Configuration or Authorization Server Metadata endpoint, processing the response for the jwks_url property.spring-doc.cn
  2. Configure the validation strategy to query jwks_url for valid public keys.spring-doc.cn
  3. Configure the validation strategy to validate each JWT’s iss claim against idp.example.com.spring-doc.cn
A consequence of this process is that the authorization server must be receiving requests in order for Resource Server to successfully start up.spring-doc.cn
If the authorization server is down when Resource Server queries it (given appropriate timeouts), then startup fails.spring-doc.cn
Runtime Expectations
Once the application is started up, Resource Server tries to process any request that contains an Authorization: Bearer header:spring-doc.cn
GET / HTTP/1.1
Authorization: Bearer some-token-value # Resource Server will process this
So long as this scheme is indicated, Resource Server tries to process the request according to the Bearer Token specification.spring-doc.cn
Given a well-formed JWT, Resource Server:spring-doc.cn
  1. Validates its signature against a public key obtained from the jwks_url endpoint during startup and matched against the JWTs header.spring-doc.cn
  2. Validates the JWTs exp and nbf timestamps and the JWTs iss claim.spring-doc.cn
  3. Maps each scope to an authority with the prefix SCOPE_.spring-doc.cn
As the authorization server makes available new keys, Spring Security automatically rotates the keys used to validate the JWT tokens.spring-doc.cn
By default, the resulting Authentication#getPrincipal is a Spring Security Jwt object, and Authentication#getName maps to the JWT’s sub property, if one is present.spring-doc.cn
From here, consider jumping to:spring-doc.cn
Specifying the Authorization Server JWK Set Uri Directly
If the authorization server does not support any configuration endpoints, or if Resource Server must be able to start up independently from the authorization server, you can supply jwk-set-uri as well:spring-doc.cn
spring:
  security:
    oauth2:
      resourceserver:
        jwt:
          jwk-set-uri: https://idp.example.com/.well-known/jwks.json
The JWK Set uri is not standardized, but you can typically find it in the authorization server’s documentation.spring-doc.cn
Consequently, Resource Server does not ping the authorization server at startup. We still specify the issuer-uri so that Resource Server still validates the iss claim on incoming JWTs.spring-doc.cn
You can supply this property directly on the DSL.spring-doc.cn
Overriding or Replacing Boot Auto Configuration
Spring Boot generates two @Bean objects on Resource Server’s behalf.spring-doc.cn
The first bean is a SecurityWebFilterChain that configures the application as a resource server. When including spring-security-oauth2-jose, this SecurityWebFilterChain looks like:spring-doc.cn
Resource Server SecurityWebFilterChain
SecurityWebFilterChain springSecurityFilterChain(ServerHttpSecurity http) {
	http
		.authorizeExchange(exchanges -> exchanges
		.oauth2ResourceServer(OAuth2ResourceServerSpec::jwt)
	return http.build();
fun springSecurityFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
    return http {
        authorizeExchange {
        oauth2ResourceServer {
            jwt { }
If the application does not expose a SecurityWebFilterChain bean, Spring Boot exposes the default one (shown in the preceding listing).spring-doc.cn
To replace it, expose the @Bean within the application:spring-doc.cn
Replacing SecurityWebFilterChain
	http
			.pathMatchers("/message/**").hasAuthority("SCOPE_message:read")
		.oauth2ResourceServer(oauth2 -> oauth2
			.jwt(withDefaults())
    return http {
        authorizeExchange {
            authorize("/message/**", hasAuthority("SCOPE_message:read"))
            jwt { }
The preceding configuration requires the scope of message:read for any URL that starts with /messages/.spring-doc.cn
Methods on the oauth2ResourceServer DSL also override or replace auto configuration.spring-doc.cn
For example, the second @Bean Spring Boot creates is a ReactiveJwtDecoder, which decodes String tokens into validated instances of Jwt:spring-doc.cn
ReactiveJwtDecoder
public ReactiveJwtDecoder jwtDecoder() {
    return ReactiveJwtDecoders.fromIssuerLocation(issuerUri);
fun jwtDecoder(): ReactiveJwtDecoder {
Calling ReactiveJwtDecoders#fromIssuerLocation invokes the Provider Configuration or Authorization Server Metadata endpoint to derive the JWK Set URI. If the application does not expose a ReactiveJwtDecoder bean, Spring Boot exposes the above default one.spring-doc.cn
Its configuration can be overridden by using jwkSetUri() or replaced by using decoder().spring-doc.cn
Using jwkSetUri()
You can configure an authorization server’s JWK Set URI as a configuration property or supply it in the DSL:spring-doc.cn
	http
			.jwt(jwt -> jwt
				.jwkSetUri("https://idp.example.com/.well-known/jwks.json")
    return http {
        authorizeExchange {
            jwt {
                jwkSetUri = "https://idp.example.com/.well-known/jwks.json"
Using jwkSetUri() takes precedence over any configuration property.spring-doc.cn
Using decoder()
decoder() is more powerful than jwkSetUri(), because it completely replaces any Spring Boot auto-configuration of JwtDecoder:spring-doc.cn
	http
			.jwt(jwt -> jwt
				.decoder(myCustomDecoder())
    return http {
        authorizeExchange {
            jwt {
                jwtDecoder = myCustomDecoder()
This is handy when you need deeper configuration, such as validation.spring-doc.cn
Exposing a ReactiveJwtDecoder @Bean
Alternately, exposing a ReactiveJwtDecoder @Bean has the same effect as decoder():spring-doc.cn
    return NimbusReactiveJwtDecoder.withJwkSetUri(jwkSetUri).build();
Configuring Trusted Algorithms
By default, NimbusReactiveJwtDecoder, and hence Resource Server, trust and verify only tokens that use RS256.spring-doc.cn
You can customize this behavior with Spring Boot or by using the NimbusJwtDecoder builder.spring-doc.cn
Customizing Trusted Algorithms with Spring Boot
The simplest way to set the algorithm is as a property:spring-doc.cn
spring:
  security:
    oauth2:
      resourceserver:
        jwt:
          jws-algorithm: RS512
          jwk-set-uri: https://idp.example.org/.well-known/jwks.json
Customizing Trusted Algorithms by Using a Builder
For greater power, though, we can use a builder that ships with NimbusReactiveJwtDecoder:spring-doc.cn
    return NimbusReactiveJwtDecoder.withJwkSetUri(this.jwkSetUri)
            .jwsAlgorithm(RS512).build();
Calling jwsAlgorithm more than once configures NimbusReactiveJwtDecoder to trust more than one algorithm:spring-doc.cn
            .jwsAlgorithm(RS512).jwsAlgorithm(ES512).build();
Alternately, you can call jwsAlgorithms:spring-doc.cn
            .jwsAlgorithms(algorithms -> {
                    algorithms.add(RS512);
                    algorithms.add(ES512);
            }).build();
            .jwsAlgorithms {
                it.add(RS512)
                it.add(ES512)
            .build()
Trusting a Single Asymmetric Key
Simpler than backing a Resource Server with a JWK Set endpoint is to hard-code an RSA public key. The public key can be provided with Spring Boot or by Using a Builder.spring-doc.cn
Via Spring Boot
You can specify a key with Spring Boot:spring-doc.cn
spring:
  security:
    oauth2:
      resourceserver:
        jwt:
          public-key-location: classpath:my-key.pub
Alternately, to allow for a more sophisticated lookup, you can post-process the RsaKeyConversionServicePostProcessor:spring-doc.cn
BeanFactoryPostProcessor
BeanFactoryPostProcessor conversionServiceCustomizer() {
    return beanFactory ->
        beanFactory.getBean(RsaKeyConversionServicePostProcessor.class)
                .setResourceLoader(new CustomResourceLoader());
fun conversionServiceCustomizer(): BeanFactoryPostProcessor {
    return BeanFactoryPostProcessor { beanFactory: ConfigurableListableBeanFactory ->
        beanFactory.getBean<RsaKeyConversionServicePostProcessor>()
                .setResourceLoader(CustomResourceLoader())
Specify your key’s location:spring-doc.cn
key.location: hfds://my-key.pub
Then autowire the value:spring-doc.cn
@Value("${key.location}")
RSAPublicKey key;
@Value("\${key.location}")
val key: RSAPublicKey? = null
Using a Builder
To wire an RSAPublicKey directly, use the appropriate NimbusReactiveJwtDecoder builder:spring-doc.cn
    return NimbusReactiveJwtDecoder.withPublicKey(this.key).build();
    return NimbusReactiveJwtDecoder.withPublicKey(key).build()
Trusting a Single Symmetric Key
You can also use a single symmetric key. You can load in your SecretKey and use the appropriate NimbusReactiveJwtDecoder builder:spring-doc.cn
    return NimbusReactiveJwtDecoder.withSecretKey(this.key).build();
Configuring Authorization
A JWT that is issued from an OAuth 2.0 Authorization Server typically has either a scope or an scp attribute, indicating the scopes (or authorities) it has been granted — for example:spring-doc.cn
{ ..., "scope" : "messages contacts"}
When this is the case, Resource Server tries to coerce these scopes into a list of granted authorities, prefixing each scope with the string, SCOPE_.spring-doc.cn
This means that, to protect an endpoint or method with a scope derived from a JWT, the corresponding expressions should include this prefix:spring-doc.cn
	http
			.mvcMatchers("/contacts/**").hasAuthority("SCOPE_contacts")
			.mvcMatchers("/messages/**").hasAuthority("SCOPE_messages")
		.oauth2ResourceServer(OAuth2ResourceServerSpec::jwt);
    return http {
        authorizeExchange {
            authorize("/contacts/**", hasAuthority("SCOPE_contacts"))
            authorize("/messages/**", hasAuthority("SCOPE_messages"))
            jwt { }
You can do something similar with method security:spring-doc.cn
@PreAuthorize("hasAuthority('SCOPE_messages')")
public Flux<Message> getMessages(...) {}
fun getMessages(): Flux<Message> { }
Extracting Authorities Manually
However, there are a number of circumstances where this default is insufficient. For example, some authorization servers do not use the scope attribute. Instead, they have their own custom attribute. At other times, the resource server may need to adapt the attribute or a composition of attributes into internalized authorities.spring-doc.cn
To this end, the DSL exposes jwtAuthenticationConverter():spring-doc.cn
	http
			.jwt(jwt -> jwt
				.jwtAuthenticationConverter(grantedAuthoritiesExtractor())
Converter<Jwt, Mono<AbstractAuthenticationToken>> grantedAuthoritiesExtractor() {
    JwtAuthenticationConverter jwtAuthenticationConverter =
            new JwtAuthenticationConverter();
    jwtAuthenticationConverter.setJwtGrantedAuthoritiesConverter
            (new GrantedAuthoritiesExtractor());
    return new ReactiveJwtAuthenticationConverterAdapter(jwtAuthenticationConverter);
    return http {
        authorizeExchange {
            jwt {
                jwtAuthenticationConverter = grantedAuthoritiesExtractor()
fun grantedAuthoritiesExtractor(): Converter<Jwt, Mono<AbstractAuthenticationToken>> {
    val jwtAuthenticationConverter = JwtAuthenticationConverter()
    jwtAuthenticationConverter.setJwtGrantedAuthoritiesConverter(GrantedAuthoritiesExtractor())
    return ReactiveJwtAuthenticationConverterAdapter(jwtAuthenticationConverter)
jwtAuthenticationConverter() is responsible for converting a Jwt into an Authentication. As part of its configuration, we can supply a subsidiary converter to go from Jwt to a Collection of granted authorities.spring-doc.cn
That final converter might be something like the following GrantedAuthoritiesExtractor:spring-doc.cn
static class GrantedAuthoritiesExtractor
        implements Converter<Jwt, Collection<GrantedAuthority>> {
    public Collection<GrantedAuthority> convert(Jwt jwt) {
        Collection<?> authorities = (Collection<?>)
                jwt.getClaims().getOrDefault("mycustomclaim", Collections.emptyList());
        return authorities.stream()
                .map(Object::toString)
                .map(SimpleGrantedAuthority::new)
                .collect(Collectors.toList());
internal class GrantedAuthoritiesExtractor : Converter<Jwt, Collection<GrantedAuthority>> {
    override fun convert(jwt: Jwt): Collection<GrantedAuthority> {
        val authorities: List<Any> = jwt.claims
                .getOrDefault("mycustomclaim", emptyList<Any>()) as List<Any>
        return authorities
                .map { it.toString() }
                .map { SimpleGrantedAuthority(it) }
For more flexibility, the DSL supports entirely replacing the converter with any class that implements Converter<Jwt, Mono<AbstractAuthenticationToken>>:spring-doc.cn
static class CustomAuthenticationConverter implements Converter<Jwt, Mono<AbstractAuthenticationToken>> {
    public AbstractAuthenticationToken convert(Jwt jwt) {
        return Mono.just(jwt).map(this::doConversion);
internal class CustomAuthenticationConverter : Converter<Jwt, Mono<AbstractAuthenticationToken>> {
    override fun convert(jwt: Jwt): Mono<AbstractAuthenticationToken> {
Configuring Validation
Using minimal Spring Boot configuration, indicating the authorization server’s issuer URI, Resource Server defaults to verifying the iss claim as well as the exp and nbf timestamp claims.spring-doc.cn
In circumstances where you need to customize validation needs, Resource Server ships with two standard validators and also accepts custom OAuth2TokenValidator instances.spring-doc.cn
Customizing Timestamp Validation
JWT instances typically have a window of validity, with the start of the window indicated in the nbf claim and the end indicated in the exp claim.spring-doc.cn
However, every server can experience clock drift, which can cause tokens to appear to be expired to one server but not to another. This can cause some implementation heartburn, as the number of collaborating servers increases in a distributed system.spring-doc.cn
Resource Server uses JwtTimestampValidator to verify a token’s validity window, and you can configure it with a clockSkew to alleviate the clock drift problem:spring-doc.cn
     NimbusReactiveJwtDecoder jwtDecoder = (NimbusReactiveJwtDecoder)
     OAuth2TokenValidator<Jwt> withClockSkew = new DelegatingOAuth2TokenValidator<>(
            new JwtTimestampValidator(Duration.ofSeconds(60)),
            new IssuerValidator(issuerUri));
     jwtDecoder.setJwtValidator(withClockSkew);
     return jwtDecoder;
    val jwtDecoder = ReactiveJwtDecoders.fromIssuerLocation(issuerUri) as NimbusReactiveJwtDecoder
    val withClockSkew: OAuth2TokenValidator<Jwt> = DelegatingOAuth2TokenValidator(
            JwtIssuerValidator(issuerUri))
    return jwtDecoder
By default, Resource Server configures a clock skew of 60 seconds.spring-doc.cn
Configuring a Custom Validator
You can Add a check for the aud claim with the OAuth2TokenValidator API:spring-doc.cn
public class AudienceValidator implements OAuth2TokenValidator<Jwt> {
    OAuth2Error error = new OAuth2Error("invalid_token", "The required audience is missing", null);
    public OAuth2TokenValidatorResult validate(Jwt jwt) {
        if (jwt.getAudience().contains("messaging")) {
            return OAuth2TokenValidatorResult.success();
        } else {
            return OAuth2TokenValidatorResult.failure(error);
class AudienceValidator : OAuth2TokenValidator<Jwt> {
    var error: OAuth2Error = OAuth2Error("invalid_token", "The required audience is missing", null)
    override fun validate(jwt: Jwt): OAuth2TokenValidatorResult {
        return if (jwt.audience.contains("messaging")) {
        } else {
Then, to add into a resource server, you can specifying the ReactiveJwtDecoder instance:spring-doc.cn
    OAuth2TokenValidator<Jwt> audienceValidator = new AudienceValidator();
    OAuth2TokenValidator<Jwt> withIssuer = JwtValidators.createDefaultWithIssuer(issuerUri);
    OAuth2TokenValidator<Jwt> withAudience = new DelegatingOAuth2TokenValidator<>(withIssuer, audienceValidator);
    jwtDecoder.setJwtValidator(withAudience);
    return jwtDecoder;
    val audienceValidator: OAuth2TokenValidator<Jwt> = AudienceValidator()
    val withIssuer: OAuth2TokenValidator<Jwt> = JwtValidators.createDefaultWithIssuer(issuerUri)
    val withAudience: OAuth2TokenValidator<Jwt> = DelegatingOAuth2TokenValidator(withIssuer, audienceValidator)
    return jwtDecoder
